2.4v PSU for electric screwdriver
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8331
    Re: 2.4v PSU for electric screwdriver
    Originally posted by stj
    if you back up and read the thread you will see we did the DX stuff.
    I see DC to DC converters, not AC to DC.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5040
      • New Zealand
      You can probably find a wall-wart etc the right spec 2nd hand on eBay if you wait a while and keep a lookout.
      -David VanHorn
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        Such a wall-wart may come my way. In the meantime I have screws to deal with and hands that don't like it so I'm using the old Delta ATX PSU. Installing an AC switch, cut off unused wires at the PCB, install pwr-on light, etc. It's all old parts I have, I have no money to spend so it's all good and better than collecting dust in boxes.
        Concerning the ac-dc converters, those I've seen are low ac input, not suitable for this.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          BTW, mod'ing the PSU I've wanted to do anyway because I already use it as a general purpose DC voltage source on my bench so I may as well at least give it a proper on/off ac switch and an on LED anyway. I think I'll hook up the LED and resistor to pwr ok line and make use of that wire.
            Great Sage é½Šå¤©å¤§č–
            • 31218
            if it has a preset on the pcb to ajust the output, replace it with a pot and you may be able to screw the 3.3v rail down to 2.4v!!
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              That's an interesting tidbit, thanks. There is a micro pot on the board but don't know what it does (yet). It is located in the primary side of the smps region of the board so I'm thinking it may adjust all output voltages. I'll have to try and see It's a Delta DPS-145PB-117 REV 00.
              Even so, I am ok with using the diode I've got to drop the 3.3v down to 2.4v. I don't what else I might want to use this diode for and it's a perfectly suited use for it, it nailed the target voltage right on the money.
                • 31218
                you usually find 2 pots.
                one is the voltage ajuster,
                the other sets the maximum current before the safety trips the supply off.
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  Well I bone-headed this one already. I was checking out different LEDs for a pilot light and after the umpteenth time of flipping the pwr switch I got an arcing short between the hot and ground lugs on the back of the ac jack with the help of a solder drip/blob between them. No major damage to the jack.
                  That opened up the 5A line fuse as well as trip the GFI in the mains. I saw a flash and a bit of magic smoke from the back of the ac jack. I did solder a wire to the hot lug for the ac power switch so it is my fault. Obviously I didn't check that good enough, which is out of character for me as I usually check & double check everything I do and those lugs tend to have too much solder blobbed on them anyway. I did a double bone-head by using a 3A switch instead of at least 5A. I thought it was 5A but my bad again.
                  So after a dozen or so switch uses the 3A switch arced enough to increase the current draw thru the ac jack enough to make the sloppy solder arc. I don't see any other damages and no shorts. I knew I should have used a blue LED dammit.
                    • 31218
                    here are some tips from me doing similar mods for my worktop test-bricks.
                    1: fit an led-fan to know when it's on - no drilling and it looks really good.
                    (it also means your not trusting an old fan)
                    2: use heatshrink over any mains soldering like switches.
                    3: use a capacitor across any mains switch to reduce or stop arcing.
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Those are good tips, thanks.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #31
                        i put an 18650 li-ion and a cheap tp4056 board in mine.
                        soon all the shop screwdrivers will be modded.microusb to charge it
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          I found a 5v 3a inline type psu in my wall wart box and it works to power the screwdriver. Kinda fast, the diode knocks it down to 4.2v but still a bit fast. I suppose I could get used to it and hope I don't burn out the motor.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5040
                            • New Zealand
                            #33
                            Add more diodes?
                            -David VanHorn
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Don't have any more 3 amp diodes. I tried 1 amp diodes and they heat up pretty fast, as one would expect.
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                Mission accomplished. I scrounged up another 3A si diode from an old oddball ATX PSU and the two diodes in series drop the free-running motor voltage down to about 3.1v which produces a very usable RPM for me.
                                I also found that the position of the motor was irrelevant, the factory soldered the red and black wires reversed on the switch and must have swapped them at the board to correct for the mistake instead of re-soldering to the switch, which makes sense since it is mostly plastic construction that wouldn't stand up well to repeated soldering.
                                Sideline: Concerning the other ATX PSU I was using that popped the fuse, I was reading about arc suppression in ac line switch contacts and found the attached PDF. Apparently using only a capacitor suppresses the arc when the contacts open and actually increases arcing when they close from the cap discharging. Better to use an RC circuit.
                                • Astonished
                                  Fixing the Charge Circuit of the Batteries of the DC Motor
                                  by Astonished
                                  Hi friends of electronics
                                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                  Please help me fix this circuit.
                                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                                  01-28-2025, 06:24 AM
                                • redwire
                                  Exploding motor cap on Ryobi electric pressure washers - product recall
                                  by redwire
                                  Exploding motor cap on Ryobi electric pressure washers.
                                  Recall is for 764,000 units and 16,000 sold in Canada.
                                  "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
                                  Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
                                  Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
                                  Safety vent too expensive! DELETE DELETE
                                  08-31-2025, 11:03 AM
                                • carrzkiss
                                  Cyberpower cps1500avr not charging batteries
                                  by carrzkiss
                                  Hello, all.
                                  Cyberpower Battery Backup Unit.
                                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                  Checking the voltage, it was down to 22v.
                                  I quickly removed everything...
                                  06-15-2024, 02:10 PM
                                • SolomonMan
                                  Electric Motor Question....
                                  by SolomonMan
                                  All,
                                  Yesterday in the morning the fan was fine. Its approximately 10 years old. Its one of those high Velocity types.
                                  In the afternoon I noticed it was not running any longer.
                                  During the investigation, I confirmed the wiring, confirmed the 3 way switch is fine, the Capacitor measures the correct Microfarads. So I went to the Motor;
                                  No smell of burnt and it spins very easily. I started to measured the continuity between the 6 wires.
                                  I have included a diagram from a YouTube video I found but basically the wiring is identical. The only exception...
                                  10-29-2023, 08:02 AM
                                • juergenb
                                  Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                  by juergenb
                                  i am asking for some Help.
                                  I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                  The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                  So i got a few of these from Banggood.
                                  I swapped the motor and now i have a new fault condition.
                                  In a working Frother you would press the start button, it will light red and work for a few minutes.
                                  If you press longer it will light blue and just mixup the milk.
                                  With the new Motor it just starts...
                                  03-23-2021, 11:24 AM
