Philips 55PFL8008S/12 two blink error code
  • Dvsr
    • Oct 2022
    • 15
    • Finland
    Hi. This noob needs help with this TV.
    Symptoms: TV haven't always turned on but when it has, it has been working normally. The TV was sitting in the storage for about an year and after that time for a few days it worked perfectly and turned on every time. But then it suddenly won't turn on anymore and just shows two blinks with standby light.
    I disassembled the back cover and examined the circuit boards. I didn't notice anything obvious with PCBs and components. I measured the voltage rails. In the connector that connects to logic board every voltage is present and correct. But in the connector that goes to the screen both 56.1 V rails measured only about 45 V.
    Then I looked at the boards with my thermal camera. Two spots were getting quite hot pretty fast. They can be seen in my attachments. I also marked the "hot spots" in red in the pictures. Other component is in power supply board capacitor C612 221K 1KV. I remember measuring it and it's capacitance would be fine. The other component getting hot is in the logic board under the antenna connector's shield. It seems like a some kind of SMD chip. I couldn't examine it since I haven't removed the shield. But from the hole in the shield I could measure its temperature.
    Also the processor's(?) white large heatsink was getting warm but don't know how hot the chip itself was getting.
    I'm completely amateur with TV's and repairs. I have no idea what should I do next. Any help is greatly appreciated and thanks in advance for the kind wizards who might help me!
  • Dvsr
    • Oct 2022
    • 15
    • Finland
    Re: Philips 55PFL8008S/12 two blink error code
    I have to add that earlier I didn't find the repair manual but now I found it!
    https://elektrotanya.com/philips_cha.../download.html
    • todor
      • Feb 2023
      • 16
      • България
      This chassis is very capricious. First of all, you need to rebolt the processor and then you need to overwrite the nan flash with working software. If it works, you need to improve the cooling of the processor (under the white radiator). In my opinion, the cooling is not calculated right and that's where the problems come from
      • yokoono
        • Apr 2010
        • 486
        That capacitor creates big problems in the Philips power supply. DO NOT START AGAIN. Replace the capacitor with another one of 2Kv.
          • 12187
          • U.S.
          maybe try switching out the ceramic cap for one of those, see if it helps: https://www.ebay.com/sch/i.html?_fro...fLoc=2&_sop=15
            • 12187
            • U.S.
            ok, Yokoono beat me to post, lol.
            • Dvsr
              • Oct 2022
              • 15
              • Finland
              Thanks for quick replies!
              I'm sorry but have to ask what do you mean by rebolting the processor? Do you mean reflowing? I have no idea how to overwrite nan flash Can you give some information or guide me towards instructions?
              • Dvsr
                • Oct 2022
                • 15
                • Finland
                Thank you both! I'm going to buy and replace that capacitor first. I contacted the local electronics store and ordered 220 pF 2 kV one. If I'm lucky it might arrive this week. I will inform you after changing the cap and testing the power supply!
                  • 12187
                  • U.S.
                  I usually order a few of them in case anything goes wrong.
                    • 12187
                    • U.S.
                    Those lit up very well, which thermal camera do you have?
                    • Dvsr
                      • Oct 2022
                      • 15
                      • Finland
                      Same for me. I think they will order at least ten of those so they'll have them in stock too. I'll take few of them.
                      Yes, this camera is very sensitive! My camera is Guide IR PC210. I did quite a lot of research before acquiring. I found this one providing best bang for buck in a "budget" category (compared to professional cameras). I also have a macro lens so it can also be used to examine SMD components for example.
                        • 12187
                        • U.S.
                        ok, yes looks like a very capable camera, thanks.
                        • Dvsr
                          • Oct 2022
                          • 15
                          • Finland
                          I received the caps and replaced the original 221 pF 1 kV with 221 pF 2 kV. I then connected all the connectors. When I plugged the TV in I noticed that things got worse. Almost instantly when I only plug the power cord the capacitors temperature starts to rise rapidly. But this time it goes up to over 90 °C... With the original cap it heated up to only about 60 °C.
                          And now the TV won't even start to show that error code.
                          I'm completely clueless what to do next.
                          • Diah
                            • Feb 2013
                            • 6368
                            put back yours original 22iPF in place.. and rework soldering on the wholw back side... in case you don't have good magnifier to scope soldering points
                            • Maalobs
                              • Jun 2016
                              • 120
                              • Sweden
                              You might be following a red herring; the TV set is helpfully providing you an error code so why not investigate that clue instead.
                              The repeating two blinks means that you have a layer-1 error code 2.
                              If you take a look in table 5-2 in the service manual, you will see that they are all related to the system board ("SSB"):
                              This old model TV has a hardware SDM feature (see section 5.2.1 and figure 5-1), where you can force the TV to blink the more specific layer-2 error code by soldering a jumper wire from the SDM point to the nearest GND point on the system board:
                              When that's done, connect the mains power again and wait for the blinking to begin.
                              It can take several minutes before the blinking begins if the underlying problem is a fall to protection mode as described in the flowcharts in section 5.3, because the device will cycle through several reboot attempts before finally giving up and entering the protection mode, so just wait patiently.
                              The two digits of the layer-2 code will blink at two different speeds followed by a longer delay, then the two digits will repeat.
                              Another feature of the SDM mode is that it overrides the protection mode behaviour where most of the power rails are disabled.
                              Having SDM enabled leaves all power rails enabled while in protection mode, so they can all be measured correctly.
