Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
  • Gust zhang
    • Feb 2025
    • china
    ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem emerged. This MBP originally came with an 85W MagSafe 2 power supply. When the CPU runs at full speed and under heavy load, the MBP will power off and restart. It should be that the 85W power is not enough for the MBP, which is also why Apple limited the speed when there is no battery. But I don't want to buy another battery, even though it's very cheap in China. I want to buy a high - power adjustable voltage power supply and directly weld the positive and negative poles of the power supply to the motherboard. However, I'm not sure if the MBP can work normally after direct welding, and I haven't figured out where to make the connections. I downloaded the circuit diagram from badcaps. I want to connect the positive pole of a 20 - volt 8 - amp power supply to PP20V_DCIN_FUSE and the negative pole to GND. Can any master who repairs MBPs answer me?
  • FriedFred
    • May 2024
    • 140
    This is a possible solution, yes.
    You can try first with a current-adjustable voltage supply and use a very little current, let's say 200mA. If all is nice, you can raise the maximum allowed current slowly until the device is fully working. Then you know it's possible and you know the needed current.
