hi,
was not sure what forum to go to but thought i would try this one.
My parents have this device for drinking hot water. It sits on their counter and they press a button and it gives hot water. well it stopped working. they asked me to take a look at it. basically, it just quit heating the water. i could see lights on the unit when i press buttons but the water would not heat.
i took it apart and found this IC board links to pics (i had to use photo-bucket links...could not upload for some reason)
if pics dont come through just let me know and i will try again.
what i did thus far:
I used a multimeter and just went around the small board and started checking stuff. I started with the diodes. I found that the diode next to the big black "box" was not shorted but measured about 470kOhm. I removed the diode only to find out that it then measured fine......like a normal diode. SO this led me to focus on the big black box thing.
The part number on the big black box was "YX202-S-112DM". I did a quick search and well.........i am not sure what this thing is. I think its a relay but not sure. the black-box basically has 4 leads on it. Two of the leads appear to be inputs and are taking the power bascially from the power cord that goes to the wall....i think. THe other two leads measure the 470Kohms that i orginally measured across the diode....
any thoughts? is the relay bad? is this thing even a relay?
