Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
  • Gust zhang
    • Feb 2025
    • china
    ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem emerged. This MBP originally came with an 85W MagSafe 2 power supply. When the CPU runs at full speed and under heavy load, the MBP will power off and restart. It should be that the 85W power is not enough for the MBP, which is also why Apple limited the speed when there is no battery. But I don't want to buy another battery, even though it's very cheap in China. I want to buy a high - power adjustable voltage power supply and directly weld the positive and negative poles of the power supply to the motherboard. However, I'm not sure if the MBP can work normally after direct welding, and I haven't figured out where to make the connections. I downloaded the circuit diagram from badcaps. I want to connect the positive pole of a 20 - volt 8 - amp power supply to PP20V_DCIN_FUSE and the negative pole to GND. Can any master who repairs MBPs answer me?
  • FriedFred
    • May 2024
    • 143
    This is a possible solution, yes.
    You can try first with a current-adjustable voltage supply and use a very little current, let's say 200mA. If all is nice, you can raise the maximum allowed current slowly until the device is fully working. Then you know it's possible and you know the needed current.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • imran333
      Got 65QN95A one connect box power supply that’s faulty and clicking
      by imran333
      Got this one connect box 65QN95B and power supply is faulty and it’s faintly constantly clicking, the voltage that says standby 7.6v is not stable and going up and down, IC labelled 6b22 is getting very hot which normally fails on Samsungs but even after replacing it still same getting hot, the 4 resistors in the picture also getting hot but all read ok in circuit and out of circuit, them are the components getting very hot but not actually faulty and no short circuit anywhere and fuses ok, kind of stuck where to check next, I’ve included pictures of board and parts getting hot, all parts...
      10-29-2026, 02:06 PM
    • shadow666
      How can i connect type c cable to 19v power supply
      by shadow666
      hello
      i have a power supply adjustment like image
      i want turn on asus vivobook with type c charger
      i want a connect type c cable to power supply adjustment but type c cable have 3 wire and i don,t know how to connect the cable type c to power supply adjustment
      please help me to let me know
      sorry English is not my first language...
      12-23-2023, 03:32 AM
    • Sacajuoy
      Samsung UE46C6735 turns off intermittently - power supply unit PD46AF1 (BN44-00357B) real fault.
      by Sacajuoy
      I've had this Samsung UE46C6735 for many years now and Samsung early on replaced the power supply under warranty explaining that there were design flaws as well as bad capacitors. I worked in electronics design industry at the time and was well aware of the bad capacitor situation.
      Now, the TV worked flawlessly for many many years but in recent years it developed a habit of turning on and off and in the last week it never turned on properly, just blinked on for a short moment and I could hear relay clicking for every try to turn on. At first I was looking for a new TV so on the day...
      09-12-2026, 12:18 PM
