Dc power supply in cnc not working
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    #61
    Re: Dc power supply in cnc not working
    and it makes me mad too becasue i screwed up...and now i have to replace a high quality component with crap made in china
    i put the wires off to the side pos to one side and neg to to other side so that when i hook bnoard back up i just hook up terminals accordingly...but since i have been working on this machine for a few days the wires got moved around by accident and when i went there today to hook the board back up ...BOOM!!!!!
    this cnc machine is ...was entirely made in USA even all the electronics
    oh well
    • shelby5041
      • Feb 2009
      • 1505
      #62
      would it be ok to get a cap with diff uf value or do i need to stick with 4800uf? i know i can get higher voltage if better availability
      • CapLeaker
        Leaking Member
        • 8155
        Mallroy = Cornell Dubilier - CDE
        you find them on digi or mouser. Probably $40 or so.
        • shelby5041
          • Feb 2009
          • 1505
          #64
          awesome thanks i found them at mouser $40 plus shipping
          quite costly but thats what i get for screwing up
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Where's pictures of capacitor gore!
            • shelby5041
              • Feb 2009
              • 1505
              #66
              hi
              i dont know
              i posted photo yesterday and it showed up and then now its gone
              will have to see if i can post anohter day as the photo is not on my pc
              one question though...this capacitor is about $40 new...if i can find a used one for real cheap under $10 would it be worth buying?
              as i said i wont be using this machine much at all ..maybe once in a great while....to me a good working used one wold be ok..just wanted some input from pros
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #67
                $28 on this one, I'm not sure where the free shipping kicks in for US customer but I believe it is not that much higher?
                https://www2.mouser.com/ProductDetai...BL%252BQXG1g==
                • shelby5041
                  • Feb 2009
                  • 1505
                  #68
                  hi hanson
                  i saw that one but its wrong dimensional size and would require some modifying which i dont want to do
                  i need 22mm screw holes spacing and 2in diameter
                  mouser shipping is $9 extra
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #69
                    How about this then? Quite cheap too.
                    https://www.mouser.com/ProductDetail...5aE5RRng%3D%3D
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      I don't understand this quote on mouser's website: "Quantities greater than 33 will be subject to minimum order requirements."
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #71
                        hi hanson
                        its a bit lower than 4800uf but im sure it would be ok considering the application
                        but it may be too tall not sure..original is 80mm tall
                        its possible it would fit..i may have to do some measuring..i have restrictions on height and diameter due to where its located unless as i said i do some modifyng which im not wanting to do
                        thanks
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #72
                          They have 33 in stock, I think it means if you order more than 33 the additional ones you will not get the lower break prices on.
                          • redwire
                            • 3910
                            I would bite the bullet and get the $40 part because newer or cheaper parts are smaller and will not fit the PC board 22mm screw spacings.
                            Cornell Dubilier - CDE CGS482U075V3C 4,800uF 75VDC $39 at Mouser
                            I don't see the high current path from the cap (+) to the load. Would need more board pictures to see where the voltage loss is occurring. There might be a fuse, open-connection etc. which is what I'd be looking for.
                            The LM338 would be OK if the output measures 5VDC for the logic circuits. They might act as the master switch for the 42VDC, if there is a relay or something.
                            So far I don't see any 42VDC regulator and it could be unregulated if powering high current solenoids etc.
                            • shelby5041
                              • Feb 2009
                              • 1505
                              #74
                              Hi redwine
                              I didnt want to spend 50$ total inc shipping....however i did get lucky and found exact part number on ebay used
                              I typicslly eould never buy a used cap but sibce this one is so costly new i made an exception
                              I only paid $7.50 snd free ship... i wanted to buy this new one but its 1in taller..wouldnt fit https://www.ebay.com/itm/14409611372....c100167.m2940
                              It was the only one on ebay that matched part number and made in USA
                              Plus ...there is risk that the ps could be bad...so spending 50$ on a non returnable item could be 50$ out the window
                              And also no fuses in circuit....i measured 44v at big cap so the issue would be the lm338 or a diode in citcuit since thats all thats in between cap and output ....my only concern is if the lm338 is bad if some other component blew the lm338...will see what happens when i get the cap and lm338...both ordered
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #75
                                Here are pics redwine
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #76
                                  Am i right to assume a mallory/cornell made in usa capscitor is as good or better quality .........as compared to made in china versions? And surprisingly the mallory csp is only rated for 2000hrs ....can they last longer than 2000hrs?..i would have thought it would be 5000 or maybe 10000 hour rated.
                                    • Jul 2011
                                    • 6039
                                    They can those ratings are based on using at the rated voltage maximum and at maximum temperature rating if used with in the normal range rating it should last a lot longer
                                      • 31020
                                      the rated hours is at maximum temperature, voltage and ripple.
                                      it's a minimum life.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Those are lifes at the rated temperature. Life of capacitors are significantly improved if you keep them cool, the rule of thumb is double life each time you keep them 10°C cooler. Note that capacitors generate heat.
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #80
                                          Great info thanks...i think my decision to buy the used cap should be fine for my situation...there is a nice 4in 12v cooling fan inside the enclosure so that should keep the cap a bit cooler than normal
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • CMCM
                                            Russound CA4 Power Supply Repair
                                            by CMCM
                                            Hello Everybody,
                                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                            The outputs marked 12v and 20v are all measuring only 1v.
                                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                            The capacitors physically look clean (no bludgesor leaks) and...
                                            07-03-2025, 01:12 PM
