I rec'd this PSU dead
The O/P caps (Fucku) were vented, replaced all of these with
Pana FC and Samxon GD.
Post recap. The PSU is still dead.
Fuse ok
Bridge rectifier ok.
Removed the primary HS and tested the ICs - all ok.
However, I found one power resistor rated at 100R 5%, reading 46.
The pcb was slightly brown and this resistor will have to be replaced.
Also, another resistor 1.8R is reading more than 5% out of spec., that
is. 1.7R with my ESR meter. Ok, 1.8R 5% (+/- 0.09) is there or there
abouts. However, as this had been shrouded, the shroud had welded
itself to the device. Perhaps it is starting to drift - so will replace.
I'm working my way through this PSU to see what else is wrong with
it (if anything).
Just one question, these resistors are power resistors.
I believe these may 1 to 2W wirewound ceramic but not ceramic
rect. block power devices.
What should I be looking for, quality wise?
Any advice - appreciated
Thx.
Fuse ok
it (if anything).
Thx.
