Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Macbook A2179 820-01958
  • Instafixx
    • Jul 2022
    • 376
    • India
    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
    I checked the Power Sequences below and found this -
    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced from U6960, which uses PPBUS_G3H as its VIN.
    PP3v3_G3H: Normal voltage is ~3.3v. Produced from U7650/Q7680.
    Once the PMU (U7800) receives power from PP3v3_G3H, it will initialize and begin producing rails to power the T2 chip.
    Important note! DDR/CPU rails here are referring to the T2 chip, which is basically a CPU with its own RAM in a package on package design. These rails are not referring to the Intel CPU or system RAM.
    PP1v8_SLP_S2R: Normal voltage is ~1.8v. Produced from U7800.
    PP1v8_AWAKE: Normal voltage is ~1.8v. Produced from U7800.
    PP1v8_SLPS2R_PMUGPIO: Normal voltage is ~1.8v. Produced from U7800.
    PP1v1_SLPS2R: Normal voltage is ~1.1v. Produced from U7800.
    PP0v8_SLPS2R: Normal voltage is ~0.8v. Produced from U7800.
    PP0v82_SLPDDR: Normal voltage is ~0.82v. Produced from U7800.
    PP3v3_AWAKE: Normal voltage is ~3.3v. Produced from U7800.
    PPVDDCPUSRAM_AWAKE: Normal voltage is ~1.06v. Produced from U7800. [Getting 0.8V]
    PP0v9_SLPDDR: Normal voltage is ~0.9v. Produced from U7800.
    PP1v1_SLPDDR: Normal voltage is ~1.1v. Produced from U7800.
    PP1v2_AWAKE: Normal voltage is ~1.2v. Produced from U7800.
    PPVDDCPU_AWAKE: Normal voltage is ~1.06v. Produced from U7800. [Getting 0.5v]
    Once the T2 is powered from the above rails, it will read its ROM (U4770.) The T2 will then begin to start its boot up process, in which we will initialize the below rails.
    PP3v_G3H: Normal voltage is ~3.0v. Produced from U7800, powers some PCH functions.
    PP5v_G3S: Normal voltage is ~5v. Produced from U7650/Q7660.
    PP3v3_G3S: Normal voltage is ~3.3v. Produced from U8210.
    PP1v8_G3S: Normal voltage is ~1.8v. Produced from U8220.
    The SSD power is then enabled to allow the T2 to boot BridgeOs.
    PP1v8_VCCQIO_SSD0: Normal voltage is ~1.8v. Produced from U7800.
    PP0v9_SSD: Normal voltage is ~0.9v. Produced from U7800.
    PPVCC_NAND_SSD0: Normal voltage is ~2.5-2.7v. Produced from U9060.
    Once the SSD is powered, and BridgeOs boots, the T2 will signal the device to power on if the power button is pressed. The 820-01958 will assert the pwrbtn signal if the charger is plugged in with the battery disconnected and auto start given the device is in functional condition. We will then expect the following rails once the machine is at this stage in the power up sequence. These rails will primarily power the PCH section of the CPU. NOTE: BridgeOs failing to boot will result in the following rails to be missing.
    PP3v3_S5: Normal voltage is ~3.3v. Produced from U7800.
    PP1v8_PRIM_PCH: Normal voltage is ~1.8v. Produced from U7700.
    The PCH will then de-assert (pull low) PM_SLP_S4_L and PM_SLP_S5_L momentarily to enable the next stage in the power sequence.
    PP1v8_S3: Normal voltage is ~1.8v. Produced from U8250. (Powers system RAM.)
    PP1v1_S3: Normal voltage is ~1.2v. Produced from U8100/Q8100. (Powers system RAM.)
    PP0v6_S3: Normal voltage is ~0.6v. Produced from U8150. (Powers system RAM.)
    The PCH will then de-assert (pull low) PM_SLP_S3_L and PM_SLP_S0_L momentarily to enable the final stage in the power up sequence.
    PPVCCIN_AUX_PCH: Normal voltage is ~1.8v. Created from U7400/Q7401. Incidence in power sequence unknown, likely comes online before the rest of the PCH rails. Likely powers internal level shifting in the PCH.
    PP1v05_PCH_CPU*: Normal voltage is ~1.05v. Likely internally created within the PCH, sourced from another rail generated from U7800. May explain "clicking" sound when these boards experience CPU failure.
    PP1v1_S0SW: Normal voltage is ~1.0v. Produced from U8240.
    PP1v8_S0SW_CPU: Normal voltage is ~1.8v. Produced from U8245.
    PPVCC_S0_CPU: Normal voltage is ~1.8v, but can drop when the CPU is under load. Produced from U7100/U7210/U7220/U7230. [Getting 0.1V]
    Only 2 Rails show lower Voltage. Getting clicking sound from the board as well. is it repairable ?
  • Instafixx
    • Jul 2022
    • 376
    • India
    Re: Macbook A2179 820-01958
    PPVCC_S0_CPU = 45 ohms
    PP1V1_S3 = 4.72 ohms
    PP1V8_S0SW_CPU = 1.27 k ohms
    PP1V05_S0_CPU_VCCST = 540 ohms
    PP1V05_S0_VCCSTG = 321 ohms
    Resistance of the CPU Power Rails
    • bobtib
      • May 2018
      5 ohms is a fault condition here, did you ever get to the bottom of the problem?
      I have the same board with the same problem.
      • Instafixx
        • Jul 2022
        • 376
        • India
        No. I couldnt.
        • Gueric
          • Feb 2025
          • 81
          • France
          I think I'm a bit late to the party, but if you're hearing a clicking sound, the probability of your CPU being fried is very high.
          • crnimrki
            MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime
            by crnimrki
            MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime. On power on fan spins 5 seconds then stop and again spin and stay spinning.
            CPU Warm, DVD Drive not spinning, Mouse on USB Port inactive. No beeps without RAM DIMM-s.
            PPBUS_G3H - 12.55V without battery, 11.99 with battery charging
            PP3V42_G3H3.39V
            PPVCORE_S0_CPU - 0.98
            RAM VOLTAGE 1.49
            Where to search...
            01-02-2025, 12:51 PM
          • alro7779
            MOSFET? Is its voltage reading normal?
            by alro7779
            Hello, guys!
            Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
            06-19-2025, 08:19 AM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
