"Sima" brand 325W inverter... works currently but...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    ... it's full of Fuhjyyus !!!
    Since I don't use this inverter that much - stays cool, it still works fine. However I wonder how long it will be until it starts developing issues much like the Antec PSUs.
    The cover seems to have rusted into place so I can't get any inverter porn going here. Worth sharing I think, but we'll have to wait until I can get the cover off without damaging it.
    BTW this is the inverter that shocked me... literally. Maybe there is a real problem worth investigating...
  • CapLeaker
    Leaking Member
    • 8297
    Re: "Sima" brand 325W inverter... works currently but...
    Oh! Got to see those inverter porn pics!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Alrighty here's a bit of side tOOB...
      And here we go, inverter p0rn...
      Thin Red/White wire goes to power switch
      Blue/Brown goes to outlets
      Fat red/black goes to 12VDC
      Thin red/blue goes to fan.
      Looks uncannily like the 80W inverter I repaired - dual KA7500/TL494 and H-bridge, except bigger capacitors and transformer (it is 4x the power capacity...) and has a LM324 (the 80W uses discrete it appears). The little 80W uses a single red/green LED and this one uses discrete red and green LEDs to indicate its status. The same structure but heatsinked main switches (lower left) and H-bridge (lower right) exists in both designs.
      Anyway, isn't it sexy? We see so many ATX PSUs, for a change we get to see Sima - a PSU's opposite - that converts +12VDC to 120VAC...
      • rugger
        • Feb 2005
        • 55
        In my opinion, the sooner you replace capacitors you suspect will go bad (or are going bad) the better.
        It is perfect if you can repair a device before it starts showing symptoms of problems, because that means nothing has been damaged by the faulty caps. Waiting until it releases it's magic smoke means much more work.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          But if it won't go bad... that means you've wasted money and time
          I've never run the inverter long enough to heat up. The "primary" caps in this PSU (the 1000uF Fuhjyyu TN's) are just like in on-line power supplies - they are charged by the alternator and discharged by the switching transistors. The "secondary" capacitor is the Fuhjyyu MH capacitor, a 200V (forgot, I think it's around 68 to 100)uF 105°C capacitor.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Since you don't use it often, you can recap that with parts pulled off from other boards. That way you will not waste money.
            A working TV? How boring!
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I will need to locate a source of a large number of good spares to recover... unfortunately a whole bunch of 1mF capacitors are already spoken for in another recap job...
              • x_orange90_x
                by x_orange90_x
                01-29-2025, 09:24 PM
              • CapLeaker
                Dell ATX PSU won’t start, but forcing it works fine?
                by CapLeaker
                Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                10-28-2024, 06:59 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • valvashon
                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                by valvashon
                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                01-04-2024, 01:44 PM
              • ex250
                Kenwood SW-505D no sound issue and pops from time to time when it works
                by ex250
                Hello mates,
                I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                12-29-2024, 03:27 PM
