This 350-watt Antec was non-working. Three fuyuhu caps in the secondary were vented, so I recapped this PSU, removing every blasted fuyuhu cap and replacing with quality caps.
I had securely reassembled the PSU, but the top was off, and as I attemped to push the power cord in (switch was off) there was a loud pop and some sparks. The primary side heatsink was apparently live and touched the case.
Visual inspection confirmed this, slight heatsink melt and blackened area on inside of steel case.
So I'm guessing one of the components on the primary heatsink was shorting directly to ground. However, I repeat, the rocker switch was in the OFF position.
What happened to cause this? I went over all the caps I replaced and everything was done properly. There is no burning on any components that I can see.
I have now removed the wires so I could remove the heatsink, but the wiring was untouched when the short happened.
How do I test the Mosfets for short to ground? There is no continuity between any of the pins on the big MOSFETS and no continuity to the heatsink except at the mounting screws The smaller one has continuity between pins 2 & 3, but none to the heatsink except at the mounting screw.
