Sony xbr-75x900f 6 red blink
  • EazyBone
    • Jun 2023
    • 1338
    • United states
    Picked up a $4000 2018 TV and it's blinking 6x red. A search says something with backlights or led drivers board. This is my first time with such a complex TV. It's got 2 power boards, led drivers, tcon, main it's crazy lol.
    So I check voltages to main, all fine. 12.47v. I hit power and the BL_ON goes to 3.5V shortly and will kick off and red light flashes. Power board looks to be okay, but there is 2 power boards lol. 12V is at least hitting the second power board.
    I'm gonna test everything but how do I even test the LEDs on this thing without taking it all apart? Usually it's a wire going to lights, this has 12 ribbons. Can led tester show me if these work? Any help would be appreciated.
    • 12201
    • U.S.
    Re: Sony xbr-75x900f 6 red blink
    Check the bl_error pin, cn6401 pin 1.
    • EazyBone
      • Jun 2023
      • 1338
      • United states
      Am I looking for any voltage?
      Turn on TV. Voltage 3.3. Power board relay clicks drops to zero get flashing red light. The LED driver board has an LED that turns on
      • Storyteller12
        • Jun 2020
        • 624
        6 blinks on Sony TVs is bad backlights. Have to take it apart and replace them
        • EazyBone
          • Jun 2023
          • 1338
          • United states
          This needs a diagram just to take it apart. Good Lord.
          • lotas
            • Jan 2016
            • 4611
            • Russia
            SONY XBR-75X9*F GN4TR CHASSIS "6" - error.
            • Storyteller12
              • Jun 2020
              • 624
              Yeah, Sonys are never fun to tear apart. Not hard, just time consuming and tedious.
              Good luck. Let us know how it goes
              • EazyBone
                • Jun 2023
                • 1338
                • United states
                I've torn apart quite a few. I'm considering replacing a single LED or all of them.. all is $110 though. Although the 75s are very worrisome when taking the screen off. I did it 3x and no break yet but man it don't feel stable.
                I read in another post some guy tried a single LED on these sonys and it wouldn't accept it.. so probably gonna go new route. But will report fix when it happens
                  • 12201
                  • U.S.
                  There's a test that sometimes works, involves grounding the bl_sos wire, of course I forgot exactly how it's done, check Nick's tv on youtube, he has at least one video of the test "temp fix"
                    • 12201
                    • U.S.
                    One there, probably more too: https://www.youtube.com/watch?v=T3VRvQUB_DQ
                    • Storyteller12
                      • Jun 2020
                      • 624
                      You can replace single led. All the xbr series I’ve worked on are 12v though. Not 3v or 6v like most. Not a common voltage and sometimes harder to find. But it can be done.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4333
                        • Italy - Milan
                        I suspect in this type of set leds hardly can fail, the smaller power board is the led power board, i see it takes pfc tension from main psb and transforms it with the big transformer to i guess a smaller tension, check first in the early seconds of tv on the output voltage of that board, check it also on the blue board after the fuse, on that there is i guess also a micro controller, the software on it can be failed also, getting apart so a big tv for testing leds is high risky, all tests on boards are mandatory before.. get the service manual!
                        • EazyBone
                          • Jun 2023
                          • 1338
                          • United states
                          You can replace single led. All the xbr series I've worked on are 12v though. Not 3v or 6v like most. Not a common voltage and sometimes harder to find. But it can be done.
                          Would this be the set you are talking about? I can only find one type for 12v. Is there different ones? Would rather replace one then all.
                          Just found this amazing item on AliExpress. Check it out! $9.56 | 50PCS For SONY LED LCD Backlight TV Application LED Backlight 2.5W 12V 3535 Cool white TV Application
                          https://a.aliexpress.com/_mPFT8IE
                          • EazyBone
                            • Jun 2023
                            • 1338
                            • United states
                            I can do that, but at what test points? Sorry this additional board is confusing to me. I'm self learning all of this (with this group and internet). Am I looking for voltages coming from main PSU to the LED PSU? There is 2 sets of wires going to it. Or the voltages coming from LED PSU to the LED driver board? Sorry for all the questions.. but I'll try and mess with all voltages I see.
                            OR I'm gonna Google a service manual, but maybe you know a site to get them fro
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4333
                              • Italy - Milan
                              the output voltage of the led psu.. photograph also close the ARM cpu on the blue board..
                                • 12201
                                • U.S.
                                Well did you watch Nick's video linked in post #10.
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  Those should work. But I would take it apart and remove the bad led just to verify there the same.
                                  • EazyBone
                                    • Jun 2023
                                    • 1338
                                    • United states
                                    Yes actually and when I grounded it from LED driver PSU to main PSU I got it then to blink 4x. When I did main PSU to LED PSU It stayed 6 blink.
                                    I cannot also get a voltage on the LED driver at the fuse at all. I do get a yellow light on the driver that lights up temporarily and a red one that flashes 3x stops then 3x occasionally
                                    • EazyBone
                                      • Jun 2023
                                      • 1338
                                      • United states
                                      Here's blue board pics
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4333
                                        • Italy - Milan
                                        Repeat... check the led psu output in the early seconds after power up...
                                        the STM32 cpu can be programmed with a big free software from ST website and a cheap i2c adapter or a ch341a (don't remember), but it's quite hard and is also hard find firmware.. the power on the blue board must be checked in early seconds!!
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
