How to test 1M0880 FPS?
  • mikay786
    • Aug 2014
    • 765
    Re: How to test 1M0880 FPS?
    the top 9 pins of the transformer all have continuity, is that normal?
    And is this transformer being fed both AC and DC?
      BTW, you resolder all the components pin on the board, right? Including the OPTO PC911?
      • mikay786
        • Aug 2014
        • 765
        yep
          That is correct because each output winding has one pin connected to common cold side GND.
          • mikay786
            • Aug 2014
            • 765
            tested all rectifier diodes out of circuit and all fine 0.4v one way
              I need to look at the board layout to see what is stopping the drive circuit from from driving the power transformer.
              It is an always on power supply so there should be outputs on the cold side.
              • mikay786
                • Aug 2014
                • 765
                will the pictures from before suffice?
                • mikay786
                  • Aug 2014
                  • 765
                  could it be one of the smaller ics? like TL431K OR transistors C3198 etc
                  • mikay786
                    • Aug 2014
                    • 765
                    And do you know what FB901 is? this orange thing
                      It is just a ferrite bead inductor (a piece of wire fed through a ferrite bead).
                      • RalfE
                        • Oct 2022
                        • Deutschland
                        #51
                        I have also a Loewe I sound where exactly the same thing happened that was described before.
                        The resin was completely burned away. I am assuming it's meant to keep both resistors appart since they have a high voltage difference.
                        Now I have soldered in two new R912 and R914.
                        I meassured them and I thought that they were fine, but I exchanged them anyway.
                        However, if R912 and R914 get shorted there could be a high voltage at pin 5 of IC901, the 1M0880B.
                        I have a new one laying on my table right now but before soldering it in, I wanted to double-check the voltages at the different input pins.
                        Now the problem: I meassure 70V between Pin2 and Pin3 with IC901 removed. The maximum allowed voltage according to the datasheet is 30V. So I am reluctant to put the new one in and fry it.
                        And I also don't know how that voltage get's there. What is the voltage supposed to be present on C906. It's rated to 450V but my assumption was that the current is first transformed down and not up.
                        I found the service manual with all the schematics here:https://elektrotanya.com/loewe_indiv.../download.html
                        • RalfE
                          • Oct 2022
                          • Deutschland
                          #52
                          I figured it out.
                          The short between R906 and R912 killed Q911 and damaged IC901.
                          The way to test the 1M0880 quickly is to give a supply voltage of 20V to pin 2 and 3.
                          Now pin 4 and 5 should show above 3V. (actually 9V and 5V respectively).
                          For this you have to remove the M0880.
                          You can also test the OPTO couplers. They get 12v input voltage at pin 1 and 2.
                          I would recommend that you replace Q911, IC901 and both optos PC911 and PC912. I don't see how the rest of the components could be damaged by this kind of problem.
                          Be carefull, C906 get's 350V and keeps the voltage for a while.
                          • chth96
                            How Can I test PWM DM0365R?
                            by chth96
                            Hello
                            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                            06-18-2025, 04:14 PM
                          • khelane
                            test active pfc power with lamp test
                            by khelane
                            Hello
                            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                            Is there a way...
                            06-03-2025, 01:00 AM
                          • chronic519
                            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                            by chronic519
                            Hello.
                            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                            Found issue with a RAM block
                            Replaced, green lines gone.
                            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                            Used a good card to test and same results low errors 32+.
                            I am just search for some form of command to do a full test on the GPU.
                            I just ran the mats command with my good GPU and passed after roughly 40 min.
                            The repaired one, ran...
                            05-20-2025, 07:56 PM
                          • hemant_2222
                            Yamaha 2064 No sound but Test audio working
                            by hemant_2222
                            Hello Guys,
                            Greetings!
                            Hope you all are doing well.
                            I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
                            PCM1681DBQR - IC263 and it worked fine.
                            Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
                            11-01-2025, 11:20 PM
                          • alltvrepairs
                            Lg TCon test pins for screen test
                            by alltvrepairs
                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                            Appreciate your help....
                            06-13-2025, 06:33 AM