                              The most likely outcome is that you will get layer-2 error code 53, it's unfortunately a design error in this chassis, be it deliberate or accidental.
                              The main processor's heatsink is woefully undersized, which results in the BGA-type processor to heatwarp the PCB and over time some of the underlying pads on the PCB will disconnect from the processor.
                              The solution for this is two-fold:
                              1. The Fusion processor needs to be reflowed in the correct manner to regain contact with all the pads again.
                              2. The heatsink needs to be replaced with something bigger (it's a common form factor), and you need to make a ventilation hole in the plastic back chassis where the processor is located, as pioneered by Alpengeist, and you can see several successful examples of that here.
                              If you only reflow the processor and don't solve the underlying cause of the heatwarping, you will eventually end up in the same situation again, like this poor guy.
                              But you might have some other layer-2 error, so investigate it and let us know.
                              • Dvsr
                                • Oct 2022
                                • 15
                                • Finland
                                I will check them out and put the old cap in if I only find it.
                                Thanks for the thorough guiding! Sad to see that kind of flaws. I will try to get out more accurate error code. Lets see what happens.
                                • Dvsr
                                  • Oct 2022
                                  • 15
                                  • Finland
                                  I changed the old capacitor back and connected SDM to ground with a jumper wire. After waiting for a while the blinking started. And it was five short blinks and three fast ones. So you were right. While the TV was powered I measured voltages of the L_CA and R_CA pins in the connector which goes to the backlight(?) and it was still around 45 volts.
                                  Great thing that the faulty part was confirmed! But reflowing the processor is complicated thing for me. I have never reflown any chips especially this size. I only know the basics of that process. Any advice on that is greatly appreciated.
                                  I have Yihua 853AAA (in the picture) but don't know if I would need better equipment for even trying to reflow the processor.
                                  I have to also ask from the local hacklab if there happens to be someone who is experienced with this kind of stuff.
                                    • 12187
                                    • U.S.
                                    Maalobs nailed it.
                                    • Maalobs
                                      • Jun 2016
                                      • 120
                                      • Sweden
                                      If you don't want to risk it yourself, look for local repair shops for Playstations and things like that, bring the systemboard to one of those places and ask them to reflow the BGA chip for you.
                                      Once that has been taken care of, there is yet another issue you might have to look into.
                                      The Linux system on this board has not been properly configured to minimize write-cycles to the NAND storage.
                                      That means that the NAND could be very dodgy by now.
                                      You can find out how bad it is by recording the boot log from the system, and you can do that by hooking up the RXD and GND of a 3.3V TTL-adapter to these pads on the unpopulated debug port 1CV5:
                                      TXD-SERVICE on pin 8 is the output from the MIPS Fusion processor, that's the interesting one.
                                      It transmits at 115200 bps.
                                      TXD-STANDBY on pin 2 is the output from the 8051 standby microcontroller, which is actually located in the same big chip.
                                      It transmits at 57600 bps.
                                      You need a USB-to-TTL adapter, here's a couple of options in Perkele land:
                                      https://www.partco.fi/fi/raspberry-p...42-ada954.html
                                      http://robomaa.fi/usb-to-ttl-serial-...Serial%20Cable
                                      The Adafruit one is 100% legit, the other one maybe, the problem is that adapters at half the price of the Adafruit have the pirated chip that doesn't work with the signed Windows drivers, so you can only use the cheap pirated adapters with Linux.
                                      On the computer the adapter shows up as a normal COM-port and you just use any free serial terminal program against it.
                                      Get yourself a set of these while you're at it, it will make things much easier, and the whole kit is quite useful for other things too if you are the curious kind:
                                      http://robomaa.fi/ic-hook-with-pigtail
                                      Anyway, with that in place and the processor properly reflowed so it successfully boots, you can record what's generated to the boot log from the moment you plug mains power into the TV.
                                      The output will show any issues that the standby POST and the Linux system can identify.
                                      The number of lines with mention of "fixable bit-flip" is the number of bit errors in the NAND-chip, you can see here for a reference.
                                      It's probably bad and you can start looking for used replacements for the NAND on Aliexpress, which have been stripped from recycled electronics.
                                      Ask the hacklab if they have a flash programmer that supports NAND and EMMC, and if they have a TSOP48 socket adapter for it.
                                      Or you can just forget about dealing with the NAND and decide that it will constitute the natural life span of this TV.
                                      But you must deal with the cooling after the reflow, look for a matching northbridge heatsink on your old PC motherboards.
                                      • Dvsr
                                        • Oct 2022
                                        • 15
                                        • Finland
                                        Wow. You are a genius! And thank you so much for taking your time to write all that and help me! I really appreciate it.
                                        Your instructions are very clear. I will try to fix the tv but it will take some time.
                                        I try to find someone who is more experienced with reflowing. And if I don't find one near me or with reasonable price I will have to try it myself. I'm going to learn that skill anyway but this project is a bit pricey to be my practice item.
                                        • djordje
                                          Philips 55 oled 804/12 red light blink
                                          by djordje
                                          Hello all,
                                          I have Philips Oled 55 (804/12) with black screen and red light blink.
                                          I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                          Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                          When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                          My questions is what should i do next...
                                          01-03-2025, 04:00 PM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • EazyBone
                                          Un50cu7000 2 blink oddity *partially solved
                                          by EazyBone
                                          I write this to maybe help another with this TV.
                                          So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                          The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                          03-18-2024, 10:24 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
