Lenovo T470P NM-B071P not charging, 20 volts on positive +ve battery terminal
  • Zibbo
    • Mar 2017
    • 205
    • Zimbabwe
    Lenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
    Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals.
  • mon2
    • Dec 2019
    • 14721
    The high side battery charge or the battery enable MOSFET must be leaking. This leak is supplying the main power rail voltage unregulated onto the battery terminal. Remove all power. Measure the resistance across the MOSFET pins to confirm. If the resistance is not hundreds of k ohms, part may be defective.
    • Zibbo
      • Mar 2017
      • 205
      • Zimbabwe
      Thanks but I have already replaced the high side mosfet PQ101
      • mon2
        • Dec 2019
        • 14721
        Review if PD7 is leaking.
        PQ10 ok?
        • Zibbo
          • Mar 2017
          • 205
          • Zimbabwe
          PQ10 ok?
          Both tested ok, I have also replaced them just to be sure.
          Edit: Thank you mon2 for your assistance, it was my fault. I had replaced PQ11 with a P-Channel mosfet instead of N-Channel. Sorry for wasting your time.
          • Genghis_Khan
            ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
            by Genghis_Khan
            I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
            Issue summary:
            Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
            However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
            11-11-2025, 11:51 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • kjchatman
            asus tuf506IV gaming laptop with 19 volts on battery terminal
            by kjchatman
            i'm charging an asus laptop that i just repaired and i'm measuring 19v on the battery terminal with the charging connected. Is this normal? the battery is rated at 15.4v...
            07-03-2024, 01:51 PM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
