What is this that has blown?
  • mikay786
    • Aug 2014
    • 765
    Re: What is this that has blown?
    So the 50v are the correct value?
      I would have use 100V rating minimum. The caps are exposed to about 78 peak Voltage.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #43
        Probably best to use 100v one to limit damage in future cases mate.
        • mikay786
          • Aug 2014
          • 765
          Alright I'll order some 100v
          Can I use the ones installed for testing purposes as wont get replacements till Monday
          And we're the original ones 50v?
            You can leave them out for testing purpose. The cap are there for to reduce Diode switching noise.
            • mikay786
              • Aug 2014
              • 765
              Ok Maplins only have 2 100v 0.1uf caps !!
              As I need four can I use higher voltage ones? Say 125v or 150v and mix and match?
                >100V will be fine.
                GALE 3080.
                • fzabkar
                  • Mar 2009
                  • 772
                  Originally posted by budm
                  BTW, what is the P/N of the power amplifier IC?
                  TDA7294
                  https://cdn.badcaps-static.com/pdfs/...6e7c926434.pdf
                  I can't see how +/-39VDC is reduced to +/-11V. ???
                    'I can't see how +/-39VDC is reduced to +/-11V. ???'
                    The 2SC1815 & 2SA1015 and the Zeners are for the linear regulators.
                    • fzabkar
                      • Mar 2009
                      • 772
                      The 2SA1015 and 2SC1815 are rated for 50V, 150mA, 400mW:
                      (2SC1815)
                      (2SA1015)
                      A voltage drop of 28V (= 39 - 11) at 15mA would exceed the power rating. Does this mean that the other board is only drawing around 10mA at +/-11V? The power LED must be drawing at least 5mA.
                      • mikay786
                        • Aug 2014
                        • 765
                        Went to maplins again and they only had 3x 150v and 1x 180v capacitors.
                        Will these be ok?
                        And just googling the numbers on them I'm not sure they are the correct ones
                        151j + 181j
                        He was saying all there parts draws are a mess as workers keep putting stuff back in the wrong place.
                        Also picked up some new fuse holders as per stj's recommendation
                        • fzabkar
                          • Mar 2009
                          • 772
                          Those are not voltage ratings.
                          151J = 150pF
                          181J = 180pF
                          Neither capacitor is suitable.
                          • mikay786
                            • Aug 2014
                            • 765
                            wtf maplins are bloody useless, I told him 0.1uf
                            • mikay786
                              • Aug 2014
                              • 765
                              Are you sure I need 100v, I cant seem to find any on ebay or farnel in ceramic disk
                                • 31013
                                you dont need disc, you can use multilayer - little square ones.
                                as long as they are ceramic 100nf (0.1uf) at 100v minimum
                                maplin has been a waste of space for years btw.
                                farnell has free delivery with no minimum order these days - so use farnell.
                                • mikay786
                                  • Aug 2014
                                  • 765
                                  what about film ones?
                                  yea maplins is open late and is down the road, plus weekend was coming up so earliest I would get from farnel would be Monday.
                                  Truly dislike maplins!
                                    (2SC1815)
                                    (2SA1015)
                                    If you look at the board, there are two 470 Ohms 1W resistors, each one for feeding the Collectors of the Transistors, the Zeners are probably 12V, so they are not feeding the transistors directly with 39V.
                                      • 31013
                                      here you go:
                                      http://uk.farnell.com/vishay-bc-comp...rad/dp/1141783
                                        • 31013
                                        i had to school the counter staff once over how to read the colour-codes on the resistors.
                                        they didnt know the colours actually meant anything!!!!!!!!
                                        • mikay786
                                          • Aug 2014
                                          • 765
                                          http://uk.farnell.com/multicomp/mcrr...rad/dp/1216434
                                          Are these ok to use?
                                          • Steph.hen
                                            Bridge rectifier identification part number KPB305G
                                            by Steph.hen
                                            Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                            I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                            08-29-2024, 09:52 AM
                                          • mpn78
                                            Fujitsu Q556, What capacitor for bridge rectifier?
                                            by mpn78
                                            Hello
                                            My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                            There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                            Thanks....
                                            04-05-2022, 12:31 PM
                                          • leotron
                                            XFX 850w blown bridge rectifier.
                                            by leotron
                                            Hi, a friend of mine gave me this broken power supply, aparently it's the rectifier bridge that was damaged months ago. He took it to a technician and they didn't have the repair tools necesary but they remove the original bridge rectifier since it was damaged(burned). I have some of this rectifiers laying around, but they are not the same. The original its a pair of GBJ1506
                                            And I have KBL06 , KBL406 , RVB406, D5SBA20, D3SBA60, GBU608. Most of them have similar values to the original, but I'm not planning to use the PSU at full load (ie: SLI, an I7 processor, etc).
                                            TomsHardware...
                                            02-05-2020, 07:59 AM
                                          • EasyGoing1
                                            Reading input and output of bridge rectifier on the same scope?
                                            by EasyGoing1
                                            I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                            When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                            06-26-2022, 12:52 AM
                                          • nicktasios
                                            Macintosh Quadra 840AV PSU
                                            by nicktasios
                                            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                            12-22-2024, 05:07 AM
