  • jinu_j
    • Feb 2016
    • 93
    • India
    Hi
    4. D930 - Shorted Schottkey Diode 150V/5A
    While i can find replacements for most of the parts i cannot find a replacement for a fusible resistor. Can i replace the fusible resistor with standard 0.2 ohm resistor. If not then can i use a standard fuse, but how do i find the current rating of the fuse ?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8800
    You can choose between Wire Wound, Carbon Film, Metal Film and Thick Film resistors. If the resistor is in a high voltage application circuit, you may want a Flame Proof resistor in its place.
    • lotas
      • Jan 2016
      • 5398
      • Russia
      Your LD7575 PWM is also 100% damaged.​
      • jinu_j
        • Feb 2016
        • 93
        • India
        I thought it might be damaged but did not know how to test it. Now that you have said i think i will replace it anyways. Thanks
        CapLeaker thanks but any idea why a fusible resistor is used instead of a normal fuse. A 0.2-ohm resistance is practically zero. The voltage will be the mains voltage around 400 V. The circuit that generates VBUS is shown below
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8800
          Think about what a fuse does and what a resistor does. The fuse blows and the circuit is broken. A fusible resistor limits current to a certain degree, resistance increases as it gets hotter (limiting more current), then blows. The fuse would have blown long time ago. Probably more about reliability, so you don’t change fuses all the time for the weirdest reasons.
          Another reason why a fusible resistor is used, plain and simple cost. The resistor is cheaper than a fuse. Corporate cost cutting at its best!
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • diamon
            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
            by diamon
            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
            Pictures of these boards:
            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
            Dell...
            02-28-2024, 12:51 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Mirenia
            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
            by Mirenia
            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
            03-30-2025, 06:47 AM
          • DIY Addict
            DELL S3220dgf Display Panel Replacement
            by DIY Addict
            My monitor's screen was damaged recently and I've been trying to figure out where I could, at the very least, consider replacing the screen to salvage an otherwise perfectly functional monitor. The LCD panel model is an LSM315DP03-C01 and I have found DP01/05 models, but I don't know whether or not these are compatible with the other hardware components. As it stands right now, I need to either figure out where I might be able to find a replacement panel OR whether or not a different panel version is something that would be something I could viably consider. Any assistance, insights, and perspectives...
            08-26-2026, 11:11 PM
