Powering up a Car Antenna a "different" way
Re: Powering up a Car Antenna a "different" way
First use a felt pen and put some dots/stripes 1,2,3,4 on the blue wires, so they don't get mixed up.
I think this is right:
Swap the two wires at the motor's terminals. (D2 and B2)
Swap the two wires at the limit switch, the two that go to the relay board. You can do this at the switch end (A2 and C2) or at the relay board end (A1 and C1), whatever is easiest to solder.
This will make it default to antenna UP instead of antenna DOWN.
To understand common relay pin names, such as COM, N/C, N/O check out the relay's datasheet, part number is L-12VDC-S-2Z.Comment
i swapped D2 and B2 (the wires to the terminals of the motor).
I swapped A1 and C1 on the printed circuit board.
I connected black wire to neg terminal
I connected red wire to postitive terminal
Results: Nothing happened. I touched green wire to both the black and red and notheirng happened...nothing moved.
So i swapped red and black on the battery.
I connected black wire to positive terminal
I connected red wire to negative terminal
Results: AS soon as last wire was connected antenna "moved out or up".
Which is good right. But no way to get it to come back in or down...........i could not get antenna to come back into its housing.Comment
ok, i just realized something.........in an earlier post someone said something about just switching the black and red wires..........which i did.............i forgot to change them back to their original positions on the printed circuit board let me do this and then get backto you all.
sorry about that.Comment
ok so here is what i found out.
Antenna moving out/up:
Connect Red wire to positive lead of battery
Connect Black wire to negative lead of battery
As soon as this is done antenna begins to move out or up.
But touching green wire to either black or red does not seem to do anything.
Antenna moving in/down:
Connect Black wire to positive lead of battery
Connect Red wire to negative lead of battery
As soon as this is done antenna begins to move in or down.
Did i kill the relay or something?Comment
In the diagram, common1 and common2 are the common point of one of the two relay contacts
the relay is a DPDT relay (google it) when there is no voltage applied to the coil, the N/C normally closed contacts are connected to the common, and the N/O normally open contacts are...open. when the relay is energized (voltage across the coil) the common will be connected to the N/O contacts and the N/C contacts between common will be opened.
The relay coil should measure aprox 270Ω
A 9 volt battery won't kill the relay.
In the picture, with battery negative on pin 5, the green wire needs to be connected to positive to activate. If you had the positive of the battery connected to pin5 the green wire would need to be connected to battery negative to activate. That's itLast edited by R_J; 12-06-2019, 07:39 PM.Comment
R_J, Read your comments....will read again to make sure i understand. Basically your saying relay oil needs positive voltage difference across it to energize it ......right.
What about all the other connections........how do i connect those to get the desired result....if you know.
thanks to all.Comment
When you connect the battery (nothing on green relay coil wire) , the antenna should (now) move down and then stop, as it goes past the limit switch which disconnects the motor.
Instead, it's not doing that - it stops but you can reverse battery polarity and it moves in the reverse direction up. So it hasn't fully hit the limit switch (down) end.
I'd say your 9V battery is getting weak or is just too whimpy for this motor.
Between green and black 9V should always make the relay click, note it is undervoltaged with less than 9V but a 12V coil, so it might not always pull in.Comment
GREAT NEWS!!!!!!!!!!!!!!!!!
Dont ask me why but i got rid of the 9v battery setup and went to a 12V battery setup. I did this because of something someone mentioned in one of the replies to one of my questions.........anyway, when i do this............IT WORKS as my friend wanted.
When i connect the red to +12V and the black to ground.........if the antenna is not up it goes up ......if already up then does nothing. If antenna all the way up and i now take green wire and connect it to the red wire then the antenna goes down...............
thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!Comment
by ZibboLenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals. -
by HondamanRecently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
Years ago I made a "T"... -
by ChaksTAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
The specs says ...
High antenna efficiency 868MHz ISM Band
5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
1. Should I Fix it with a glue.
2. Should I fix it with a double side adhesive tape
3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...12-09-2024, 11:06 AM -
by SolomonManAll,
I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
Since we moved in, 8 years ago,... -
by wnlewisOK. I got the rocker switch figured out thanks to the good advice on this forum.
Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
This is a Whirlpool RDE3340 electric range.
The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
Where may I find parts... - Loading...
