Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4610
    • Russia
    #61
    Originally posted by zaratustrax
    Thanks a lot for your reply.
    I made a terrible mistake. You are right, the ic is different. And I could find the correct one.
    I attached the file, please clean my bin archive.
    Thanks again for your help and guidence
    Your dump is fine, working, so the problem is somewhere else, maybe the panel.
    • zaratustrax
      • Aug 2015
      • 9
      • mexico
      #62
      First at all Thanks for taking the time and check my file.
      As you said the problem is some where else. I was looking for and I discovered that the problem is on the panel side.
      I made a trick, I dissabled the Tcon protection which detetcs if the panel is connected to the Main board. So I could discovered where the problem was. And it is on the left side.
      This tv has two boards in which are Soldered the cofs. So we have a 'board-cof' left and right. And also each one is divided in two board connected through a Coffee color flex.
      I cheked this part and I couldnt find any Short or low resistente, I also try to dissabled the board in which the problem is cutting the ckv lines and covering with tape the voltages lines.
      At this point I am stuck. I am wondering if the problem are the cofs or this side of the panel is broken or something.
      Could you please tell me another way to 'turn off' or dissable this part of the panel in which the problem is?
      Again, Thanks a lot for your help
      • lotas
        • Jan 2016
        • 4610
        • Russia
        #63
        Initially, you posted a dump from T-con IC1603 25Q80, was it native to this TV or did you already record someone else’s dump into it?
        • zaratustrax
          zaratustrax commented
          Editing a comment
          It was native from my tv
      • srdi
        • Jan 2024
        • 5
        • Ukraine
        #64
        The TV does not turn on, there is no standby mode! SAMSUNG UE40MU6402
        • lotas
          • Jan 2016
          • 4610
          • Russia
          #65
          Try.
          • srdi
            • Jan 2024
            • 5
            • Ukraine
            #66
            Originally posted by lotas
            Try.
            Thank you very much!! Everything is working!
            • edukojak
              • Brasil
              #67
              Hello friends. I'm new here and I noticed that everyone helps each other. I'm from Brazil and I'm looking for the bios for the Samsung 50 MU6100G BN41 02568A BN49 12418K TV. Does anyone have this?
              • lotas
                • Jan 2016
                • 4610
                • Russia
                #68
                Other people's dumps won't help you, post your non-working dump here, I'll fix it for you.
                • edukojak
                  • Brasil
                  #69
                  ok friend thank you very much I will do that
                  • murtagh
                    • Feb 2014
                    • 9
                    • Ireland
                    #70
                    Hi Lotas ,can you fix this file please. I have used some of your files before and they worked ,thank you. Samsung UE49MU6500 BN41-02568 ic1604.
                    Murtagh,
                    Ireland.
                    • lotas
                      • Jan 2016
                      • 4610
                      • Russia
                      #71
                      Murtagh,
                      Ireland.
                      Hi, try.
                      • murtagh
                        • Feb 2014
                        • 9
                        • Ireland
                        #72
                        Hi Lotas, this file worked perfectly. You are truly a Legend.
                        Many Thanks.
                        Murtagh.
                        Ireland.
                        • lotas
                          • Jan 2016
                          • 4610
                          • Russia
                          #73
                          Many Thanks.
                          Murtagh.
                          Ireland.
                          Hello! Thank you!
                          • a_lik
                            • Feb 2019
                            • 7
                            • Indonesia
                            #74
                            Hi Lotas ,can you fix this file please. I have no standby light ,thank you. Samsung UA55JU6000K BN94-09309Z​
                            • lotas
                              • Jan 2016
                              • 4610
                              • Russia
                              #75
                              The problem is not inclusion here in the xxMUxxxx series, you have a completely different chassis.
                              • a_lik
                                • Feb 2019
                                • 7
                                • Indonesia
                                #76
                                i'm sorry my bad, i'll go to "eeprom dump thread. thx
                                • hazi12
                                  • Jun 2015
                                  • 8
                                  • Czech Republic
                                  #77
                                  Hi, is it possible to fix 25Q40CL listing in ASprogrammer , but I don't have CH341A I only have RT809F and there is no option to select hardware? Thank you.
                                    • 20966
                                    ASprogrammer software only works with the CH341A ,it is not meant to work with the RT809F. The RT809F is a good programmer, chip support can be added manually if the chip is not in the latest support list.
                                    • lotas
                                      • Jan 2016
                                      • 4610
                                      • Russia
                                      #79
                                      Everything is there and it (RT809F) supports it!
                                      • hazi12
                                        • Jun 2015
                                        • 8
                                        • Czech Republic
                                        #80
                                        I've tried unchecking the protection, unchecking all the boxes and then I want to write and then I want to delete and it writes an error, it can neither delete nor write, there is still protection probably on.
                                          09-07-2024, 05:50 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • totof
                                          Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                          by totof
                                          Could you help me...
                                          I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                          Then motherboard connected, standby led is on and current consuption is 18W.
                                          Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                          Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                          The model of my TV is :
                                          Power supply BN44-00807A
                                          Main Board BN41-02568B / BN94-12765W
                                          Panel CY-GM055HGLV3H...
                                          05-01-2023, 04:30 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • jeangonbay
                                          Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                          by jeangonbay
                                          Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                          The model of my TV is UE43MU6105K
                                          Main Board: BN41-02568B
                                          BN94-12007Y
                                          Could you help me to repair the dump please. Thank you.
                                          02-16-2024, 05:46 AM
