PlayStation 4 ADP-200ER PSU repair
  • Johndill
    • Aug 2015
    • 314
    Re: PlayStation 4 ADP-200ER PSU repair
    Originally posted by momaka
    Looks like resistors R99, R98, and diode D63 at the very least.
    R99 should read 10 KOhms or less in circuit (or not more than 5% over 10k).
    R98 looks like a 51 Ohm resistor. Again, it should read 51 Ohms or less.
    D63 may or may not show a diode reading both ways, depending on what's in parallel with it. But it looks like there isn't anything, so if you get a good diode reading one way and nothing (infinite/open) the other way, then it's probably fine.
    R99 reads 9.86k ohms
    R98 reads 51.0 ohms
    D63 shows 0.024V in circuit with the leads on either way
    I have a broken ADP-240CR PSU that looks like it has a good 24N60M2 in it for a replacement, it has around 0.9 ohms between the left and centre pin and left and right pins, the centre and right pin have 0.2 ohms, is that ok?
    Edit: with the possible replacement 24N60M2 out of circuit, the readings are lower, from what was said in post #16, that is good?
      "D63 shows 0.024V in circuit with the leads on either way"
      What is the resistance reading of D63? 50 Ohms or so?
      • Johndill
        • Aug 2015
        • 314
        Yes, D63 is 51.0 ohms
          That is what I expected, the Gate discharge D63 is connected in parallel with R98 (51 Ohms), it is typical set up for Gate discharge circuit.
          • Johndill
            • Aug 2015
            • 314
            Do I put on the other MOSFET I have and test with the light bulb again?
            • Johndill
              • Aug 2015
              • 314
              Replaced MOSFET and did the light bulb thing and the bulb lights up as before, did I connect the bulb correctly before or do I still have a short?
              R99 reads 1.1 ohms with this other MOSFET in circuit.
                At this point it can be that the SMPS IC that drives the MOSFET has the output stuck high all the time instead of switching on and off.
                Can you read the P/N of the SMPS IC?
                • Johndill
                  • Aug 2015
                  • 314
                  Is that component IC31?
                    IC41, as you can see, the Gate pin of the MOSFET is routed to that IC via resistors and diode D63, R98.
                    • Johndill
                      • Aug 2015
                      • 314
                      How do I test it?
                        • Jul 2011
                        • 6070
                        Do not worry about testing if you suspect that this part might be the problem I would highly recommend replacing it unless it is hard to find but I would looking for one
                        • Johndill
                          • Aug 2015
                          • 314
                          How do you suspect IC41 would be a problem?
                            • Jul 2011
                            • 6070
                            From what I have read on the forum that seems to be the problem when the mosfet is taken out and if this is the case most of the time this is why I made the comment that I did and If I was doing this repair myself I would replace it
                            I have repaired a few servo drive where switching power board would not power ON most of time it has been those types of IC chip has been the problem most of time
                            These were hit with a lightning strike near the house————>
                            You can read about this repair at
                            https://www.badcaps.net/forum/showthread.php?t=65482
                            I just repaired a 3 volt @ 5 amp switching power supply I had two of them
                            ( I have a total of 3 of them )
                            that are the exact same model one of them the main fuse was blown on the board the other one was turning on and off repeatedly
                            So I took the switching power regulator IC chip and move it to one that had not blown the fuse
                            Well that did not turn out so well that IC chip blew out sparks out the bottom of the chip where the pins are it did blow the main fuse on the board but it did trip the electronic fuse controller that I have ( I call this the controller the spark and smoke tester ) I have had few of them do that in the past
                            I replace the switching power supply regulator IC chip now the power supply has been working for the last three weeks non stop so when I have come to the conclusion that the switching power supply regulator IC chip could be the problem I just replace it and be done with it
                            Here is where you can fine one
                            https://www.mouser.com/ProductDetail...Dc8bBrvA%3D%3D also has the data sheet
                            They do not cost much I would order a few of them just in case you put to much heat to one of them when installing it
                              Check the resistance between the Pin 8 (GATE) and Pin 7 VCC just to see what you get, make sure to count the pins correctly.
                              • Johndill
                                • Aug 2015
                                • 314
                                Pin 7 and 8 read 8.70k ohms
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #36
                                  Looking more closely at the pics you provided, it appears that MOSFET Q6 (the 24N60M2) is for the PSU's APFC circuit, along with diode D11 next to it.
                                  Try this: remove Q6 completely and apply power to the PSU through the incandescent light bulb. Does the bulb still stay lit all the time, or does it go bright for a second and then go off/very dim? If it stays bright, you probably have a short-circuit somewhere else on the primary side (i.e. not the APFC circuit). If not, then see if you get any voltage from the PSU's 4.8V standby rail. I believe you can find that on the white connector on the output side of the PSU. If not, it appears that C123 and the coil/inductor next to it should be connected to the 4.8V standby rail as well.
                                  Another thing to keep in mind: APFC PSUs don't always like the incandescent bulb trick and may make it stay lit or flicker very quickly for 10-20 seconds. For this reason, I always test APFC PSUs with at least two or three 100 Watt incandescent bulbs all in parallel. This allows more current to pass through them to the PSU and keep the APFC happy while still providing good protection from over-current and over-power. So try that and see if the 2-3 incandescent bulbs stay lit or go off with Q6 back in the circuit. If the bulbs do stay lit for more than 10 seconds, IC41 may indeed be bad, and/or more of the components surrounding it.
                                    That seems low to me and probably enough to bias on the MOSFET.
                                    You can check the Voltage between GND pin and Gate to see if you see steady DC of >2~3V or not, use the lamp in place still in this test.
                                    Or you can also GND the Gate of the MOSFET with 100 Ohms resistor and see if the lamp will not light up.
                                    But then again, how much is that IC comparing to taking a chance of blowing up new MOSFET due to bad IC?
                                    • Johndill
                                      • Aug 2015
                                      • 314
                                      Sorry, I've become too busy currently and will have to put this project on hold, hopefully I can continue soon :-)
                                      • mindfx
                                        • May 2016
                                        • 4
                                        • litwa
                                        #39
                                        ok , if mosfets have short`s , no matter between which pins it`s bad. , so put new ones. always check resistor , whick provides HV power to theese mosfets . this resistor should be around 1 ohm. then if them blown again , then replace power control IC , and of cource mosfets and HV power supply resistor again. Also ensure , that there is no short on output before.
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
