How to test 1M0880 FPS?
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: How to test 1M0880 FPS?
alright it seems to be fluctuating between 11v upto 14v jumping around within that range, not constant. Measured from filter cap negative and 3rd pin vcc
when I turn the power off and measure at same place once its below like 10v it declines in an orderly fashion not jumping up and down.
Main filter caps has 347v
Measured the large two caps top right again which are 2200uf 50v and they have nothing going through them just mvLast edited by mikay786; 07-13-2016, 10:59 AM.Comment
So it can be bad startup cap C911 which is connected to the VCC pin, or the circuit detects problem so it is in the startup-shutdown mode, or bad SMPS IC.Never stop learning
Please check the resistance between the two legs of C921, C928, C932, C924.Never stop learning
OK, they are OK, no very low resistance reading, so more likely the problem is in the power transformer drive circuit.
Since the startup cap is already changed, next thing will be the SMPS IC itself.Never stop learning
http://www.ebay.co.uk/itm/1M0880-KA1...sAAOSwv0tVcz8Y
is that the correct part?Last edited by mikay786; 07-13-2016, 12:38 PM.Comment
That is the one.Never stop learning
It will blow the fuse if the internal power MOSFET is shorted out (PIN 1 to pin 2).
The VCC pin has internal 32V Zener for protection, it can be bad.Never stop learning
The VCC should rise up to 15VDC then the IC will start driving the transformer which at that point the AC from AUX winding of the transformer is fed to fusible resistor R913, the output side of R913 (verify that it is OK, it is probably low Ohms resistor between 1~10 Ohms range) feeds the rectifier by D911 and filtered by C911 to supply the steady DC to run the IC, probably around 18~20Vdc range (Max VCC is 30V).Never stop learning
BTW, I am curious as the resistance between the VCC and the GND pin is.Never stop learning
So the VCC on the 1M0880 is still low and fluctuating?Never stop learning
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... -
by khelaneHello
I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
Is there a way... -
by chronic519Hello.
GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
Found issue with a RAM block
Replaced, green lines gone.
Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
Used a good card to test and same results low errors 32+.
I am just search for some form of command to do a full test on the GPU.
I just ran the mats command with my good GPU and passed after roughly 40 min.
The repaired one, ran... -
by hemant_2222Hello Guys,
Greetings!
Hope you all are doing well.
I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
PCM1681DBQR - IC263 and it worked fine.
Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
by alltvrepairsHi,
i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
Appreciate your help....2 Photos - Loading...
