3 wire cord but no ground
  • larrymoencurly
    • Oct 2004
    • 960
    No-name model SPP34-12.0/5.0-2000, 3-wire plug but no ground connection (or UL approval or EMI filter):
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: 3 wire cord but no ground
    LOLOLOL!!!!
    I love how its labled genericly, "Power Supply"
    Try shorting the output and see what it does
    Muh-soggy-knee
      If the construction for critical components are double insulated, then ground prong is not needed. Is there actual ground pin on this IEC AC Inlet?
      • mariushm
        • May 2011
        • 3799
        I think there actually is ground, through that blue capacitor by the transformer. later edit: no i was wrong, it has to do with making sure there's no high frequency noise and radiation in the output cable .
        The optical isolator is for feedback on the secondary side.
        Here's a really crap psu : http://www.youtube.com/watch?v=T88ej...ature=g-user-u
        And a reasonable one: http://www.youtube.com/watch?v=1F3Xl...ature=g-user-u
        ^ it explains about that capacitor near the transformer and being isolated and all that, why it doesn't need ground...
        • larrymoencurly
          • Oct 2004
          • 960
          There is a ground pin there (see attached pic), only it goes nowhere inside, but on eBay I've seen power supplies with AC inlets that fit 3-wire cords but lacked any visible ground pin. At least they weren't pretending to be safer than 2-wire.
          How safe are non-certified transformers vs. certified ones?
          I use the 3-wire 19VDC power adapter from an old Dell Latitude with my Toshiba laptop because it's grounded because I suspect it's safer. Actually Toshiba once told users of a certain AMD-based model to switch to 3-wire non-Toshiba AC adapters, not for safety but to prevent lockups and reboots from line noise. I don't know why their Intel-based laptops, like mine, weren't included in the notice.
          • larrymoencurly
            • Oct 2004
            • 960
            This AC adapter has been updated to make it even cheaper, although the output ratings remain unchanged. I think the basic circuit is the same (new one still has an optoisolator, but it's hard to see in the picture), but some parts were removed (output chokes), reduced in size (less capacitance, lower wattage resistors, TO-220 schottky diodes replaced with axials), or cheapened (regular resistor in place of flameproof, UL certified Y-capacitor now an uncertified one). The ground prong still goes nowhere, but they quit bothering to solder it, at least not properly.
            The old AC adapter was made in China; the new one was made in "CHIAN".
            • imp
              • Aug 2010
              • 125
              • Sweden
              Originally posted by mariushm
              LOL! Why even bother to put some components inside? Worst I ever seen!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                If one laptop PSU needs 3-prong then wouldn't all portable electronics need it?
                In my opinion it almost seems all laptops require 3-prong unless somehow they can double insulate the output plug exposed contacts... as far as I know, most laptop PSUs are single insulated for the exposed plug contacts (namely, the main transformer). However somehow my eeePC 12V PSU is 2-prong and supposedly passes UL (but I have yet to open it to look at how it's insulated internally...)
                • mariushm
                  • May 2011
                  • 3799
                  The eeePC may need low enough power for the adapter to fit into another category of power supplies, when it comes to radiations and so on.
                  I don't own one and didn't have one go through my hands, but looking on Amazon for replacement power supply for eeePC it looks like it's 9.5v 2.315A ... that's just 22 watts... no problem.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    My 65W AC adapter for my laptop has two prongs also.
                    Muh-soggy-knee
                    • mariushm
                      • May 2011
                      • 3799
                      The transformer inside is insulated, there's only a tiny capacitor coupling the dc side and ac side and that's for emi suppression, so the dc is basically floating.
                      Not much to kill you from the secondary side of the adapter and onwards. Also, laptops usually only use a high voltage to charge the batteries, otherwise there's just a tiny area on the pcb where you get more than 5v in the laptop.
                      Even if you short something, it's theoretically not deadly, so there's no risk for human.
                      But of course, there's a lot to argue about low voltage/high voltage, low current/high current and so on ... you may get your heart fibrillating or damage your tongue if you put your tongue on the 19v dc jack of a laptop charger.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Oh... I think I just thought of why it's OK for transformers are OK. The varnish on a transformer's primary counts as one layer of insulation, a plastic guide and tape to separate the primary and secondary will be the main insulation, and finally the varnish on the secondary would be a third... that should qualify, so maybe this is fine not to have a ground after all as long as the transformer is designed this way. (I would hope that varnish would not be the only insulation separating me from doom!)
                        The wiring from the mains plug and the primary circuitry itself still needs to be double insulated...which typically isn't too hard... So I think for power bricks it mostly should be fairly safe to have no ground as long as it's designed properly.
                        And BTW...the eeePC PSU is a 3A 12V, so 36W, so very well might be a special class. Some other PSUs I have:
                        Scanner: 24V 1A -- GROUNDED!
                        Big HP laptop power brick: 12V 5A -- Grounded!
                        Iomega PSU: 5V1A+12V0.75A - Not grounded
                        LCD: 12V 4A -- Grounded.
                        I guess the scanner might be an anomaly?
                          The reason no ground is used is because there are two separate insulating layers PLUS the ground isn't needed for EMI.
                          Ground is very useful for getting rid of EMI because it is easy to couple most of the noise into it. Live and neutral approximate ground at high frequencies.
                          This is why some products do not have an earth: including one is more expensive, so they'd rather make it such that one isn't needed. For lower power products, that's possible.
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            I have an old 95W Sony VAIO "power brick" (it really is) with only 2 prongs.
                            I also have a 12V 1A 3 prong SMPS from my D-Link DCM-202 modem.
                            Go figure ...
                            • larrymoencurly
                              • Oct 2004
                              • 960
                              Several years ago, Toshiba issued a technical bulletin about some of their laptop computers acting wierd because EMI got through their ungrounded AC adapter, and their suggestion was to substitute a grounded Targas brand adapter. That was back when Targas adapters were UL or CSA approved.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                I've never had that problem
                                Muh-soggy-knee
                                • lti
                                  • May 2011
                                  • 2547
                                  It was only a certain series. See post 5:
                                  • larrymoencurly
                                    • Oct 2004
                                    • 960
                                    It was for some of their A2xx series Satellite laptops, only those with AMD CPUs (A215?).
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Ah, thats older than mine. Good to hear xD
                                      (mine is a L645D from 2010, AMD Phenom II triple core CPU )
                                      Muh-soggy-knee
                                      • Colt45ws
                                        • Jan 2009
                                        • 174
                                        Once I took my old Dell laptop on a trip and forgot the power adapter, so I bought one of those "green" adapters from WalMart that purported to be compatible.
                                        It made the computer HOT. Like AC voltage hot. Any metal components I would get a tingle off of like if I rested my hands on the palm rest. So I returned it and got another one. It did the same thing! I couldnt figure it out. It wasnt full 120VAC, obviously, but it was well enough to feel.
                                        • playit
                                          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                          by playit
                                          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                          09-02-2023, 02:43 AM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
