Hisense LCD42W60P Television
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4427
    • Italy - Milan
    ok so replace all secondary el.cap. , bye
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Yes, i have already done that. TV is working fine. Thanks for your input.
      Regards
      Angelos
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • bimole
        Weird behavior on 3.3V rail of a CORSAIR CX600
        by bimole
        A colleague gave me an apparently ill CORSAIR CX600.
        He told me that he heard a banging noise, and smelt the magic smoke.
        After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
        I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
        It's another story on the 3.3V rail...
        I have some devices to test deeply PSUs (scope, AC source, electronic load)...
        02-13-2025, 04:49 AM
        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
        by momaka
        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
        http://www.rmac.kingwin.com/products.../abt_650MM.asp
        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
        What mostly drew me into buying it is its 2x PCI-E power connectors...
        03-29-2022, 11:34 PM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • AJ847.63e
        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
        by AJ847.63e
        Hi Folks,
        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
        05-06-2025, 10:37 PM
