Ault Power Supply 3 volts @ 5 amps one second on one off
    • Jul 2011
    • 6059
    This power supply run some white LEDs flood light in the front of my yard
    This power supply has been in use for about 4 to 6 years until we had a bad thunderstorm which mess up a lot electronic devises which cost me about $1000
    to replace
    This power supply did not escape it vengefulness of that storm
    I would like to try to fix it I can not find this size power supply in this foot print any more
    It fits in a power supply box that was made by Malibu lighting company it nice and small with a photo cell all ready there
    The problem with power supply is that it come ON for a second then goes OFF for a second and keeps repeating
    The optic sensor was blown to pieces replace it and recap it except the main cap
    Right next to main filtering cap there is a device that 4 pins but I can not read the numbers on it but I think that it must be the switching regularlator IC chip
    I have another switching power supply that is the same exact model that works fine I can read the numbers on that if I take out filtering cap again which I can do
    Any one have any ideas where to start
    • 31163
    Re: Ault Power Supply 3 volts @ 5 amps one second on one off
    check resistor SR9 on the bottom of the board.
      • Jul 2011
      • 6059
      Thank you for pointing me in the right place on this board
      SR8 = 101 which should be 100 ohms reads a lot higher that in either direction
      First thing I am going to do is replace this resistor
      SR9 = 705 which should be 7 megohms it more like 11.34 k ohms in either direction
      Take this one out and recheck it
      SDZ1 if this one is a diode in one direction it reads .856 in the other direction
      It reads 1.67 volts in diode test mode
      If this is a resistor with a value of “0” it is not reading “0” ohms not even close kohms range
      (it looks like there maybe another digit but the solder is in the way)
      I will have to see if this component has a line or a dot on it ones I have taken it it out
      If it turns out to be a resistor it get replaced with another “0” ohm resistor
      All of these reading are all mess up
      One other note
      This was checked with a lab power supply with voltage and current control
      Most of the the white LEDs are not working and the amperage is a little high in both direction
      This should not be the case it should have current in one direction and none in the other direction at 3.3 volts
      I will have to replace all of the LEDs in the flood lights
        • Jul 2011
        • 6059
        UpDate
        Replaced the “0” ohms
        Now it flashes slower and little bit brighter but still dose not work right
        I going look up the four terminal device and see what it is and probably replace it
          • Jul 2011
          • 6059
          UpDate
          I replace all the LEDS lights in the flood lights in my yard now they work again
          I still do not have the original power supply working yet that another project I will have to order some parts for the board
          One note the power supply loaded to about 120millamps the voltage is at 3.07 volts so the LEDs are not being over driven the tag that was with the LEDs that I bought says 3.0 to 3.2 volts
          There are 40 LEDs for this flood light system there are 4 flood lights with 10 LEDs in each one
          One note I made these flood lights from some very good solar lights
          The reason I took the solar panels of them was because the batteries that were in them would not stay light all night long
          Malibu lightning system had a 12 volt transformer that went bad so I use the case because it had an electric eye in the case
          That when I took out the bad transformer and put in the switching power supply
          To make this LED lighting system
          I have one more of these Malibu 12 volt transformer that has gone bad I going the same thing again with this one as well
            • 31163
            not overdriven, but maybe overheated??
              • Jul 2011
              • 6059
              I put the wrong valve for the total amount is about 120 mill amps
              At 3.2 volts it is 20 mill amps for one
              At 3 volts the mill amps for one is 3.3 ( at this power supply voltage they are fairly bright)
              One note
              This has worked this way for 4 to 6 years if these LEDs are as good as the original one that came with I would be real happy
              The bag that they came in said made China so we will see if last
                • Jul 2011
                • 6059
                Here is a photo of the flood light
                  LED is current device, you should regulate the Current flowing through the LED and run it at less than the max current spec. The Vf of the LED varies with temperature and the amount of current flow through it.
                    • Jul 2011
                    • 6059
                    Here is the specks for these LEDs
                      It does not show the max current rating?
                      The spec is showing what the Vf will be at forward current of 20mA, the Vf varies with the amount of current. 20mA white LED is way too low to be used for flood lights, there are missing specification for that LED. I expect it to be 200~400mA range to be used for lighting application.
