APC Smart UPS 1500
  • true_blue
    • Aug 2014
    • 24
    APC Smart UPS 1500
    Hi guys.. I was wondering if anyone has had any experience with this UPS as mine stopped working all of a sudden and just emits a solid audible tone when turned on.
    I think it is probably the battery.. but for it to just work fine and then not within a day seems strange.. so before I buy a new battery, are there any tests I can do on the UPS itself to see whether anything else is the cause?
    Also, where do you guys generally buy your replacement UPS batteries? I have read somewhere that a normal motorcycle battery will do the trick, and the branded APC ones are just a rip off. Is this true?
    Sorry if this post is in the wrong section, I figured it would better fit in with PSU's rather than just "General Electrical"
  • diif
    • Feb 2014
    • 6978
    • England
    Re: APC Smart UPS 1500
    Does the tone last for 60 seconds ? It should go off every few hours to inform you the battery is on its way out. Have you got the APC software installed ? you can disable the warning in there.
    Having recently seen a photo of a UPS that used cheap UPS batteries with them both melted inside, personally i would only use decent batteries.
    • true_blue
      • Aug 2014
      • 24
      Thanks for your reply!
      I think the tone was like that yes. It lasted quite a while then went off and came back on an hour later or something. But the battery didn't work at all, and as soon as I cut power to the UPS it failed completely. No battery backup even for a few seconds.. that is what I find strange. So could it still be the battery or would that be the UPS itself?
      I always expected it to sorta slowly die out until it couldn't keep the power up for more than a few seconds in the end.. not just a sudden death.
      Cool ok.. and where would you buy your battery if you had to? Ebay seems like it could be full of fakes.. and the delivery is obviously pretty costly for the weight of them.
      Cheers mate!
        I would try to get it locally so you can see the date codes on the batteries, you do not want to buy the batteries that has been sitting on the shelf for a long time, see page 16.
        http://www.stevejenkins.com/blog/201...a-cheaper-way/
        • diif
          • Feb 2014
          • 6978
          • England
          Have you got he APC software installed ? The status is monitored through that from what I remember with the alarm sounding when the battery has fallen below its working level.
          It's not something I've had to order but a quick Google turns up a couple of uk websites that focus on batteries. The one I've just looked at did £4.99 shipping.
            • 31026
            so post the links.
            • diif
              • Feb 2014
              • 6978
              • England
              My bad, I was on my phone.
              http://www.mdsbattery.co.uk/shop/pro...uctGroupID=755
              And
              Hardwareexpress.co.uk
                • 31026
                probably worth linking this.
                http://www.rapidonline.com/Electrica...Acid-Batteries
                • true_blue
                  • Aug 2014
                  • 24
                  Wow thanks for the info guys. I read that great blog about the UPS batteries.. you should all read it if you haven't already! Thanks BudM!!
                  After following it, I was able to find a brand new battery for £25 on ebay with free delivery!!, and like the guy says on his blog.. it is likely just ONE unit that is dead.. so I can keep one of them and use the new one together with it.. if not I will find another somewhere else.
                  But apparently all these batteries are the same, regardless of brand name and I was right in my original post about APC and the like ripping people off. Its shocking some of the crap they pull.
                  Oh also, yes I had the APC software installed and was getting a error code which pointed towards dead battery.. but I just had a hard time believing the battery could go from (good for 2-3 hours powering my PC) to dead in a day. Is that normally how those batteries die? I thoroughly expected it to be a slow death where the capacity would just dwindle away.
                  If the UPS itself is faulty.. its only a £25 battery wasted which I am sure I can find a use for somewhere else. Fingers crossed though!!
                  I would also like to ask you guys if it is possible to repair/refresh the surge protection part of a UPS so that it is back to new? As I know that surge protection is only good for so many uses.
                  Cheers!
                    • 31026
                    battery's are NOT all the same.
                    some are designed to be constantly flattened and recharged - for booster-packs, lanterns etc.
                    some are designed to just sit on tricklecharge waiting without damage - for emergency lighting/UPS etc.
                    and some are designed to handle very fast high current discharge - for starting engines for example.
                    the type you need for a UPS is the cheapest btw.
                    • true_blue
                      • Aug 2014
                      • 24
                      Oh what I meant was there are no "special" type UPS batteries.. they are just common wheelchair / motorcycle batteries with an APC sticker whacked on.
                      If this £25 deal works out I will be really thrilled! Even the old APC SmartUPS 1500 I have is still pretty expensive to replace. Still around £275 here plus delivery!
                      Any thoughts about my surge protection question? I was reading an article the other day about surge protectors only having a certain amount of "goes" before they stop being useful. So I thought maybe there is a way to replace the parts inside them to reset them?
                      Cheers!
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        These are three years old and came out of a smart UPS 1000.
                        To echo stj, not all batteries are the same.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          you will have to replace both.even if the "good" one is usable it wont for long.
                          worse is its float current will be different than the new one and 1 will get overcharged.
                          order another and try to get it from the same lot as the first.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            was that a cell failure or a runaway charger?
                            hopefully you checked the float at the batteries rather than powerchute!
                            • true_blue
                              • Aug 2014
                              • 24
                              Yeah as long as it works for a bit ill know the ups is still ok so that is my priority for now and then I'll try get that 2nd Newy. Sadly the listing had only 1 left but I'm gonna message them about more.
                              Cheers!
                              • Behemot
                                • 4845
                                • CZ
                                If it is more than 4 years old, definitelly replace all 22uF capacitors. General purpose, I use Chemi-Con KMG.
                                • sambul83
                                  • Mar 2015
                                  • 134
                                  If it doesn't, look through this thread: APC Back-UPS 1300 not charging battery.
                                    @sambul, what happen to that thread? You never give us the follow-up.
                                    • sambul83
                                      • Mar 2015
                                      • 134
                                      Sorry, I will definitely do that in a few days. Your help is unforgettable!
                                      • true_blue
                                        • Aug 2014
                                        • 24
                                        Battery came today so I'll try it tomorrow if I get a chance. I also built my esr reader on Thursday so I can test the caps as well if needed. Cheers
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • flat-earther
                                          Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                          by flat-earther
                                          I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                          To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                          I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                          The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                          So I need to connect another battery in...
                                          06-08-2025, 02:00 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • huzo
                                          HP ELITE X2 1013 G3 weird battery issue
                                          by huzo
                                          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                          01-31-2025, 12:09 AM
                                        • trepachka
                                          iPad Air A1475 Boot loops after replacing battery
                                          by trepachka
                                          This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                                          The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                                          I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                                          11-08-2024, 03:17 PM
