20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
    • Jul 2011
    • 6070
    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to “V” to check the water valve “N” to “M” to check the motor
    Well I have no water valve function but I have the water dispenser working and luckily the coils are the same just a different color so you do not plug the wrong wire to wrong valve well now I have the ice maker working again ( I do not recommend anyone doing this unless you are aware of what could go wrong with trying this procedure I have worked on this ice maker in the past for other customers and myself I just do this just to make sure that there is nothing else wrong with this refrigerator I would not recommend leaving it this way for a permanent fix by no means)
    I need to order a new replacement water valves so I can push the refrigerator back in to it properly place and be done with it
    Sense I have had this refrigerator I have replaced the ice maker twice before and I keep them for parts and testing purposes and I have a repaired one that I took two ice makers and made a working one but when I get the new water valve I will put the new ice maker in
    The reason I replaced the first one was because the ice was getting stuck in the mold because of water deposits and it not recommended that you clean them because the nonstick coating will come off so I just replace it the second one was taking longer than normal to make ice because the temperature sensor was going bad so I switched temperature sensors around so I have a working unit again however it is also has water deposit on it but not real bad yet
  • redwire
    • Dec 2010
    • 3912
    Re: 20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
    This is a mechanical failure in the water solenoid valve?
    I think mineral deposits, rust flakes in plumbing jam the valves or maybe they just wear out. Should have a mesh filter upstream maybe.
    Or is it like the Frigidaire fridge ice maker/water dispenser problems due to bad diodes, like in this thread: Re: Frigidaire Refrigerator Model FFHS2612LS0 diodes it uses DC on the valves.
    My buddies Miele washing machine, he comes home and the side door is open as usual, but the tub (side) filled with water and dribbling out onto the floor. Fill solenoid was not shutting off 100%, leaking.
    Does it have a water leak sensor, or firmware look at the float sensor to alarm? NO.
      • Jul 2011
      • 6070
      Yes there is a problem with the water valve for the ice maker sometimes the ice cubes are not fully shaped right I have a double water value coming to replace the original one but the ice maker is 35 watts and the water dispenser valve is 20 watts so you can not generic water valve in it
        • Jul 2011
        • 6070
        Now my ice maker is back to normal after replacing the water valve so this project is finally completed and working properly now
          • Jul 2011
          • 6070
          Well now the ice dispenser switch holder which has round plastic rods that hold the micro switch to power the auger motor broke off and nothing was holding the switch in place
          Small circuit board stand-off cam to the recuse and save the day which allows me to get the switch mounted back in the right place for it to work properly again
          • redwire
            • Dec 2010
            • 3912
            Whatever happened to using screws? Maybe it gets hit hard by people, my buddy throws a party and everyone is drunk and usually busts that or the ice maker inside the freezer that flips to fill a hopper.
              • 31293
              using rods through microswitches has been common for decades.
              the problem as i see it is that they did it in a cold enviroment where the plastic would have less flex
                • Jul 2011
                • 6070
                Yea but remember that this refrigerator is around 20 years old now and I use the ice dispenser several times a day at a minimum sometimes more often than that
                I am not surprised that this has happen to it and in fact I am surprised that this refrigerator has lasted this long as it has I guess because I have a device on it that if the power blinks it keeps the refrigerator off for about 5 minutes before it starts running again I have only replaced the compressor starting relay once senses I have had this refrigerator once while it was under warranty I had to have the freezer fan replaced because it became nosier but really have not had too many issues with it other than the ice maker a few times and just recently the water valve
                  • Jul 2011
                  • 6070
                  Well I put the Kenmore refrigerator out to recycle center and bought a new one because they had a very good price and no sale tax ( at Lowe’s ) on a Frigidaire side by side with the old fashioned compressor not the inverter type which I did not want this type of compressor I have read to many complaints about them
                  I figured that I was on borrowed time with the one I had and it was starting to give me issues
                  I did remove the new ice maker that I had just replaced a couple of months ago
                  • connorcc2005
                    Kenmore refrigerator adaptive defrost timer fix. Part: AP4909015
                    by connorcc2005
                    I have a 20 year old Kenmore side by side refrigerator that was acting up with the following issues:
                    • Evaporator coil in the freezer was frozen up.
                    • Unit was still holding temperature
                    • Evaporator fan would run 2 to 3 seconds on then shut off only to repeat.
                    Defrosted the evaporator coil and began testing. Defrost heater ohmed out good. Defrost thermal switch on the evaporator line in the freezer tested good. Once the evaporator coil was defrosted, the freezer and fridge worked but the fan continued to cycle on and off continuously. I suspect the evaporator coil was destined to freeze up again...
                    03-20-2024, 01:14 PM
                  • Ugur87
                    MacBook Air M4 A3240 Brand New Water Damage no Image
                    by Ugur87
                    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                    08-28-2025, 01:09 PM
                  • edugimeno
                    Stagg sms12p audio amp has water damage
                    by edugimeno
                    Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                    I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                    There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                    There is only one signal wire connecting the first boards...
                    05-24-2025, 06:00 AM
                  • RetroComputingGrotto
                    Water Damaged Toshiba 48L1435DB
                    by RetroComputingGrotto
                    I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                    The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                    10-07-2024, 08:23 AM
                  • x_orange90_x
                    Samsung UN65AU8000FF fried by water
                    by x_orange90_x
                    I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                    10-16-2025, 08:40 PM
