Sony KDL-46EX700
  • digitalshooter
    • Jul 2023
    • 24
    Sony KDL-46EX700
    Hello all, yes I am new here and appreciate any assistance in troubleshooting this TV. Picked it up from my son last night, turn it on and all you get is the blinking red 6 times light.
    I have begun looking at the Sony Troubleshooting manual that I found in a post here. Initially one would think that its the backlight but in the the troubleshooting guide page 16, it states that (6X blinking) is caused by a failure of the converter circuit. Replacement of the power supply board is necessary.
    The flowchart on page 17 indicates that it would be the GE2B board.
    So as a novice, I am sure that Sony's have known issues and regular cut to the chase malfunctions. So I am seeking any guidance into leading me to the issue with this TV. I have yet to open it and look for any obvious issues on the board, so any help would be appreciated.
    Thanks,
    ed
  • digitalshooter
    • Jul 2023
    • 24
    Re: Sony KDL-46EX700
    So here is exactly what it does. Tv turns on, Sony logo appears then disappears. Starts again, Sony logo appears, then disappears for the second time and TV then blinks 6 red lights.
      • 12276
      • U.S.
      Try a simple reset, unplug tv for 5 minutes, press and hold the power button on tv for 30 seconds, plug tv back in and try it, probably won't fix but easy enough to try, could be bad backlight/s or backlight driver. There's a few things to try there: https://automatelife.net/sony-tv-red...nking-6-times/
      • digitalshooter
        • Jul 2023
        • 24
        Thanks for your response, that was the first thing he tried. Will look at the info in the link you provided.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4463
          • Italy - Milan
          bad leds
          • lotas
            • Jan 2016
            • 4753
            • Russia
            Code error "6".
            • digitalshooter
              • Jul 2023
              • 24
              OK so 4 new led strips is what I am hearing you guys say.
              • digitalshooter
                • Jul 2023
                • 24
                SO I am this stage, can some one point me to further tear down to get to the LEDs?
                  • 12276
                  • U.S.
                  I always check all the resistors, diodes and transistors at least on top of the powerboard before tearing down, might not be your case but i have seen one resistor cause the shut down and 6 blink error, here's a guy doing your model, maybe be a little more careful with the panel than he is being tho, it's definitely not the best how to video, maybe you can find a better one, searching on youtube can be a pain: https://www.youtube.com/watch?v=I2WIbl7sm_I
                  • digitalshooter
                    • Jul 2023
                    • 24
                    • digitalshooter
                      • Jul 2023
                      • 24
                      So after replacing the 4 LED's, this is what I have now, comes on show this and goes blank. 6 blinks red light
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4463
                        • Italy - Milan
                        are you sure now 6 blinks and not 5?
                        • digitalshooter
                          • Jul 2023
                          • 24
                          Yes, Sony appears behind this half screen and goes away.
                          • digitalshooter
                            • Jul 2023
                            • 24
                            SO I had a bad flex cable connection. The screen is normal again, but TV still turns on then quickly off. I am seeing some kits on ebay that have transistors and resistor that claim should fix this kind of issue. Or I can buy a used power board with 30 day warranty shipped for less than 50.00 bucks.
                            Thoughts?
                              • 12276
                              • U.S.
                              A couple simple things to try, look over the solder joints on the powerboard and reflow any that look suspicious, look up images of bad solder joints if needed. Heat up the electrolytic capacitors with a hairdryer for a couple minutes, probably try this first, use hairdryer NOT heatgun, then try tv, don't wait til it cools down, see if it stays on longer or there is a difference, it's a test that can sometimes sniff out marginal/bad caps.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4463
                                • Italy - Milan
                                You have replaced single leds and this is the reeason, needs a certain technique to find half damaged leds, i suggest you to remove the return wire for the leds and put an 1n4007 diode in series..
                                • digitalshooter
                                  • Jul 2023
                                  • 24
                                  Will try this today, thanks!
                                  • digitalshooter
                                    • Jul 2023
                                    • 24
                                    Not sure I follow what you are saying but for clarification on my end all 4 complete strips have been replaced. Also, in the meantime after acquiring an LED tester, I have checked the original 4 strips that I removed, and the all power on completely.
                                    SO is this telling me that my efforts to replace the leds strips, were wrong to begin with?
                                    • digitalshooter
                                      • Jul 2023
                                      • 24
                                      Warmed the board, no change. Turn power switch to ECO, hear relay click, push power button: Green light comes on, Sony logo briefly appears and goes away. Cycles once again, then red light on front comes on, then blinks 6 times.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4463
                                        • Italy - Milan
                                        this is what you told:
                                        and so i answered..
                                        the persistance of 6 blinks is either bad strips or bad backlight circuit, but i guess is the first, so why don't try the same my advice?
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • James007$
                                          Sony KDL-70R550A red led blinking 5 times, troubleshooting
                                          by James007$
                                          Hey mates! my tv keeps blinking 5 time and when I turn on it doesn't show anything on screen and it turns off after a few seconds.
                                          I am having the same issue as this guy: https://www.badcaps.net/forum/showthread.php?t=65126 and following his method,
                                          I have removed the right bottom ribbon cable and the tv starts but the picture showing but not very clear and good, I attached a pic.
                                          Can anyone point me to the next step I should take? thanks!...
                                          07-09-2022, 05:03 PM
                                        • YasaCh
                                          sony kd-49xf9005 4 red blinking problem
                                          by YasaCh
                                          Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                          05-05-2025, 08:40 AM
                                        • NolesFan
                                          Sony kd-85x85j LED blinking red 6 times
                                          by NolesFan
                                          I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
                                          03-16-2025, 11:50 AM
