What are these caps?
  • jonnyGURU
    • Feb 2006
    • 244
    No brand name or markings familiar to me here:
    http://jonnyguru.com/PSU/TP2-550W/IMG_0540.jpg
    Rest in peace BFG. You were... a job...
  • Fatal0E
    • Jan 2004
    • 252
    Re: What are these caps?
    Is that the Panasonic logo?
    • jonnyGURU
      • Feb 2006
      • 244
      I dunno. It's not a trick question. I really don't know.
      • Galvanized
        • Mar 2006
        • 468
        Half way down the page https://www.badcaps.net/forum/showth...4&page=4&pp=20
        Third of the way down the page https://www.badcaps.net/forum/showthread.php?t=588
        Ya gotta show the vent cap well in pics
        There is no stripe down the side of the cap?? Is it a Chinese knock-off of a Panny??
        • jonnyGURU
          • Feb 2006
          • 244
          Damn. I'll check for the "T" on the vent in the morning.
          I doubt it's a "knock off." It's an Antec PSU.
          It would make sense if the "M" stood for Matsushita, but I didn't think Antec used Panasonic caps in their PSU's. But if there's no "T" on the top, which is a Panasonic exclusive, would that mean they'd have to be knock offs?
          • jonnyGURU
            • Feb 2006
            • 244
            Here's the photo embedded in a post. Sorry I didn't do that before, and of course BadCaps isn't set up to allow for edits after a period of time.
            I'll get more photos tomorrow.
            • Shroomie
              • Apr 2006
              • 356
              It looks like it *should* be a Panasonic. Either it is or it's a counterfeit one.
              What does the vent look like, Jonny?
              Edit: No T? Seeing as Antecs are famous for bad caps (Fudge-Yous especially) it wouldn't shock me. This is my last Channel Well.
              You know there's something wrong when you open up a PSU and are glad to find Teapos.
              Why I don't buy cheap cases!
              • linuxguru
                • Apr 2005
                • 1564
                Large can-type or HV Panasonics don't necessarily have a T-vent. These look like regular M-series 85c Panasonic. Nothing wrong with them, they're pretty much indestructible on the primary side.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  I bet it's a knockoff, seeing how cheap crap Antec uses for the rest of their designs (Fuhjyyu)
                  • JEDIYoda
                    • Mar 2006
                    • 34
                    well we all know and have opinions about the Antec Brand but what if....
                    Finally somebody at Antec woke up and decided it was time to have a quality PSU?
                    I understand people being quick to jump on the band wagon and you all are probably right.
                    But what if....
                    • jonnyGURU
                      • Feb 2006
                      • 244
                      Well, it's a very current unit. It's a True Power 2.0 550W SLI. And it did fine in the load tests except for that it got really hot (50C) and shut down. So I was thinking, if this thing had fake Panasonics, it's only a matter of time before this thing blows up. But if it's that recent and they really are Panasonics, maybe it'll be fine even if temps hit 50C.
                      I have to be skeptical. Any Antec I've personally had has had the primarys blow up. One time, right by my ear.
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        I don`t hink that this caps are faked, loks like a genuine Panasonic to me. In generall, i think that the primary caps arent the problem in PSU`S, as those big caps are easy to produce and due to their size they will suvive any of the primary caps. Even not that good cap brands will work fine on that application. So if heat is a concern i would first think about those secondary side caps, as they have to stand against temperature and a lot of ripple current too (which will heat up the caps too).
                        Is this temp a realistic comparable with an 30 or 40°c input air temp (like normal pc cases) or on free air?
                        • Super Nade
                          • Jun 2006
                          • 294
                          gonzo, why is this a problem (secondary side)? I thought both the primary and secondary sides had filtering mechanisms? If so, why should the secondary side bear the brunt?
                          Q6700 @ 3.6 GHz
                          Zippy GSM-6600P
                          Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                          Abit IP35Pro
                          ATi HD4870
                          • jonnyGURU
                            • Feb 2006
                            • 244
                            Like I said, I've had Antec's blow primary side caps. There's even a poor bloke over at HardOCP that had one of his primarys catch fire: http://img197.*************/my.php?i...ture0075wk.jpg
                            Hey.. I just noticed. Those have a "T"! Of course, the fire could easily be from a short at or around the cap and not from the cap itself, but I digress....
                            I'll get better pics of it AND the secondary caps in a few minutes.
                            As for the temps, I essentially have my load tester venting heat back into the case. So in other words: Whatever wattage the PSU creates, is turned into heat and pumped back into the case. So the temps might be a bit higher than typical, and the PSU was putting out a sustained 550W when the temps got up that high. But it's not like I cranked the room temp up to 50C. The room temp is only 25C.
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              • USA, Unsure of Planet
                              That's the Matsushita logo, and the series, "UQ" is probably the TS-UQ series marketed under the Panasonic brand and available from D-K.
                              PeteS in CA
                              • jonnyGURU
                                • Feb 2006
                                • 244
                                I updated the photo. It is a Panasonic cap.
                                Unfortunately, all of the secondary caps are still Fujhhyu.
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  primary caps seldom fail unless someone flips the 115/230 switch to 115 and plugs it in to 230.hmm we need an exploding cap smiley.
                                  • jonnyGURU
                                    • Feb 2006
                                    • 244
                                    Well... I've had them blow up on me twice and I was nowhere near the 115/230V switch.
                                    But there could've been a short inside the PSU that triggered the explosion, so I'm discounting anything.
                                    • gonzo0815
                                      • Feb 2006
                                      • 1600
                                      Well, as long as the cap isn`t mechanically dammaged, i don`t think they will blow for nothing. But ok, if seriousely overloaded over some time i can immagine that the ESR will become important, due to the higher ripple current and the high temp. But normaly as stated before, due to their absolut size there are a lot of elektrolyt in them (to dry out somhow). And even high ripple currents will only over long time affekt the caps, due to the size and surface of thos big buggers, disipating heat. And i am not aware about some high voltage cap having an aqueouse elektrolyt......wich could be funny
                                      But at least i am right there, those I/P caps will survive those bad Fujhhyu crap by decades.
                                      Is this still a aktuall unit from Antec? haven`t they stoped selling this utter Fujhhyu crap caps as "high end" stuff for a lot of money?
                                      I think it is time for an lawsuite against them, it seems to me that they need to suffer substantiall loses to learne the lesson.
                                      Hope the other reviewers will notice that Antec isn`t a good brand, even if they will do it if they are new.
                                      • jonnyGURU
                                        • Feb 2006
                                        • 244
                                        You're thinking of Seasonic. Seasonic started using Nippon Chemi-Con. To my knowledge, Antec never got away from using Fujyyhu.
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