                        • Jul 2011
                        • 6059
                        I was not looking for high out put LED for this application I was wanting some thing that look like flood light but was not high output just to light the walk way
                        Which works very well
                        I would not be able to use high output LEDs in this case there is no room in the case for a heat sink
                        Now do want to make some high output flood lights but the problem is finding the right case for this project do you have any Idea
                        I have some 10 watt high output LEDs that I bought a while back that I would like use for this project
                        Here is the link where I have bought some before
                        http://www.mpja.com/1000-Lumen-10-Wa...25+OP/#reviews
                        Here is driver LED power supply here is a link to one would this work
                        http://www.mpja.com/LED-Driver-10W-9...info/32817+PS/
                          Bottom line, no matter what LED you use, you should limit the current to about 75% of the maximum rating with good thermal management if you want the LED to last.
                            • Jul 2011
                            • 6059
                            UpDate
                            The 4 pin device is a switching power regulator
                            Part number is
                            KA5M0265R.
                            It is a hard to find I can get them from a company in Miami Florida (they have an eBay
                            https://www.ebay.com/usr/dalbanicorporation )
                            web page it been a long time since I have bought anything from them but they carry hard to find parts
                            Quest Components Corp
                            ( https://www.questcomp.com/?gclid=EAI...SAAEgKgSPD_BwE)
                            is another company to find hard to get parts
                            I hope that these two websites will help someone looking for hard to find components
                            If anyone else has use another company to get hard get parts that does not have a high minimum quantity or a high minimum $ amount can you please post the company name or the link to there website thanks
                              • Jul 2011
                              • 6059
                              Power supply UpDate
                              I had two these power supply’s that did not work
                              Power supply number 1 the one I posted still does not work with the new switcher IC chip
                              Power supply number 2 this one blew the main fuse this is the one I took the switcher IC chip and put in power supply number 1 and fire works came out the bottom of the power supply switching regulator IC chip but did not blow that fuse
                              Put a new power supply switching IC chip and this power supply number 2 works again
                              So now I have to figure out what wrong with power supply one that I posted on this post
                              • Longbow
                                • Jun 2011
                                • 623
                                Technically you are right, but in this simple case the small variation in Vf is irrelevant.
                                the 20mA white LED is way too low to be used for flood lights,
                                not if the light is composed of an array of LED's, which it is according to the descriptions so far.
                                Anything above continuous 100mA in one LED is called high output and is manufactured with integral heat sink. I don't think this simple light uses special hi-watt units, but rather an array of series/parallel LED's running a typical 20 mA value (still no exact information). Let's just say that 20mA would be a good safe starting guess to get everything working before thinking about hitting them with more current. Reading just one of the LED's with the meter on diode mode will give you a working practical value for the Vf of one LED. I suggest powering the lamp with a small variable supply to find the required drive voltage.
                                Is it plugged in?
                                  My logic based on given DATA:
                                  'There are 40 LEDs for this flood light system there are 4 flood lights with 10 LEDs in each one"
                                  Power supply is rated at 3V 5A, so if the LED used for each bank is only 20mA, and all connected in parallel then total current draw for one LED bank = 10 x 0.02A = 0.200A (or 200 mA).
                                  So if all 4 bank is connected in parallel, then total current draw = 0.200A x 4 = 0.800A. Power supply is rated at 5A, so the OEM could have suplly the unit with 2A power supply to save money.
                                  But per OP: " One note the power supply loaded to about 120millamps" So that does not add up to have 40 LEDs with total current draw of only 120mA which will be only about 3mA per LED!
                                  So I doubt that those LEDs are rated at 20mA or 50mA, they will be higher rating. The LEDs are probably mounted on aluminium substrate. Unless the DATA given is wrong.
                                  It is easy enough to measure the current draw for each LED bank.
                                  In each lamp assembly may also have boost converter and some circuit to maintain the constant current through the LEDs, or may be they are just really cheaply made and just apply 3VDC to the LEDs directly.
                                    • Jul 2011
                                    • 6059
                                    I have work with LEDs for along time and if you have the voltage turn down until it the current climbs to 10 milliamperes for most low power LEDs now I have work very low power LEDs that current is less than 5 milliamperes those to me are hard to work with
                                    Those LEDs I will run them at one milliamperes unless it is very dim I might run them at 2 milliamperes with setup I have had very good results
                                    Unless the LED very poor quality then all bets are off
                                      • Jul 2011
                                      • 6059
                                      The reason I chose this power supply supply is because the regulations was very good and no matter what the load that is on it the voltage stay right at 2.90 to 3.09 volts
                                        They are flood lamp in post 8, I never seen flood lamp with just 10 LEDs at low current to give enough lights.
                                        We make lighting accessories too and we drive them in 100mA range unless we are talking about those cheap night light with 1 LED.
