Lenovo T470P NM-B071P not charging, 20 volts on positive +ve battery terminal
  • Zibbo
    • Mar 2017
    • 204
    • Zimbabwe
    Lenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
    Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals.
  • mon2
    • 14675
    The high side battery charge or the battery enable MOSFET must be leaking. This leak is supplying the main power rail voltage unregulated onto the battery terminal. Remove all power. Measure the resistance across the MOSFET pins to confirm. If the resistance is not hundreds of k ohms, part may be defective.
    • Zibbo
      • Mar 2017
      • 204
      • Zimbabwe
      Thanks but I have already replaced the high side mosfet PQ101
      • mon2
        • 14675
        Review if PD7 is leaking.
        PQ10 ok?
        • Zibbo
          • Mar 2017
          • 204
          • Zimbabwe
          PQ10 ok?
          Both tested ok, I have also replaced them just to be sure.
          Edit: Thank you mon2 for your assistance, it was my fault. I had replaced PQ11 with a P-Channel mosfet instead of N-Channel. Sorry for wasting your time.
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • kjchatman
            asus tuf506IV gaming laptop with 19 volts on battery terminal
            by kjchatman
            i'm charging an asus laptop that i just repaired and i'm measuring 19v on the battery terminal with the charging connected. Is this normal? the battery is rated at 15.4v...
            07-03-2024, 01:51 PM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
