AC Voltage Stabilization
  • pappa_smurf
    • Sep 2012
    • 5
    • mozambique
    Hi all
    Here is a good one for all the BRAINY people on this forum.
    Is there a simple way ie. connecting ONLY a capacitor across mains that will help to stabilize very short dips.
    I ask this because we operate a pressure pump system at the lodge and our power here in Mozambique is very iffy with regular point something second dips.
    Being in the middle of Africa I thought I could use a RUN cap from a motor to help.
    ANY IDEAS PLEASE
    Regards
    to all
    my email is smithjollyroger@gmail.com
    • 31161
    Re: AC Voltage Stabilization
    no.
    there is a technology involving a heavy flywheel you could use.
    • Behemot
      • 4845
      • CZ
      Or UPS, line-interactive is minimum and has to be made for inductive loads/motors. But that will be expensive.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        Originally posted by pappa_smurf
        Hi all
        ANY IDEAS PLEASE
        Regards
        Plenty of ideas if you do not afraid complexity.
        http://www.ittsb.eu/forum/index.php?topic=876.0
        • 999999999
          • Sep 2006
          • 774
          Get the pump motor manufacturer and model # info and ask the manufacturer what the most cost effective way to manage that is. Possibly you need a different motor or entire pump more immune to the dips.
          The flywheel idea is interesting. At first I was thinking an active generator style flywheel but then I thought "What if it's possible to just put it on a pulley or gear on the motor shaft?", although you might then need a second motor to start it so it doesn't burn up the pump motor and then if you're going to do that then you could just select a second motor more immune to the power dips and might not need the flywheel involved at all, just the second motor.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            I recall there were some solutions with a variable transformer and a motor controlled by a servo to do regulation a really long time ago... I really wonder how reliable that solution is at the end...
              http://www.sigmaelectricals.com/autotech.htm
              http://www.sigmaelectricals.com/autotech02.htm
              https://cdn.badcaps-static.com/pdfs/...bf4c60e62c.pdf
              http://voltsmartstabilizers.com/serv...ransformer.htm
              http://www.servostabilizer.in/Servo_Stabilizer.html
              http://www.ustpower.com/comparing-au...age-regulator/
              • Behemot
                • 4845
                • CZ
                And also how (in)efficient.
                  master hoarder
                  • May 2008
                  • 12175
                  Originally posted by 999999999
                  Possibly you need a different motor...
                  Good idea.
                  I'm thinking, maybe find a DC motor that meets the RPM and torque requirements of the original AC motor (or at least I am assuming it's an AC motor). Then it may be possible to build a backup DC supply bank. If the motor is for 12V or 24V DC, the backup DC bank perhaps can be made with car batteries in series/parallel and all hooked to a charger (so that they stay charged when the power is on).
                  stj's idea sounds reasonable too. Probably the easiest if you have a way to mount something to the motor's shaft. But you'll probably also need a secondary motor for start-up, as 999999999 noted... and a circuit to disengage the main AC motor if the power drops out for too long and the pump stops spinning. Then the circuit would need to engage the start-up motor, get the pump up to speed, disengage the start-up motor and engage the main AC motor again.
                  I guess none of these are exactly easy solutions.
                  Is the pump's motor DC or AC? 3-phase or single phase? Induction, synchronous, universal, other?
                    I like the DC motor idea better since you can build good power supply with good hold up and regulation power when voltage sag. When you have power sag, when it recovers, the voltage will over shoot before settling down which is not good for the electronics or the motor either.
                      • 31161
                      i suspect this is a water pump that could be drawing from a well.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Assuming the motor is an AC type, you could get a VFD (variable frequency drive) and add a lot of capacitance to the rectified mains in the drive. The drive converts the mains AC to DC, then to AC. Why? It's AC output has a variable frequency, which is used to control the speed of some AC motors. That is not the reason for using that here though. The reason is so that you can put a large capacitance on there to help with the voltage dips.
                        However, if you do that, beware that the inrush current from the capacitors may cause the rectifier bridge on the mains input to burn out!
                        Muh-soggy-knee
                        • Behemot
                          • 4845
                          • CZ
                          I just by a chance have some older Siemens 3phase frequency drive, 4 kW or 5 HP. I think I can check insides (and caps) without problem and than try it with some motor. If it would be intereseting, I can send it but count on high shipping costs, probably as high as a price of the unit itself. On the other hand, how much would new such unit cost somewhere in Africa? Fortune I bet…
                            • 31161
                            the best bet may be an iron or stone flywheel fitted to the pump's motor shaft.
                            • Fernon@Repair
                              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                              by Fernon@Repair
                              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                              VCCIO voltage ok
                              VCCSA Voltage OK
                              VCCPLL Voltage OK
                              Ram Voltage ok
                              RamVTT OK
                              VPP 2.5 OK
                              But No Core Voltage
                              and i want to this vrm ic datasheet or pinout (ISL69269)
                              anyone have this ic pinout voltages?...
                              06-25-2025, 07:19 AM
                            • electron_jj
                              Panasonic TH-L42D25A checking the PSU output voltage
                              by electron_jj
                              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                              08-29-2021, 08:13 AM
                              Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                              I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                              The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                              Now...
                              06-09-2024, 10:57 AM
                              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                              Based on Intersil's Robust Ripple Regulator...
                              11-05-2024, 03:24 PM
                            • ruletero
                              Acer a515-43 low battery charge voltage
                              by ruletero
                              Hi
                              Acer A515-43
                              LA-H801P
                              Fail: Does not charge battery, has low voltaje on connector.
                              Laptop didn't want to turn on, only charge led blinked.
                              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                              10-24-2022, 02:31 PM
