Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
  • Chaks
    • Sep 2015
    • 115
    • India
    TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
    The specs says ...
    High antenna efficiency 868MHz ISM Band
    5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
    The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
    1. Should I Fix it with a glue.
    2. Should I fix it with a double side adhesive tape
    3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium plate - there is about 1mm on three sides and 0 mm on one side between the ceramic and the perforated metal plate.
    I am confused can someone help me out.
    Antenna url
    https://www.mouser.in/datasheet/2/39...2E-3137376.pdf
  • Hondaman
    Single-channel antenna?
    by Hondaman
    Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
    I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
    Years ago I made a "T"...
    11-18-2024, 01:14 AM
  • howardc64
    LG 49UJ6500 LCD panel lighter band that goes away
    by howardc64
    49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
    Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
    02-19-2023, 12:13 AM
  • SolomonMan
    Antenna...
    by SolomonMan
    All,
    I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
    There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
    Since we moved in, 8 years ago,...
    10-05-2023, 02:37 PM
  • Hondaman
    Gray-Hoverman antenna
    by Hondaman
    Hello all,
    Recently I'm upgrading my Gray-Hoverman antenna. Original design. I cannot use a "double-stacked" antenna because of attic space. I do not wish to mount anything to my chimney.
    I am using a separate antenna for WHAS Channel 11 (they are using RF Channel 11, 198-205 MHz). I replaced my 29-inch "T" antenna made out of #12 or #10 wire. I made a 58-inch "T" antenna out of 0.25-inch copper tubing. Hooked it up with a matching transformer to the 75-ohm coax going to my TV. I held the "T" antenna up against my ceiling, less...
    10-16-2021, 05:28 PM
  • chth96
    by chth96
    03-09-2024, 10:03 PM
