Philips 55PFL8008S/12 two blink error code
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Re: Philips 55PFL8008S/12 two blink error code
    Do you have such black drops on the back of the board?
    • William1967
      • Nov 2017
      • 215
      • Netherlands
      Reflowing is a short-term solution, the tin is porous and does not improve with heating. Reballing is the best solution if you want a good repair. Yes, there are motherboards that still work after a reflow after half a year, but most of them don't make it.
      • lotas
        • Jan 2016
        • 4752
        • Russia
        But before reballing, you need to carefully remove this black compound, there are small solder balls inside it and when heated, the solder melts and closes inside the components (capacitors, resistors ...).
        • Dvsr
          • Oct 2022
          • 20
          • Finland
          Thank you for the great tips!
          Do you mean that the processor would be faulty after overheating or do you mean that the cooling must be fixed too? I don't have anything to lose (except otherwise fine TV) so I think I'll go with reflowing and better cooling and try my luck. Or do you have something better idea?
          Good to know! I didn't even think about those blobs deeply. And yes I do have three of them as shown in the picture. Do you have tips how to remove that black compound? I watched some videos in which they used hot air and careful scraping to remove it.
          • lotas
            • Jan 2016
            • 4752
            • Russia
            Yes, you have to be very careful with these drops, you can damage the elements and tracks!
            • Diah
              • Feb 2013
              • 6437
              before 4-5 years.. i was out to visit friends family and was his grandma have this philips Main Soc usual BGA issue... and there nothings underhand... and i asked if this will not succeed then need to buy Boards or new TV.. she agreed.. then i used Cloth Iron she had really nice heavy with out Steam..LOL put wet cloth on the Soc. and let the Iron heat to its last degree then just put it on the cloth with out move for about 5-6 minutes.. the Tv start working... but later one year or more they told it back to same fault lol
                • 12276
                • U.S.
                #27
                Cool, a year from an iron refow, thats great, MacGyver would be envious. https://www.imdb.com/title/tt0088559/
                • Diah
                  • Feb 2013
                  • 6437
                  Necessity is the mother of invention LOL
                  • Dvsr
                    • Oct 2022
                    • 20
                    • Finland
                    #29
                    I'll try my best!
                    Good one mate!
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Originally posted by Dvsr
                      Yes, this camera is very sensitive! My camera is Guide IR PC210. I did quite a lot of research before acquiring. I found this one providing best bang for buck in a "budget" category
                      Sounds like something I should have gotten when my MSI B450 Tomahawk was still working! I think the MOSFETs failed! (or whatever they are called)
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • Dvsr
                        • Oct 2022
                        • 20
                        • Finland
                        #31
                        Decent thermal camera is expensive but crucial in some situations. It's good for monitoring slight differences in temperatures and also tracing faulty components while injecting voltage! What did you do to that motherboard? Did you try to repair it?
                        • sordids999
                          • May 2013
                          • 2161
                          #32
                          I'm trying to repair this TV totally dead D501(T2D34 diode) is showing as shorted in circuit and out
                          Zd501,zd504,zd505 shorted in circuit but out of circuit there fine so stuck on trying to trace what causing the fault any ideas
                          • William1967
                            • Nov 2017
                            • 215
                            • Netherlands
                            #33
                            Find the error on the mainboard, start the SDM and see how many times the LED flashes.
                            • sordids999
                              • May 2013
                              • 2161
                              #34
                              Found T2D34 diode is shorted and B117H is also shorted
                              Ordering B117H but can't find T2D34 diode does anyone know and alternative ?
                              • lotas
                                • Jan 2016
                                • 4752
                                • Russia
                                #35
                                And what's wrong with T2D34? It's not a simple diode, but a protective, bi-anode one, and you can't check it with a simple multimeter.
                                • lotas
                                  • Jan 2016
                                  • 4752
                                  • Russia
                                  #36
                                  Your diode belongs to the ST02D series, the exact name (voltage) depends on the marking, its marking depends on the color of the inscription on it.
                                  You can replace it with P6KE SERIES, but you need to know exactly what voltage you have.
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    #37
                                    Just and update on this post replaced T2D34 diode and B117H TV now up and running
                                    • djordje
                                      Philips 55 oled 804/12 red light blink
                                      by djordje
                                      Hello all,
                                      I have Philips Oled 55 (804/12) with black screen and red light blink.
                                      I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                      Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                      When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                      My questions is what should i do next...
                                      01-03-2025, 04:00 PM
                                    • cloo
                                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                      by cloo
                                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                      After doing a factory reset this problem was gone and the picture was back to...
                                      01-06-2025, 06:02 AM
                                    • EazyBone
                                      Un50cu7000 2 blink oddity *partially solved
                                      by EazyBone
                                      I write this to maybe help another with this TV.
                                      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                      03-18-2024, 10:24 PM
                                    • alro7779
                                      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                      by alro7779
                                      Hello, guys!
                                      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                      09-14-2025, 12:25 AM
                                    • G33RT
                                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                      by G33RT
                                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                      It does power up when pressing the power button.
                                      I already try the power button while plugin the plug with no result.
                                      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                      Could this be an PSU or eMMC issue ?
                                      07-19-2025, 03:43 AM
