ATX stby voltage too low +1.8v
  • kamel
    • May 2011
    • 129
    • TUNISIA
    hi!
    Got fuj. siemens esprimo c5910 with power issue : no reaction to switch.
    To make pc start, need to power up PSU alone without load (by grounding pson) before connecting it to mobo
    All PSU voltages are checked ok without load (stby voltage=+5v), but when connected to mobo, stby voltage becomes low : 1.8V.
    Steps taken : swapped PSU with a good working one, pc starts normally.
    Concluded that PSU is culprit, and particularly stby rail.
    Opened PSU case, all caps are looking fine.
    Any idea as what are the main stby rail check points and where to dig further to help fixing this issue ?
    Thank you
  • SteveNielsen
    Retired Tech
    • 2327
    Re: ATX stby voltage too low +1.8v
    Post the make and model of the psu and good pics of the psu guts, top and bottom of the board. then someone may be able to help ts it.
    • CapLeaker
      Leaking Member
      • 8352
      Any hi res pictures from top and bottom to go with this? I think that this is a "special" PSU as it is rectangular tube shaped and does not use a standard ATX PSU case.
      • kamel
        • May 2011
        • 129
        • TUNISIA
        hi,
        PSU model : NEWTON POWER LTD MODEL : NPS-210BB A REV : 08 -210W
        Unfortunately, no specific schematic found on the net.
        Here attached some photos.
        • kamel
          • May 2011
          • 129
          • TUNISIA
          Here newly attached reduced size photos, if previous photos are slow to load.
            • 31304
            probably bad caps on the standby causing voltdrop when there is actually a load.
            specially in that, it's packed like a train during rush-hour!
            • kamel
              • May 2011
              • 129
              • TUNISIA
              Sorry Board1 and 2 uploaded were same.
              Here attached real Board2 of PSU.
              • kamel
                • May 2011
                • 129
                • TUNISIA
                Caps are looking quite fine. If no other fix found, will change all caps on stby rail.
                • CapLeaker
                  Leaking Member
                  • 8352
                  x2 what stj said.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    They can look "fine" but still be bad. Without an ESR meter, you can't really know for sure.
                    So in cases like yours, it is best to change them. I've seen bad caps (that looked physically good) make the 5 VSB act weird in more than one occasion.
                    • nimit
                      • Oct 2015
                      • india
                      ATX stby work proper but no output
                      i have i ball xpx-252 psu in which i get standby voltage perfectly, & also get power on volt but i cant get final output of 5,12,3.3 etc
                      i have checked al componant all is well. i have found that power transformer not get voltage in it's primer nor secondary , i dont know how to check drive pulse in circuit.
                      please guide me.
                      i am beginner.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        @ nimit: start a new thread and post some pictures of your power supply there.
                        • angelos
                          Hisense LCD42W60P Television
                          by angelos
                          Hi Guys,
                          I have this 2008 lcd tv that uses ccfl lamps. The tv is stuck on standby. This is what I have noticed. The standby 5Vs voltage is not 5V but rather 3.28V. There is a 14V rail as well but that measures ok. I put my volt meter on the 5Vs rail and switch on the 220Vac. I noticed that the 5Vs rail goes to 5.1V and quicky changes to 3 28V and steady.
                          I unplugged the main board and ccfl lamp wires and tested the power supply separate from the tv without load and put a 470 ohm resistor to the stby rail to force the tv on.
                          1. Pfc circuit activates and mains smoothing cap is...
                          07-12-2025, 11:44 AM
                        • Instafixx
                          Macbook A2179 820-01958
                          by Instafixx
                          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                          I checked the Power Sequences below and found this -
                          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                          05-20-2023, 05:19 AM
                        • bimole
                          Weird behavior on 3.3V rail of a CORSAIR CX600
                          by bimole
                          A colleague gave me an apparently ill CORSAIR CX600.
                          He told me that he heard a banging noise, and smelt the magic smoke.
                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                          It's another story on the 3.3V rail...
                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                          02-13-2025, 04:49 AM
                        • ROONEY50
                          Voltage Injection on 3.3v rail
                          by ROONEY50
                          I am repairing a laptop that has a short on it's 3.3v rail. I injected 1v on the rail and it was pulling 200mv but can't find any heat anywhere with thermal camera or alcohol. What else can I do to find what's shorted?
                          10-11-2025, 12:37 PM
                        • jaroslav.psenicka
                          Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                          by jaroslav.psenicka
                          I have a Lenovo Yoga 13 Panasonic here, when powered
                          • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                          • most voltage rails seem OK (see image below, red labels)
                          • resistnace to ground mostly seem OK as well (blue labels)
                          the only suspicious is the 0.0V rail (2nd from left, top row)
                          • the resistance to ground is rather low (1.9ohm)
                          • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                          also tried new BIOS, no change
                          I can't find a schematics for the board - can some of you gurus look at the voltages?...
                          05-02-2024, 05:59 AM
