2.4v PSU for electric screwdriver
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    My sis gave me a cheap B&D cordless driver a few years ago. It never would hold a charge for long even on the shelf but I used it anyway for a couple of years. I like the size and weight of it and having pretty bad arthritis in my hands it was sorely needed.
    First the spring for the ac prong release button broke and started poking out, which I removed before it had the chance to short the ac main. Then the batteries died and wouldn't charge.
    I removed the batteries and charger board and soldered two wires directly to the direction/power switch and the motor works fine although a bit fast from two 1.5 flashlight cells as the motor is rated for 2.4v. I want to convert it to a corded driver. I don't need cordless while working on my bench and don't want to have to wait for batteries to charge in order to use it either.
    I tried a few different PSUs, wall-warts, etc. but nothing would supply enough stall current to get it turning. I did some current readings, it pulls over 3 amps at stall and 1.5 amps free running. I use an old Delta 145w ATX PSU on my bench for powering drives etc. and decided to try the 3.3v output to run the screwdriver, which worked.
    I don't want to burn the motor out with over voltage so I connected a 3 amp silicon diode in series and it dropped the voltage near perfect to 2.45v. This is fine for the time being but I'd like to build a PSU into the handle of the driver and just run an ac cord to the outlet but haven't had luck finding an appropriate circuit.
    master hoarder
    • May 2008
    • 12175
    Re: 2.4v PSU for electric screwdriver
    Maybe try to find a 5V, 2A, 2.5A, or 3A AC power adapter. Those should be somewhat more common (usually they are for some modems and routers). Most regulate the output voltage with a 431 shunt and opto. Just remove bottom resistor in the 431's feedback network, and that should give you 2.5V. You may also have to swap the output rectifier, though.
    3A @ 2.5V is 7.5W, so an adapter like that should have no problem.
      • 31218
      http://www.dx.com/p/lm2596-digital-d...rk-blue-360654
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        Thanks for the tips guys.
        The LM2596 looks good, the only concern I have is the stall current going over 3A.
          • 31218
          i'll go look for something more powerfull then
            The inrush current will be a lot higher than 3A.
              • 31218
              10A
              http://www.dx.com/p/10a-dc-cnoverter...-supply-214277
              15A
              http://www.dx.com/p/15a-dc-4-32v-to-...gulator-219807
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Bud: Exactly. I know the meter can't show the inrush current fast enough so it's got to be well over the 3A I saw. I could lock the screwdriver and measure it but don't want to burn anything out.
                stj: I need to go ac to dc, not dc to dc. Using one of those I'd still need to run it off a separate PSU. So I may as well run it off the ATX PSU with the diode It's just a little clumsy is all. I'm not sure if a transformer to work that will fit in the handle exists.
                  I think by the time you get all the parts, it will be a lot more than that B&D is worth.
                    • 31218
                    well i have a really nice electric screwdriver with lithium-ion battery's that cost me £15
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      My desire is to not use batteries at all.
                      Anyway, thanks for the input guys, you've helped me realize doing what I want is not practical nor cost effective.
                      I'll just use it as a "screwdriver workstation" using the small ATX PSU and diode. I can put the PSU out of the way.
                        master hoarder
                        • May 2008
                        • 12175
                        That's similar to what I did with a cordless 9.6V drill I had. Except I wired it to a Xbox 360 PSU. Still works fine, though I could have used thicker wire (20 AWG wire actually heats up a bit with a few amps of continous load on it). Link of the ugly mess here:
                        https://www.badcaps.net/forum/showth...705#post294705
                        Anyways, I'm pretty sure the 5V adapter will work. Most will shut down and restart if your stall current is too high, so no need to worry about the inrush current too much. If you really are, just add a 2200 uF cap or two in there, and that will do it.
                        Or you can use the setup you have now. In that case, I'd say just run it straight up on 3.3V. Pretty sure the little motor will take it just fine. Most can take up to 4 to 5 times their rated voltage and they will still work. Post a picture of it if you want.
                        Also, run a 3rd extra wire to your desk (or to the screwdriver) and hook it up to PSON on the PSU's end. On the screwdriver's wire, put a little switch between that wire and ground. Now you can turn ON the PSU easily as you pick up the screwdriver and then turn it OFF when you are done using it.
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          Not sure what 5v adapter you mean.
                          Here's a pic of the motor.
                            • 31218
                            looks just like the one in my old bosch screwdriver - RIP.
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Jeez, I took the thing apart again to get that picture and had pita experience getting it back together. I have no idea why as I had zero problem with that before. Plus I put the motor in backwards so the polarity reversed at the switch! I guess I'm getting dumber by the day now Actually the trick I finally figured out was having the pinion in the gear cluster, not on the motor shaft.
                              It's ok tho' I have to take it apart again to replace the short leads with a cord.
                                master hoarder
                                • May 2008
                                • 12175
                                I meant you can use a 5V power adapter rated for 2A to 3A. 2A and 2.5A adapters tend to be somewhat common. Look in a pawn shop or yard sale next time and you might just find one.
                                Typical 380-size motor (you can see that on its label). Those can usually take A LOT more than 2.4V. Well, I guess it depends on what size of wire they used for the rotor inside (the thicker the wires, the rated voltage would be lower and stall current current). But these tend to be quite common in bigger toy RC cars that run on 7.2V and 9.6V batteries. So up to 12V will likely give it no problems. You'll just have a supper fast screwdriver .
                                  • 31218
                                  dont overdrive it unless it has a variable clutch, you'll just end up stripping threads!
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    Thanks for the info guys. I'm just going to use it 2.4v, normal speed is fine for me. Even at 3.3v it seems nearly twice as fast, too fast for what I want.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8331
                                      use this power supply and adjust the voltage to that what you exactly need. The power supply has a voltage adjustment.
                                      http://www.dx.com/p/5v-3-8a-regulate...41#.VJNd7ZACDA
                                      here is another one:
                                      http://www.aliexpress.com/item/5V-10...508775940.html
                                        • 31218
                                        if you back up and read the thread you will see we did the DX stuff.
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • redwire
                                          Exploding motor cap on Ryobi electric pressure washers - product recall
                                          by redwire
                                          Exploding motor cap on Ryobi electric pressure washers.
                                          Recall is for 764,000 units and 16,000 sold in Canada.
                                          "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
                                          Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
                                          Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
                                          Safety vent too expensive! DELETE DELETE
                                          08-31-2025, 11:03 AM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • SolomonMan
                                          Electric Motor Question....
                                          by SolomonMan
                                          All,
                                          Yesterday in the morning the fan was fine. Its approximately 10 years old. Its one of those high Velocity types.
                                          In the afternoon I noticed it was not running any longer.
                                          During the investigation, I confirmed the wiring, confirmed the 3 way switch is fine, the Capacitor measures the correct Microfarads. So I went to the Motor;
                                          No smell of burnt and it spins very easily. I started to measured the continuity between the 6 wires.
                                          I have included a diagram from a YouTube video I found but basically the wiring is identical. The only exception...
                                          10-29-2023, 08:02 AM
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
