How to test 1M0880 FPS?
  • mikay786
    • Aug 2014
    • 765
    Hi guys need some help with this Loewe 525 Indvidual Subwwoofer which doesn't seem to be powering on.
    AC is coming through, bridge rectifier is ok and outputting I think was 350v and main filter cap is reading 350v across it. A little further ahead there were a couple of blown 470k Resisters I think which are around 1w (Though not sure)
    I replaced these resisters with 470k 0.6w !! which I thought would be ok just to test. I did buy 2w ones but lost them on the way home and they were the last two in store so had to go with 0.6w ones which again I thought would be ok to test until I get 2w ones.
    Anyhow this hasn't made a difference, I'm not getting any voltages further down for example of the 2 big caps up top am not getting any DC voltage.
    The blown resistors are connected to pin 3 VCC of the 1M0880 FPS so thinking it could possibly be the cause?
    How do I test this?
    Re: How to test 1M0880 FPS?
    When you said the two 470K resistors were blown, what do you mean by that? Open circuit? Are they really are 470K Ohms?
    Did you check or replace the startup/running cap C911 in the primary side?
    • mikay786
      • Aug 2014
      • 765
      The 470k Resistors were covered in that glue stuff which was charred.
      Measuring on multimeter the ohms reading just keeps climbing, currently at 17.92M Ohm and climbing. Is that open or short circuit? On transistor tester thing just says unknown / damaged part.
      Colour band is Yellow, Violet, Yellow, Gold
      I tested C911 capacitor which is a 50v 47uf cap and it tested ok.
      Ive tested the diodes too and they seem fine in circuit.
        OK, the glue damaged the resistors.
        They look like 1/2W resistors MOX type.
        The replacement resistors you put in do not look like they have the correct color code, they are 5-band and the colors do not look right to me.
        It looks to have Yellow, Gray, Black, Orange, Brown.
        Can you provide straight shot pictures of the top and the bottom side of the board without the red markings?
        • mikay786
          • Aug 2014
          • 765
          The guy at the store measured the resistors before handing them over.
          The colours are, Yellow, Violet, Black, Orange, Brown. They are 0.6w and are significantly smaller that the old ones.
            OK, the replacement are 1% resistors.
            So did you check or replace C911?
            BTW, all the rectifier diodes on the cold side tested OK?
            • mikay786
              • Aug 2014
              • 765
              Ive tested all the caps and they all measure good aside from one on the secondary side C933 which is slightly low (black small cap below 3 row transistors top right) 1000uf 10v measures 850uf.
              Tested row of components where the burnt resistors were and all ok, ceramic caps, and diodes / resister.
              • mikay786
                • Aug 2014
                • 765
                Checked C911 and it measures ok, I can replace and try as I should have a suitable replacement?
                I have not tested the diodes out of circuit, but in circuit they seem ok. I will though now.
                  So D925, 927, 931 are all OK?
                    BTW, what DCV are you getting on the VCC pin of the SMPS IC with the new resistors installed? Make sure to use Negative leg of the main filter cap as the GND ref. for the meter.
                    • mikay786
                      • Aug 2014
                      • 765
                      In circuit they appear fine, directional but I will pull them out now and try.
                      • mikay786
                        • Aug 2014
                        • 765
                        Is that the IM0880?
                        Will do after I get these diodes out and tested. D925, 927, 931
                          Originally posted by mikay786
                          Is that the IM0880?
                          Yes, IM0880.
                          • mikay786
                            • Aug 2014
                            • 765
                            Yea I was playing with it yesterday but didn't know how to measure it properly, I had the black lead going to pin 2 ground and red cable going to pin 3 vcc but readings were all over the place.
                            So I should use filter cap negative as ground.
                              BTW, there are 3 black devices with mounting hole and one with metal tab also with mounting hole, what are the P/N? The designators are IC921~924?
                              BTW, the top side pictures are not straight shots and not clear enough to read the designator for those 4 devices in question.
                              • mikay786
                                • Aug 2014
                                • 765
                                D925 and D927 rectifier diodes are ok reading 0.4v
                                D931 (SFAF1004G)
                                http://pdf1.alldatasheet.com/datashe...SFAF1004G.html
                                Which in diode mode is directional and reads 0.415v so good again I assume
                                  BTW, the Vstart (Voltage at the VCC pin) for the IM is 15VDC.
                                  • mikay786
                                    • Aug 2014
                                    • 765
                                    IC922 (LEFT) - KIA78R12PI
                                    IC924 (MIDDLE) - KIA378R05PI
                                    IC923 (RIGHT) - KIA78R33PI
                                    IC921 (Metal tab) - KA7912
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      Ill get it put back together and measure the IM0880 VCC which should be 15VDC, with ground coming from negative on the filter cap.
                                      • mikay786
                                        • Aug 2014
                                        • 765
                                        Ohh yea before I forget there was some heavily burnt glue underneath the encapsulated resister top right near the two big caps. 470 ohms resister but it measured ok and so did the caps next to it.
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          06-18-2025, 04:14 PM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
                                        • chronic519
                                          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                          by chronic519
                                          Hello.
                                          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                          Found issue with a RAM block
                                          Replaced, green lines gone.
                                          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                          Used a good card to test and same results low errors 32+.
                                          I am just search for some form of command to do a full test on the GPU.
                                          I just ran the mats command with my good GPU and passed after roughly 40 min.
                                          The repaired one, ran...
                                          05-20-2025, 07:56 PM
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
                                        • signal.quest
                                          Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                                          by signal.quest
                                          I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                                          I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                                          09-30-2024, 11:21 PM
