Antec TruePower 380p failed after intermittent supply, suspect MOV
  • rabbituk
    • Apr 2020
    • 7
    I have an Antec TruePower 380p PSU that I had repurposed from a Sonata case. It had been working fine on a server in the loft using the Wake-on-LAN feature regularly until a couple of recent power outages where the power became very unstable - going on/off very quickly. There is now no output whatsoever from the PSU & fan isn't working. There was a pop when I attempted to turn it on.
    Upon examination, it appears that voltage isn't getting very far so I believe the immediate issue is within the first stage. There is a green component that I am not familiar with. It has '005 10' written on it. Is it a MOV? Does anybody have an idea of the spec? There is a hairline crack that goes around the side of it and a burn mark on the rear. So I'm guessing this means it is toast. The DMM measures 22Ohm.
    Here are some photos...
    Front of component
    Rear of component
    Any help in suggesting a replacement MOV appreciated - assuming I'm correct that it is a MOV!
    Daniel
    • 31048
    Re: Antec TruePower 380p failed after intermittent supply, suspect MOV
    not a mov.
    mov's are smooth and will meter open-circuit when good.
    that rough surface part is an inrush limiting resistor that lowers it's resistance as it heats up.
    it's probably fine as it isnt split in half or a pile of ash!
    • rabbituk
      • Apr 2020
      • 7
      Thanks for the pointer. A look at NTC thermistors does indeed show some very similar looking candidates. There is definitely a burnt smell from this NTC so I'm tempted to replace it anyway. There are also some domed caps near the output.
        • 31048
        burned glue on the back - that's the smell
        check the resistance
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Thermistors sometimes crack or blow apart is there is a really high current short further into the circuit, e.g. a shorted bridge rectifier or switch device. So you have a bad thermistor and some probably bad output capacitor. You also probably have one or more shorted PFC or inverter MOSFET.
          PeteS in CA
          • rabbituk
            • Apr 2020
            • 7
            The 22 ohms that I mentioned earlier was measured across this thermistor. Was it correct to measure it whilst in circuit or do I need to take it out? Is 22 ohms correct for this component?
            • PeteS in CA
              • Aug 2005
              • 3581
              Yes, it can be measured in circuit. The actual resistance depends on the specific part, but 22 ohms is credible. However, if it is cracked it is damaged and should be replaced. The cause of the cracking would be as I described above, a very large excessive current. Fuses don't blow without a reason. The same is true of thermistors. The cracking indicates there is a problem elsewhere in the power supply.
              PeteS in CA
              • protocold
                MacBook Pro 15" 2010 820-2850 intermittent charging
                by protocold
                I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                when it is not intermittent:
                PPVBAT_G3H_CHGR_R is 12.07v
                when it is intermittent:
                When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                data line on the battery...
                07-25-2025, 08:18 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • MakNCheese
                ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                by MakNCheese
                I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                Symptoms:
                • Severe lag across the system, including BIOS navigation.
                • Slow boot times and unresponsive performance in Windows.
                • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                • No error messages or BSODs, just extreme sluggishness.
                What I've Tried:
                • Replaced
                06-04-2025, 12:48 AM
              • cheeky2
                MSI GTX 970 4G V316 1.1 Loads of lines across screen suspect memory??
                by cheeky2
                Recently purchased this MSI GTX 970 Gaming 4G graphics card and card shows plenty of lines when booting up to bios and into Windows.
                What are your thoughts memory issue as I don't have that much experience repairing graphics cards?
                I have checked before plugging in card for shorts on the 12V power rails, PEX etc otherwise I wouldn't have plugged the card into the motherboard.
                The screen shuts down if I load the drivers on the card.
                See attached pictures.
                Any thoughts with what is likely to be the issue? I suspect a faulty Samsung memory chip and if so would...
                05-28-2025, 07:49 AM
              • gurj1979
                Surface Laptop 1769 SSD Failed KUS040202M-B000
                by gurj1979
                Hey guys,
                I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
                These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
                AliExpress has this but it's expensive.
                Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
                Or which NVMe can I remove it from ?
                02-17-2025, 04:02 PM
