Cougar CMX 700W suddenly Went off
  • abdorefky
    • Jan 2017
    • 19
    • Egypt
    i have : Cougar CMX 700W
    Model : CGR B2-700
    the power supply stopped working.
    i tried to connect the green wire with the black wire to activate the fan but still nothing ! .
    how can i troubleshoot such thing ?
    Thank you
  • Agent24
    I see dead caps
    • Oct 2007
    • 4977
    • New Zealand
    Re: Cougar CMX 700W suddenly Went off
    Is the 5vSB rail working?
    -David VanHorn
    • CapLeaker
      Leaking Member
      • 8214
      I'd also be looking for the 5V STBY rail first while the PSU is plugged in. If the STBY rail works, force the PSU on and check the DC voltatge on the main filter capacitor. Be careful, you are connected to mains voltage and if the PFC booster is running, there is 390V DC on that capacitor.
      Can you explain as best as you can what happend? Did it just turn off, or was there a bing bang, or is the fuse blown etc?
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        I'd be curious to know if the thing is getting 5VSB too. When you hit the power while shorting PS_ON, does the fan tick for a second? I noticed that the daughterboard between the primary heatsink and main transformer is covered in what looks like conductive glue. Look closely to see if there are any burn marks there.
        Black PCBs look cool but make troubleshooting harder since you can't see discoloration very well
        Check the startup cap as well which looks to be that small cap by the large high voltage cap.
        • abdorefky
          • Jan 2017
          • 19
          • Egypt
          good morning every one and sorry for the late replay.
          i have tested all voltages while shorting the PS_ON
          the only working one is the 5VSB ( and it doesn't need to short on PS-ON ) it on all time.
          all other voltages doesn't work .
          should i should more photos for the power supply ?
          • abdorefky
            • Jan 2017
            • 19
            • Egypt
            The DC voltage on the main capacitor is 320
            about what happened : i tried to turn it on but it didn't !!
            • abdorefky
              • Jan 2017
              • 19
              • Egypt
              i have made some Diode testest
              D81,D82,D83 = .455
              D24 = .345
              D10 = .310 ( but on the reverse it keep counting up and stop at 1.1)
              D6 = .445
              • abdorefky
                • Jan 2017
                • 19
                • Egypt
                Addtional photo.
                • Behemot
                  • 4845
                  • CZ
                  Seems like you have some chloroprene glue in the unit, check if it went brown somewhere shorting something and if so, clean it.
                  Do you have about 3.3 V on the green wire?
                  • abdorefky
                    • Jan 2017
                    • 19
                    • Egypt
                    Hello Behemot,
                    i don't have the 3.3 V on the green wire
                    about the brown i have attached those 2 photos the view some brown.
                    but how to clean it with out damaging the board ?
                    • Behemot
                      • 4845
                      • CZ
                      Well, badly.
                      If you don't have PWR On available than no wonder it can not be started. Most likely problem with the secondary supervisor.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4977
                        • New Zealand
                        Make sure you measure the green wire without connecting it to ground, ie: without trying to force the PSU on.
                        That glue is much easier to remove if you heat it, try a hairdryer or heat gun on low temperature. Carefully pull it off with pliers or such. Don't damage the parts under it.
                        -David VanHorn
                        • Behemot
                          • 4845
                          • CZ
                          I can see Silicon Touch Technology logo, which one is there?
                          • abdorefky
                            • Jan 2017
                            • 19
                            • Egypt
                            mmmm i did connect the avo between the green and the black .
                            will the avo force PSU-ON ?
                            • Drack
                              Yup it's me
                              • Nov 2016
                              • 297
                              • Venezuela
                              Have you tried it with a car bulb or something that can put some load, some PSU don't like to start with no load.
                              Check d 10 out of the unit, took every glue that looks brown. The fan ticks or makes something when you short ps on with ground or just dead?
                              When it went of did it make any wierd sound?
                              Drack.
                              • abdorefky
                                • Jan 2017
                                • 19
                                • Egypt
                                PS223
                                P11616A1F
                                Board by ****** i dunno the logo
                                06 94V-0
                                TB-7-2W(L)X-CNT F1.2
                                2010.10.12 DC0-0103F2B
                                • Behemot
                                  • 4845
                                  • CZ
                                  So when you keep the PWR On high, do you have 3.3 V or not?
                                  Lightbulbs are bad idea unless combined with NTC in series. Startup current of lightbulb is hundreds of amperes, that can kill rectifier right away.
                                  • abdorefky
                                    • Jan 2017
                                    • 19
                                    • Egypt
                                    Alright i have checked again, how ever i am sure that all gives 0 voltages except the 5VSB
                                    something new happened now, maybe the cleaning did something ?
                                    the Green Wire voltage = 2.973 V
                                    when i try to force power on while measuring the green wire voltage it jumps to 0 voltage
                                    • Behemot
                                      • 4845
                                      • CZ
                                      that's normal condition, by pulling the signal down the supervisor starts the main power supply
                                      • abdorefky
                                        • Jan 2017
                                        • 19
                                        • Egypt
                                        Great, what should i test now
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
                                        • GlenBrim
                                          1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                                          by GlenBrim
                                          I got this recently as-is. Gigabyte 1070 video card.
                                          DVI port is removed. I don't know why.
                                          A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                                          I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                                          The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                                          02-14-2024, 02:08 AM
