Single-channel antenna?
  • Hondaman
    • Sep 2008
    • 1088
    Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
    I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
    Years ago I made a "T" shaped antenna for RF channel 11, where the top of the "T" was 37.65 centimeters, a "quarter-wave" antenna. Worked well but it had to be pointed PRECISELY perpendicular to the transmitter or the signal would drop off SHARPLY. So when I made the Gray-Hoverman and the "T" for 199/200 MHz (WHAS, Louisville KY) I made it 75 cm (half-wave, 29 inches). It was MUCH more robust when turned a little, but of course I kept it pointed DIRECTLY at the tower anyway.
    Now that I have the store-bought antenna, I am getting a DREADFUL (basically zero) signal on RF channel 8 (180-186 MHz here in the US). I thought I'd make a "T" shaped antenna with exact dimensions. so for 183 MHz, the top of the "T" should be 1.6382 meters.
    If I use equal length coaxial cables again, and I get bad results, I can always remove the "T", use the store-bought antenna by itself, and just never watch WBNA 21 (RF channel 8).
    Can I make the top of the "T" double the length? 3.2764 meters? Any ideas?
    Any thoughts greatly appreciated.
  • Hondaman
    • Sep 2008
    • 1088
    Okay. I tried several different combinations of one antenna and two antennas. I did keep in mind that a two-antenna setup requires EQUAL length coaxial cables going from the antenna to the combiner. I was thinking about posting every single result, but now I think that would be boring.
    NOTE: There are some errors in the post above. One station in my town is at 181-186 MHz (RF channel 8), and another station is at 199-204 MHz (RF channel 11).
    CONCLUSION: Basically, combining two antennae up in my attic always gave me worse results than one antenna by itself. The Antennas Direct Clear Stream 4 MAX (from my local Best Buy) gives the best results, when used by itself. It is pointed at the towers on Knob Creek Hill (4.2 miles away), outside of New Albany, Indiana. The "T" shaped antenna works well for the 180-184 MHz station when placed in my living room, but HORRIBLY in my attic (USA asphalt roof shingles versus living room window). I don't want to use a 5-foot or 10-foot "T" antenna, fastened to a piece of lumber, one meter off the floor in my living room, just to enjoy one station. The 180-184 MHz station put their antenna down by the Louisville, KY airport, further complicating matters. And the station is owned by a church, which probably will never have the money to move their transmitter up on the hill with the rest of the transmitters. Besides, last week I bought a ROKU ULTRA (11th generation), and I have fiberoptic internet. So free stuff on Roku, delivered through the internet, will easily make up for the 180-184 MHz station that I really could never receive very well anyway.
    I might be able to do better if I put the Clear Stream MAX 4 on my chimney, but I don't wish to figure out how to get the coaxial cable in from the roof. What I have is the best solution I can have with an antenna in my attic (one-story ranch home). Combined with the ROKU Ultra and a large DVD collection, I have quite a bit of free entertainment now.
    And if you combine two antennae, you will likely have poor results unless you are an amateur (or professional) radio or TV engineer.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8325
      Overseas they had multiple antennas on the roof. You get cables easily inside with a rubber boot, a pipe and a weather head. That’s what I got.
      Back to the antennas… they were single channel antennas, fed with 75ohm coax, on the bottom of the mast / pipe was a multi channel amplifier and a combiner splitter so all the channels (9) were available to watch in bedrooms, living room, basement living room etc.
      • Hondaman
        • Sep 2008
        • 1088
        My previous post is the one I wanted to end with, but now there is an update. The 12-inch coaxial cable from my wall to the splitter has a problem. One end wishes to come apart easily. When I pulled the cable out of the wall connector to install a "5G filter" last week, the end of the coax came apart. When I jam the connector back together, or use another 12-inch piece of coaxial cable, the weak station (180-185 MHz with the antenna down by the Louisville, KY airport) is now fairly strong.
        (The splitter sends one signal to the "Zapperbox" ATSC 3.0 device, and the other to the Toshiba D-R550 DVR unit, which then sends it to my Toshiba 39.4-inch television.)
        Was the cable FIRMLY plugged into the wall for the last 10 years? Was the cable loose and causing problems for the last 10 years? Did it come loose AFTER I experimented with different antennae in my attic a few weeks ago? We will never know. But the Antennas Direct "ClearStream Max 4" is good. I did NOT get $30 off at Best Buy, which was advertised. Perhaps the lower price was an internet-only price. But I have good results and the project is finished.
        And last month I bought a ROKU device. You cannot go to roku dot com and watch programming like going to youtube dot com. But with the Roku device, Roku delivers lots of free programming, with commercial advertising, through my high-speed internet. And I can use it to sign up for other streaming services ("Peacock", "Paramount Plus", etc) available here in the US.
        (If Roku is built in to your television, it is often cheap a Wal-Mart television that fails quickly. My stand-alone Roku is about as large as 2 packs of cigarettes lying next to each other, and sends programming to the HDMI port of my 18 year old "dumb" TV.)
        Thank you for your time and attention !
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • spleenharvester
          Reverse engineering of 18650 4-channel tester
          by spleenharvester
          Hi friends
          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
          05-04-2025, 02:43 AM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
        • Chaks
          Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
          by Chaks
          TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
          The specs says ...
          High antenna efficiency 868MHz ISM Band
          5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
          The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
          1. Should I Fix it with a glue.
          2. Should I fix it with a double side adhesive tape
          3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
          12-09-2024, 11:06 AM
        • dicky96
          American Audio VLP1500 Distorting on one channel
          by dicky96
          Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
          Protection and Clip LED are off
          There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
          I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
          The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
          07-13-2022, 05:25 AM
