Cougar CMX 700W suddenly Went off
  • Drack
    Yup it's me
    • Nov 2016
    • 297
    • Venezuela
    Re: Cougar CMX 700W suddenly Went off
    Was talking about a 20w watts though
    • Drack
      Yup it's me
      • Nov 2016
      • 297
      • Venezuela
      Told you check d10 out of the circuit
      • abdorefky
        • Jan 2017
        • 19
        • Egypt
        i just did, it's working fine . and in 1 direction only
        • Drack
          Yup it's me
          • Nov 2016
          • 297
          • Venezuela
          Check the others too
          • abdorefky
            • Jan 2017
            • 19
            • Egypt
            Just found dark brown here too !!
            • Drack
              Yup it's me
              • Nov 2016
              • 297
              • Venezuela
              #26
              Took it off, a short can make the PSU to shut off
              • abdorefky
                • Jan 2017
                • 19
                • Egypt
                #27
                The fan ticks or makes something when you short ps on with ground or just dead?
                Drack.[/QUOTE]
                Just dead Fan
                  • 31246
                  change all small caps.
                  • abdorefky
                    • Jan 2017
                    • 19
                    • Egypt
                    #29
                    Changed all capacitors
                    Still nothing .
                    What about the secondary supervisor ? What should i do on it ?
                    • abdorefky
                      • Jan 2017
                      • 19
                      • Egypt
                      #30
                      Originally posted by Behemot
                      that's normal condition, by pulling the signal down the supervisor starts the main power supply
                      Hello Behemot
                      Any idea about what i should do now ?
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #31
                        green corrosion behind q202.
                        dammed brown glue ate a trace.
                        • abdolah
                          • Feb 2025
                          • 5
                          • Egypt
                          #32
                          Hi do you still got that psu , I have the same model and I need the marking on that transistor
                          • wnlewis
                            New wire for my RDE3340 Whirlpool electric range
                            by wnlewis
                            OK. I got the rocker switch figured out thanks to the good advice on this forum.
                            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                            This is a Whirlpool RDE3340 electric range.
                            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                            Where may I find parts...
                            01-08-2025, 11:21 PM
                          • emeskay
                            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                            by emeskay
                            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                            08-06-2024, 07:13 AM
                          • technicalspecialist
                            Vintage fan repair, copper wire question
                            by technicalspecialist
                            I currently have a customer's vintage fan on the work bench to repair.
                            It uses an induction motor with 4 poles. One of the poles is open.
                            I couldn't find the break so i cut off the original wire.
                            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                            The enamelled copper...
                            03-16-2023, 12:54 PM
                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                            by sam_sam_sam
                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                            12-16-2023, 08:39 PM
                          • kalemaroni
                            Dell DC Brown wire
                            by kalemaroni
                            There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                            08-26-2025, 10:10 AM
