The Eurocases PSU is full of bad caps - Hec ones. Mine has even tougher job - it has to run entierly fanless. Yet powering my server is not so hard task, the mobo ECS P6STMT and 14W 1200MHz VIA C3 Nehemiah CPU aren't so demanding...
Now let's list all the caps used for anyone who want recap that thing:
Eurocase PSU
2x 680uF 200V d22x46 (can be up to d25x75)
1x 1000uF 16V d10
4x 1000uF 10V d10 (can be 6.3V)
3x 470uF 16V
2x 47uF 50V (max 23V on it)
2x 22uF 50V (max 11V on it)
1x 4.7uF 50V (max 5V on it)
4x 1uF 50V (max 0.16V on it)
I have absolutely NO IDEA where to get these big caps:
But maybe someone can help me?
Now the other ones.
There is many and only 1000uF ones for filter the output. And unnecessary 10V ones - for the 5 and 3.3V rails. At least always two of these 1000uF are in parallel to filter better, but... is not 2000uF too small still?
The blue ones are Hec too, just 16V ones (one 1000uF as well, as two other 470uF ones - third 470uF 16V one is black...?!). I'm the only one who get the feeling that 1000uF cap aren't nowhere near enought for filtering the 12V rail???
Now let's take a look, how the output that killed the G-LUXON caps and my mosfet on my board looks, shall we?
Not very good, I would say. Note that the spikes sometimes exceed 0.2V ...
How can one rate such output in terms of quality on the scale 1 - 10...?
So, now about recapping.
I sort of giving up ATM for the big ones, but from the small ones, these 1uF and 4.7uF cap's voltages suggested that I could happily use a 16V ceramic SMD 1210 cap there. 10uF one. And I did:
After replacing these caps I run the PSU on dummy load for about half a hour and none of these ceramics are damaged, so I think that it is safe to replace them with any 16V caps - ceramics preferably - it last, hehe
Now the rest - as Rainbow suggested:
I think it will be safe to replace the 22uF 50V caps with a little bit higher capacities, so the end list should look like that:
Eurocase PSU
1x 2200uF 16V d10
4x 3300uF 6.3V d10
3x 470uF 16V
4x 47uF 50V (can be 35V only)
Now the filtering. After my bad experience with the PSU I wanted to make sure that nothing bad will happen again. So, what should I do? Block (bridge) each of the big output caps with 10uF 16V ceramics?
Will that help enought? Or should I also add in parallel 100nF 16V ceramics to this?
What should I do to make the absolutely best results
I think I know, but since I got THERE these PSU in my machines, I better ask what will be simply the best solution
Eurocase PSU
1x 1000uF 16V d10
3x 470uF 16V
Now the other ones.
One of the 22uF/50V cap is critical for the auxiliary supply and these HECs go bad after about 2 years, the voltage for the control chip increases to the point that it dies, resulting often in more damage. I replace them with 47uF/63V caps.
Eurocase PSU
1x 2200uF 16V d10
4x 3300uF 6.3V d10
3x 470uF 16V
