Cap specs & rated voltage
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    I wonder, how much the caps specs differ when the cap is running on other that rated voltage. Let me say this - there is 16V cap. Let's assume that it run at 8V - half of the rated voltage.
    How much capacitance it have, compared to the original specs? (half...???)
    How does the ESR change? (probably only very slight, right?)
    How does the ESL change? (probably also very slight...)
    And the lifetime?
    And it is the change linear or rather logaritmic?
    What about running 16V cap at 5V?
    And since most Vcore voltages are about 1.2 - 2.0V, how much suitable is to use 6.3V caps there? Sure, the PWM pulses are notably higher that the resulting Vcore after caps, as oscilloscope showed me, so 6.3V are probably necessary there - but it really is?
    Some caps manufacturers made even 4V ones. Suitable for Vcore?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • Rainbow
    • Aug 2005
    • 1375
    Re: Cap specs & rated voltage
    Capacitance does not depend on voltage.
    • yanz
      • Nov 2004
      • 910
      yup. i think if it is 1000uF, it is 1000uf wether it on 5v or 12v. that's the meaning of "capacitance". cmiiw. geeks over here can explain much better i think..
      about ESR & ESL, i have the same question as you, trodas let's see what they'll explain about this..
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        With lytics, the C doesn't change with applied DC voltage, nor does the ESR or ESL. OTOH, ceramic caps' C does change with applied DC voltage (except for "COG" ceramic), how drastically depends on the type of ceramic. I think Z5U and Y5V are the worst, but even X7R caps are affected some.
        PeteS in CA
        • Spacedye69
          • Nov 2005
          • 698
          • US
          Is there any need for 10v at all on pc equiptment, or is 6.3v too close on 5v line?
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            is there any chance that the dielectric is not being maintained well with low applied voltage to much higher voltage caps. say 3v going through 16v caps for instance?
            • VILE DISRUPTION
              • Jun 2006
              • 47
              Possibly. it depends on how long the low voltage is there but then when it breaks down just use a variable PSU to bring it back up if it is needed for something else. But maybe it will lower the lifespan on the cap(s). So it is best to use the right voltage cap. when i build a circuit and the instructions say a 16v is needed i measure the coltage first and see if i need a 16. but for another part where the voltage is 9 i just use a 10. now i hope this answers that. but sometimes people go overkill w/ 1000v where only a 4.5v is called for. how would you rehabilitate that? my desk psu is only 0-30v
              Stats Reset Every Month.
              My Forums
              • yanz
                • Nov 2004
                • 910
                so we should be carefull if we attempt to reuse used caps and we should check the original voltage that was applyed to them, right?
                that is, if someone find 16v or 10v caps, he should be carefull if he want to use it on 12v or 5v line. that caps probably was used for 3.3v lines (or ~2v -> cpu vrm output) for years..
                • yanz
                  • Nov 2004
                  • 910
                  i guess, that is a 'memory effect' phenomenon? like what was common to the antique NI-Cd batteries..
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    As i remmeber, i have read something about those issues on rubycons hp. They stated that the dielectric barrier will decrease if lower voltages are apllied to them, but the oxid layer will rebuild itself when higher voltages are applied. But they recomend the usuall formating thing with some rsistor to slwoly rise the voltage (as at the beginning the leakage current will be fairly high). And they stated that an cap will only at the rated voltage will archive full capacitance. For ESL and ESR i can`t remeber that those where affeckted.
                    The rebuild process will always consume some of the elektrolyt, thus the lifespann could be reduced somhow.
                    • trodas
                      • Jan 2006
                      • 770
                      • Czech republic
                      Yep, that is exactly what I remember sometime ago...
                      Novadays they seems to use better electrolytes, witch could possibly mostly eliminate these abovementioned problems, however I still think that the caps parameters (not only capacitance, but ESR and ESL as well as lifetime - but lifetime probably only increase?) are affected somehow.
                      Maybe less that before, but who knows for sure - let him speak.
