My new Seasonic has questionable caps.
  • i4004
    • Oct 2006
    • 2029
    #121
    Re: My new Seasonic has questionable caps.
    pcbonez and gdement ++
    • starfury1
      • May 2006
      • 1256
      #122
      just on JG OW articule
      the caps were from what I could tell at a quick look at the article
      Fuhjyyu (is it TMR ?) Neopower 480W
      Capxon on the other FSP600-80GLC
      I think both got Chemi-Cons KZE and KY
      Thats an interesting point you make bonez
      if these had a higher ESR lower ripple....
      I was "assuming" the replacement were of better specs then those replaced
      which sort of didn't make sense....
      anyway no guru here
      cheers
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • gonzo0815
        • Feb 2006
        • 1600
        #123
        I think KZE is ok, but the KY are from my point of view not the ones, i would have put in there.
        My favourite would have been Panasonic FM, Rubycon ZLH, Samxon RS or GD or Pany FC.
        Sure, apart from the ripple measurement, the Antec from OW is working fine, and it would probably make no difference in real world usage.
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          #124
          I think so: the graphs have a V/Div value of 0.01 instead of jonnyguru's usual 0.05, so they are emphasized 5 times. As OklahomaWolf stated in the forum, the recapped units have a ripple value still under Atx recommendations, so they aren't bad, only worse than before when speaking to ripple and [a lot] better when speaking of reliability.
          Zandrax
          Have an happy life.
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            Well, I finally got time to recap the dumb thing. Unfortunately my ISP is being today, so I'll upload the pics when I can. Right now it works about 1/3 of the time, and goes about 1/100th of the normal speed. They'll probably stumble in there hung over tomorrow morning and flip the switch or something to fix it.
            Stupid wireless internet.
            Edit: Oh, and the power supply does work well after the recap.
            A man convinced against his will is of the same opinion still.
            • acstech
              GrumpyModerator
              • Jul 2007
              • 1432
              Ok here they are:
              http://i231.photobucket.com/albums/e...h/hpim0517.jpg
              http://i231.photobucket.com/albums/e...h/hpim0518.jpg
              What you're looking at is a mix of Panasonic FC, FM, and Samxon GD and RS.
              • starfury1
                • May 2006
                • 1256
                #127
                ROTFL
                Iv'e heard ISP's called a lot of things but , thats classic
                Good to hear its done and working
                Thanks for the peep show of them
                Cheers
                • shadow
                  • Feb 2007
                  • 732
                  I regularly called my former ISP !
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    My word for ISP has 4 letters.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • zandrax
                      Hit and miss
                      • Dec 2007
                      • 1157
                      • Italy
                      #130
                      Let me guess: the first is an f ... yeah, as in Read The Fine Manual.
                      Zandrax
                      Have an happy life.
                        by momaka
                        03-12-2025, 03:42 PM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
                      • madscientist750
                        Replacing electrolytic caps by solid caps on old motherboards
                        by madscientist750
                        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                        10-19-2025, 06:10 AM
