Sony XBR-65X900E 4 Blink Code
    • 12306
    • U.S.
    Re: Sony XBR-65X900E 4 Blink Code
    if you have a multimeter and want to test it, test voltages at cn6401, what is the voltage of bl-error and list any others that do not match the map/legend next to it.
      • 12306
      • U.S.
      testing procedure there if needed, as always be very careful what you touch on the powerboard, there is some potentially DEADLY voltage on the hot/primary side: https://www.youtube.com/watch?v=XH9GfkGQX1I
      • my2k2zx2
        • Jan 2023
        • 20
        I unhooked the boards and do not see any failed capacitors or burn marks anywhere. Plugging the boards back in did not change anything, still 4 red flashes.
        CN6401 voltage all seem to match the legend when the tv is powering on.
        bl_err is at 0.028v when the tv is powering on, but then goes to 0.003v when the red light flashing 4 times.
          • 12306
          • U.S.
          ok, so the backlight error is very low, I think that is ok, now maybe check that you have voltage leaving the led driver board and going into the mainboard.
            • 12306
            • U.S.
            can also test those little mlc caps on the ld/led driver board, see if any test short, can put a probe on each end or put neg. probe on chassis ground and pos. probe on each end, one side will have continuity, beep if you have a meter that beeps and the other side will show a reading or not beep if ok.
            • my2k2zx2
              • Jan 2023
              • 20
              Where would I check for the led driver voltage? I only see a flat ribbon connecting it to the main board.
              No shorts on the capacitors on the led board.
                • 12306
                • U.S.
                #27
                Storytell12 do you remember what your bl-error voltage was?
                  • 12306
                  • U.S.
                  #28
                  ok, I see yours is a little different than my 900C, mine has an additional board inbetween the powerboard and the led driver board.
                    • 12306
                    • U.S.
                    #29
                    try unhook cable from powerboard to led driver board leave it off, then plug tv into power and try it, see if you still have the 4 blinks.
                    • my2k2zx2
                      • Jan 2023
                      • 20
                      yup, still 4 red blinks with that cable disconnected.
                        • 12306
                        • U.S.
                        #31
                        ok, I watched a Nick's video, he says that could be a mainboard issue.
                          • 12306
                          • U.S.
                          #32
                          check all the little mlc capacitors on the mainboard, none should read short.
                          • my2k2zx2
                            • Jan 2023
                            • 20
                            The part 2R2 and the cap to the right of it beep to ground on both sides on my multimeter.
                            Everything else on the mainboard only beeps on one side.
                              • 12306
                              • U.S.
                              #34
                              ok, I think you have found the problem, I'm no expert, some may have better advice, I think I would take the cap off and see if it reads short out of circuit.
                              • lotas
                                • Jan 2016
                                • 4803
                                • Russia
                                #35
                                You have a short circuit on this capacitor or just a low resistance (how many Om?) And if it were short, the F4000 (3A) fuse would blow.
                                  • 12306
                                  • U.S.
                                  #36
                                  forgot to mention to have the other boards disconnected from mainboard while testing those caps so its isolated and no potential errors are coming from the other boards.
                                  • my2k2zx2
                                    • Jan 2023
                                    • 20
                                    2R2 is 4 ohm on one side, OL on the other.
                                    the little cap is 4 ohm on one side and 0.4 ohm on the other.
                                    The main board is not connected to anything.
                                      • 12306
                                      • U.S.
                                      #38
                                      yep, that 4 ohms seems way low, probably something making it read that way, is that fuse ok? the fuses are tiny on my board, there's probably a few on the board, check it for continuity, a fuse that reads short is a good fuse.
                                      • lotas
                                        • Jan 2016
                                        • 4803
                                        • Russia
                                        #39
                                        2R2 is a coil (inductor) it should show the same resistance on both sides.
                                        • my2k2zx2
                                          • Jan 2023
                                          • 20
                                          the part by the F4000 wording does not beep when I put the probes on both sides of it.
                                          I guess I thought that was a capacitor since it only beeped to ground on one side.
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            07-18-2025, 12:53 PM
                                          • x_orange90_x
                                            Sony KD-75X750H no backlights
                                            by x_orange90_x
                                            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                            07-16-2025, 07:49 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
