Newly pulled 2yo Antec Truepower 430W
    As my newly built Conroe rig went online yesterday, I took my old rig offline and stripped it for dust cleaning and capacitor inspection. The MB, a MSI 865PE Neo2 is full of OST and TEAPO:s and will be recapped. This is the last board I bought before becoming aware of the capacitor debacle.
    This concerns the PSU, however. It has, along with the rest of the stuff been in continuous use for little over two years. Now, having read about the crap caps Antec put in these PSU:s, the question is whether to open it for cap inspection and void almost one year of remaining warranty or not. Your thoughts, please.
    18
    For Heaven's sake, check them. Check them now!
    0%
    18
    What are you thinking! Don't void the warranty!
    0%
    0
    The poll is expired.
    Re: Newly pulled 2yo Antec Truepower 430W
    fan should be replaced anyway for adequate airflow
    most psus have crapcaps
    your choice
    i usually void the warranty immediately
      your choice
      I agree. What good is a warranty if a bad PSU takes out other hardware as well?
        i usually check for DOA first though
          A very good point. So good in fact, I followed up on it, and did a cap inspection. Sure enough, one of the six 3300 uF Fuhjyyuh:s were visibly swollen.
          It's now become a recap project.
            Depending on the unit's vents, it may not be necessary to open it, if you shine a bright torch into it.
            I found a brand new Antec EarthWatts 380W unit for AU$81 online, and a source for Nippon Chemi-Con KY and KZE Series capacitors. Recapping this unit would be a risk worth taking... any loss would be small.
              Well... once you've recapped it, it'll be good for a least another 2 years+ and as willawake has already pointed out, replacing the stock fans with new higher rated cfm units will improve airflow dramatically within the PSU (adding further to it's service life)
              Viva LA Retro!
                To ask this question on bc.net is not a true question lol
                The election result is not that astonishing. But if you want a other result, post the same question on some more average hardware forum, unless you topic would not imediately removed for some saefty issues most nmormal people wouldprefer hail the warranty myth.
                Any way, i vote for open, as those crap fujihuy have to go to the dump AFAP.
                  talking about psu fan replacement. i just did one now. replaced with a new sunon. reassembled the computer, booted then after being in windows for a short while the computer went a little quieter. i check the psu fan and its not working....
                  must be the temperature control made too low voltage for that fan to run.....so i replaced the fan again this time with a known good papst.
                  this is an important concern though if anybody is replacing fans. keep an eye on the new fan for a while because going out to the pub or something and you could find your psu toasted when you come back.....
                    When I was looking into 24V fans, ca. 1987, I found extreme variation on the start voltage, brand to brand. I had some Rotrons that would start at 5V (a 24V fan!). I some others that, if the supply voltage came up really slowly (like if you're turning up a lab supply slowly to observe the start-up voltage, ), they would never start. EBM-Papst makes good fans - likewise Rotron, Nidec, NMB and Panasonic. Delta is good, but I'not sure if they're in those others' league.
                    PeteS in CA
                      I'd contact Antec and tell them you are inspecting the unit but are NOT changing anything inside the unit, I've heard they will respect you inspecting the unit, but if you change anything at all, then the warranty is void.
                      Ya'll think us folk from the country's real funny-like, dontcha?
                      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                        thats good to hear
                        still i respect companies which dont use stickers. eg: fortron
                          I was going to post the Antec CSR's email addy but I only know it for The States.
                          Silverstone Strider and Element series use no warrenty stickers as well as thier OEM, Enhance. Enermax uses none either. (Libertys are off the recommended list)
                            My 420w Noisetaker had a round (dime-sized) warranty sticker over one of its cover screwholes that, when peeled off, left "VOID" behind on the cover. Perhaps mine's an exception, though.
                            You know there's something wrong when you open up a PSU and are glad to find Teapos.
                            Why I don't buy cheap cases!
                              HEC is the same, without the void bit
                              if they gave a lifetime warranty covering damage to all parts of the pc then that would be ok. otherwise i will void the warranty, make periodic inspection or modifications i dont care. better voiding a $100 PSU warranty than losing $1000 of components.
                                I anticipated that most if not all of you would vote to open it. I wrote it partly due to the frustration of having paid $130 for a PSU with second or even third rate components. A cheap $40 PSU would be another matter. I feel ripped off by Antec, and I don't like being ripped off. That was the last piece of equipment I purchased, before becoming aware of the badcaps situation. I will not ever buy another Antec product again.
                                Thank you all for your input.
                                  umm...try to find a psu with good caps....they are rare indeed
                                    I chose the PSU in my new rig, a Corsair 520W, on good reviews plus the fact that they make a point of mentioning that they use quality caps. One review had a picture of the innards, and the caps sure looked like Nichicons to me.
                                      ooh i want one too.
                                        i recap anything i own that contains known crap parts.
                                        and anytime i see a known bad psu/mobo in a customers machine i recommend recap/replacement.
                                        not unusual to see me open up a brand new psu and recap before use.t i very rarely have any problems with my stuff.good thing as i spend all my time fixing everyone elses crap!
