Troubleshooting B&W Original Powersupply
  • bsjoling
    • May 2021
    • 4
    • United Kingdom
    #41
    Re: Troubleshooting B&W Original Powersupply
    Some great info here too...
    https://www.abcelectronique.com/foru...t=97071&page=1
    • PanicMechanic
      • May 2017
      • 47
      • Serbia
      #42
      You can use basically anything from this: https://export.farnell.com/w/c/passi...-in-stock-grp1
      Not sure what voltage you need, I put 16V to 35V. These are all low ESR.
      • DropThePuck
        • Mar 2022
        • England
        #43
        Thanks for all the information here.
        I managed to pick up an original Zeppelin (inc remote) with the flashing red light in almost mint condition for £30.
        I ordered the 4 grouped capacitors from Farnell. For anyone else that is going to do this, these were my issues:
        • Disassembly is easy, apart from the grill removal. The buttons to unlock the grill are there but you have to press them just right. Then sliding to the left and right is tricky, but a firm grip will do it.
        • Be careful removing the old capacitors. I managed to remove the copper tracking underneath two of them. Never had this problem on a circuit board before. So had to solder new caps from the top.
        • As mentioned before, the plastic mounting posts are very brittle. I just ended up removing the broken bits and screwing into the base of the post that remained. It seems to be fine.
        • Reattaching the ribbon cables is fiddly - be careful.
        • Reattaching the grills is not easy, as a combination of squeezing the grill and sliding is awkward. Then, I got them the wrong way around!
        I was not convinced it was going to work, but it did. It was definitely worth it, and an old iPhone 4 now plugged into it. Fantastic sound.
        Thanks again.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #44
          Im half way through making a repair video of the zeppelin generation 1.
          • thesmith
            • Aug 2017
            • 3
            • Brazil
            #45
            Hello!
            anyone solved the problem?
            My zeppelin 1g only red light flashing
            my power supply have 5v and 25v too!
            I Changed
            2200uF 16V
            470uF 16v
            220uF 25V
            1000uF 35v
            caps, but same problem!
            • mikey2230
              • Nov 2022
              • wales
              #46
              Hi. can anyone idendify what component this is please (PIC1). I was soldering a CAP onto the board and this came off D305 (PIC2). I think its a Rectifier Diode but with it being in half I cannot test it. Also I am not good with the color's !! Quite close by there is also one I found on the board but not sure if it is the same (PIC3).
              Mike
              • R_J
                • 9579
                The diode is a MiniMELF diode, it could be a BAQ134-GS08 Switching diode or it may also be a zener diode BZV55 series?
                The zener diodes pdf is here:
                • Slawit
                  • Aug 2024
                  • United kingdom
                  #48
                  I volunteer at a local repair cafe and someone's brought one of these Zappelin speakers in, with a blown power supply board.
                  We've not had any success repairing the board, and B&W Trek me they aren't manufactured any more. Nor do they have any circuit diagrams.
                  I was wondering if anyone knew the output pinout (on the six pins)? What voltage they should be, which pubs are ground, etc. If we know that, maybe we can put together an alternative that provides the same requirements.
                  Thanks for your help!
                    Acer Extensa EX2540-56BF + PowerCube Original Notebook 15 Specification for Upgrade or Repair
                    This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                    09-06-2024, 08:16 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • harp
                    can fanless heatsink replace poor original on RX26PG2
                    by harp
                    I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                    06-25-2025, 10:56 AM
                  • kingiii
                    downloaded bios is smaller than the original bios dump
                    by kingiii
                    Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                    Thank you very much
                    06-07-2025, 04:21 PM
                  • Capacitorial
                    Powersupply has all the voltages - Monitor still no power
                    by Capacitorial
                    Hello guys,
                    I have a Philips 240B7QPJEB. The monitor seems completely dead.
                    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                    The weird thing is, that the Power LED is powered over the TCON board.
                    On The TCON...
                    12-28-2024, 02:12 PM