                      Also it possibly depend on cap type/producer.
                      And now about the measuring... DMM measure the average voltage and not spikes - in CPU VRM there is about max. 2V average, but on the caps I saw at least 4V high spikes, so 6.3V there have some sense... At least on Epox 8RDA+ and DFI LP B voltage regulators
                      And to that time I thought we can use 2 - 4V solid polymer caps there...
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        You can use 4v polymeres, as they have more headroom for spikes.
                        But the problem with thinning oxid at lower voltages is IMHO not fixable due to elektroly improvment. But anyhow, i won`t give to mutch on those issues.
                        • 999999999
                          • Sep 2006
                          • 774
                          Practically speaking, you can use the higher rated caps, even reuse them, at lower voltages. The change in capacitance (if any) will be trivial for most common purposes we see on this 'site, and the ESR and ESL depend most on the physical can size, not charged voltage vs rated voltage. This is considering same family of cap for comparison, and modest changes in rated voltage, not using a 400V cap where a 16V used to be, as this will start having more significant capacitance loss.
                          Thus, most often the ideal is the largest cap you can fit in the allotted space, and whether you pick a higher voltage than it sees or a higher uF value instead, depends most on whether you have a supply with slow sensing or frequency (favoring higher uF) or lower turn-on surge capability (favoring the lower uF but still retaining the low ESR from the larger can size).
                          As for what is actually required or most cost-effective, that may depend as much on how long you want the part to work properly, if the caps are among the earlier failure points. It is much easier and not much of a cost factor for one-off build or repair to just fudge a little on the safe size with lower ESR or a little more capacitance than necessary, but still if you had a 10V 1500uF cap and could fit it where same family of 6.3V 1500uF could go instead, in general it's not going to be a problem.
                          • Fernon@Repair
                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                            by Fernon@Repair
                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                            VCCIO voltage ok
                            VCCSA Voltage OK
                            VCCPLL Voltage OK
                            Ram Voltage ok
                            RamVTT OK
                            VPP 2.5 OK
                            But No Core Voltage
                            and i want to this vrm ic datasheet or pinout (ISL69269)
                            anyone have this ic pinout voltages?...
                            06-25-2025, 07:19 AM
                          • Perry Babin
                            Operating caps well below rated voltage
                            by Perry Babin
                            I think this has been answered but I couldn't find the thread.
                            Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                            So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                            If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                            Or would it require reforming?
                            05-23-2024, 05:43 PM
                          • conghuyms
                            MSI RX580 Vcore voltage is too high, please help me !!!
                            by conghuyms
                            I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
                            I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
                            Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
                            What should I do...
                            08-02-2025, 11:38 PM
                          • chbalnuweit
                            HP 17-cn0234ng - RAM and VCORE voltage missing
                            by chbalnuweit
                            I got an HP 17-cn0234ng and I am hitting a wall diagnosing it.
                            When I first got it, it wouldnt turn on at all and no lights were active.
                            I found a shorted capacitor on the 3.3V powerrail near the lid sensor. Once I removed the shorted capacitor, the power and charging light on the DC connector started working and the Laptop reacted to the powerbutton.
                            When I press the powerbutton, current consumption goes up to about 50mA and just stays there. Chipset and 3.3V regulator getting a bit warm under thermal camera, but not really noticeable...
                            03-07-2025, 05:21 AM
                          • Harryrepair
                            Lenovo Legion 5 16ACH6 no vcore on CPU/GPU and no voltage on ram
                            by Harryrepair
                            Hello all,
                            i am stuck with this device, which i bought for myself.
                            All main voltages are present on their power supplies
                            20V
                            5V
                            3.3V
                            1.8V
                            0.7V
                            Powerbutton 3.3V
                            It charges the battery well
                            Powering on :
                            -Light on Powerbutton
                            -NO voltage on CPU/RAM/GPU
                            I dont find any short on the board.
                            Thank you for any assistance...
                            04-28-2025, 06:36 AM
