Sony KDL-46EX700
  • digitalshooter
    • Jul 2023
    • 24
    Re: Sony KDL-46EX700
    Originally posted by Davi.p
    this is what you told:
    and so i answered..
    the persistance of 6 blinks is either bad strips or bad backlight circuit, but i guess is the first, so why don't try the same my advice?
    Thanks...I tested the strips before install and they all worked, so as we in America would say: I assume they are good.. So now I need to figure out, per your advice, how to test the backlight circuit that you mention.
    I am a novice to this, although I have experience in computer repair. I am also reading a Sony Training Manual: AZ1L Direct View LCD Television Chassis Course: CTV for ideas,
    • EazyBone
      • Jun 2023
      • 1353
      • United states
      6 blinks was not bad LEDs for my Sony. It's bad power board. I tested all lights before removing and they all worked. I replaced anyways because of comments stating it's bad LEDs. New LEDs all worked and still 6 blinks. It states power board for my TV. My TV had 2 power boards. I would look more closely at that because this advice led me astray also.
      Says most likely power board or panel. Then says replace main board. This is for 900f though so I'd look into that. The new problem you have well I don't know. Just do due diligence into PSU checking
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4464
        • Italy - Milan
        A normal backlight tester is not good enough to test leds with small leakage, if you think i'm saying stupid things i don't know what to do, if you want my help you can simply follow my advices, testing a psb is not as easy as my test.. anyway if you know the ohm's law and you are rich in power resistors arsenal you can put some and simulate the leds, hoping you have psb specs
        • EazyBone
          • Jun 2023
          • 1353
          • United states
          Don't know if you are talking about me davi, I am just giving my experience and sharing the info I have. I don't know if you are taking offense to something I am saying but I ain't here to make people wrong just help fix tvs. Just giving the info I have, like others give to me. Good luck op
          • digitalshooter
            • Jul 2023
            • 24
            I appreciate your assistance, I DO NOT THINK you are saying stupid things, never said that or inferred it!
            I'm very handy, but know little about the actual fine testing methods you describe.
              • 12276
              • U.S.
              #26
              Did you check over your solder joints?
              • digitalshooter
                • Jul 2023
                • 24
                Yes with a magnifying glass and as best I could tell, all looked good.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4464
                  • Italy - Milan
                  #28
                  eazybone i was talking to digitalshooter..
                  • digitalshooter
                    • Jul 2023
                    • 24
                    So new used board is in and all works, except I messed up one of the LVDS cables that connects the TCON to the screen. Any ideas where I can get? Do I need a Sony or can this type flex cable be gotten (and made) from any electronics store?
                      • 12276
                      • U.S.
                      #30
                      Should be a number on your cable, put that in search, maybe try ebay.
                      • digitalshooter
                        • Jul 2023
                        • 24
                        Could not find one:
                        • digitalshooter
                          • Jul 2023
                          • 24
                          OK so I just got this part number from Encompass: 1-837-704-11
                          • digitalshooter
                            • Jul 2023
                            • 24
                            No luck so far, is this something that can be made?
                              • 12276
                              • U.S.
                              #34
                              Can you show a good picture of the damaged area?
                              • digitalshooter
                                • Jul 2023
                                • 24
                                The corner got bent over.
                                  • 12276
                                  • U.S.
                                  #36
                                  So it's a lvds cable that goes from tcon to mainboard NOT tcon to panel driver board, probably best to get a replacement, not sure what models are interchangeable.
                                  • digitalshooter
                                    • Jul 2023
                                    • 24
                                    It goes from the TCON to the screen.
                                      • 12276
                                      • U.S.
                                      #38
                                      Ok, hard to tell from the picture.
                                      • digitalshooter
                                        • Jul 2023
                                        • 24
                                        TV is now repaired. Was able to source an aftermarket cable from an eBay seller in China and the used board from here in the states.
                                        • EazyBone
                                          • Jun 2023
                                          • 1353
                                          • United states
                                          #40
                                          Thx for report back ��
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • James007$
                                            Sony KDL-70R550A red led blinking 5 times, troubleshooting
                                            by James007$
                                            Hey mates! my tv keeps blinking 5 time and when I turn on it doesn't show anything on screen and it turns off after a few seconds.
                                            I am having the same issue as this guy: https://www.badcaps.net/forum/showthread.php?t=65126 and following his method,
                                            I have removed the right bottom ribbon cable and the tv starts but the picture showing but not very clear and good, I attached a pic.
                                            Can anyone point me to the next step I should take? thanks!...
                                            07-09-2022, 05:03 PM
                                          • YasaCh
                                            sony kd-49xf9005 4 red blinking problem
                                            by YasaCh
                                            Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                            05-05-2025, 08:40 AM
                                          • NolesFan
                                            Sony kd-85x85j LED blinking red 6 times
                                            by NolesFan
                                            I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
                                            03-16-2025, 11:50 AM
