Faulty generic 5V 2A AC adaptor ('wall wart')
  • tiff_lee
    • Feb 2016
    • 17
    i've got a faulty 5V 2A ac adaptor and was just looking for some pointers to identify the problem, sure I could buy another one for next to nothing but i'd rather try and fix it if only for the learning experience.
    Here are some pics:
    Output voltage was approx 5.3V but as soon as I connected a load (only had a 6 Ohm 50W resistor to hand) the voltage dropped to 1V even though the load current at that resistance is less than half what it should be capable of.
    Given the complex PSUs some of you work on no doubt this is childsplay for many so please be nice!
    cheers, Lee
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Faulty generic 5V 2A AC adaptor ('wall wart')
    Probably bad caps causing the fault, do you have an esr meter to check the caps ?
    • tiff_lee
      • Feb 2016
      • 17
      Unfortunately not only a Uni-T multi meter.
      Any recommendations for one? I see plenty of cheap ones on ebay but when I searched previously I recall people saying they were not 'true' ESR meters or something?
      Edit: Now reading some older threads on here regarding the ebay ESR meters
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Without an ESR meter, I'd start with replacing C2 then the output caps.
        • CapLeaker
          Leaking Member
          • 8352
          change three caps (starting cap next to the PWM, and the 2 on the output) and be done with it.
          • Dumah Brazorf
            • Jun 2013
            • 179
            • Italy
            Change the keyboard too. It looks horrible!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Am I the only one that doesn't see any pictures?
                • 31304
                no, i dont either.
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  photofucket, aka M$, strikes again.
                  Uploaded/attached to the thread:
                  That said, I'd just as soon crush this thing, for obvious reasons.
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • tiff_lee
                    • Feb 2016
                    • 17
                    Photobucket links dont work here? I could see them in the post ok?
                      • 31304
                      i like that supply, it's simple and clean - even has a pi filter.
                      i would just replace the 3 low voltage caps with panasonic FR's and be happy.
                      i know it doesnt have an input choke or anything, but who cares - it's tiny.
                        • 31304
                        oh yea, wash that keyboard!
                        • tiff_lee
                          • Feb 2016
                          • 17
                          ha yeah.. I think the keyboard needs burning tbh
                          • tiff_lee
                            • Feb 2016
                            • 17
                            So just for closure, I replaced all the caps and now it works again as it should.
                            I did order one of those ESR meters from ebay so once that gets here ill check the old caps just to see which one actually failed.
                            Cheers for the help.
                            • cyjun1990
                              • Jan 2016
                              • 16
                              • Philippines
                              wow! congrats...
                                • Jul 2011
                                • 6070
                                If I buy any switching power supply I change cap on site if they are NOT well know good brand name caps
                                This is a 5 volts @ 5 amp power supply
                                It had some green colored sleeve that had printed " Low ESR " on them no brand name
                                I know this a hack job how ever it had 2200uf@10 volt caps were 12mm Dia and 17mm tall
                                It end up with a 10mm Dia and 30mm tall
                                It had three of them and one that was 1000uf@10 Volts 8mm Dia and 15mm tall it end with a 8mm Dia and 20mm tall
                                I could NOT find any with that size at Digikey I look for some time so I did a hack job on the case
                                I would use KY,KME,FC or FR
                                • zx8401
                                  Phantom Fiddler
                                  • Aug 2013
                                  • 49
                                  LOL i do like your easy access to the capacitors
                                  You can keep an eye on the tops for bloating or leakage, it reminds me of the valve amplifiers that proudly show the valves sticking out of the case.
                                  Makes it more expensive you know
                                  • tiff_lee
                                    • Feb 2016
                                    • 17
                                    ESR meter arrived today, one of the 470uF caps had a value of 117uF and ESR of 39Ω
                                      • 31304
                                      which meter did you get?
                                      • tiff_lee
                                        • Feb 2016
                                        • 17
                                        I actually ordered 2, this one
                                        http://www.ebay.com.au/itm/291601505...%3AMEBIDX%3AIT
                                        and the diy kit with rotary encoder
                                        http://www.ebay.com.au/itm/301837290...%3AMEBIDX%3AIT
                                        I recall reading though your thread modding your own, some top tinkering
                                          HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 08:50 AM
                                        • jayjr1105
                                          9v super basic wall wart issue
                                          by jayjr1105
                                          This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output....
                                          03-03-2022, 08:32 AM
                                        • JarzabekPZ
                                          HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                                          by JarzabekPZ
                                          I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                                          08-08-2025, 03:40 AM
                                        • Spudgun
                                          Why doesn't current just bypass faulty capacitors.
                                          by Spudgun
                                          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                          04-01-2025, 10:33 AM
                                        • Simonc123
                                          CH341A bios chip wont fit 1.8v adaptor holder
                                          by Simonc123
                                          Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
                                          Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
                                          03-09-2025, 08:54 AM
