VPower VT-300ATX (DEER)... I don't think a recap will revive this one.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    I'll let the pictures do the talking here...
    And there you have it!
    On the output side, the smaller caps are Jun Fu and the larger are CapXon. All the caps on the output side are domed, and some of them are burnt (though this could be from nearby component failure).
    Ludicrous gibs!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: VPower VT-300ATX (DEER)... I don't think a recap will revive this one.
    wowee bet that smelled nice....did it take anything else out?
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      The only thing it took out was the floppy drive...
      Believe it or not, but this thing still tried to boot the computer up! But it made a very bad screeching noise while it was doing it.
      Ludicrous gibs!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Had the fan died perhaps?
        Does not look like a failure even a Deer would manage all on it's own...
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Yes, the fan is seized.
          Ludicrous gibs!
          • Rainbow
            • Aug 2005
            • 1375
            As it still worked, complete recap (including the smallest caps - as they are probably all bad from the heat) would probably fix it - but it's not worth that.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              I would also have to replace the other charred components and the melted wiring... def not worth it...
              Ludicrous gibs!
              • arneson
                • Sep 2005
                • 1267
                Fire!
                Did you need a hose to put that out?
                Jim
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  cues up beavis and butthead fire heh heh
                  • japlytic
                    • Oct 2005
                    • 2086
                    Not worth recapping - these units are junk anyway; it looks like there is rust on the cover. Should the sale (and import) of power supplies made by Deer/L&C be banned on grounds of poor quality (especially in developing countries)?
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      That's not rust, that's burnt electronics!
                      Ludicrous gibs!
                      • Chris1992
                        • Apr 2005
                        • 561
                        YECCH!!!!!!!!!!!!!!!!! Even the worst PSU fail I've seen, Hipro with seized fan, didn't look nearly as bad as that!
                        The great capacitor showdown!
                        • linuxguru
                          • Apr 2005
                          • 1564
                          Yup - that's a Deer/L&C all right. It may not be worth it, but this one is probably fixable - caps, fan, wiring and a real TO-220 10A Schottky-barrier rectifier on the 12v rail should make it usable. On second thoughts, just scavenge it for parts - there are usually fairly nice primary-side HV BJTs and FETs, as well as passable secondary rectifiers on some of these - I've found Fujitsu & Mospec.
                          • Tom41
                            • Oct 2005
                            • 338
                            • England
                            I saw a similar effect inside the PSU of the work PC that died. The fan had been dead for some time, and the PC had been left on 24/7 - therefore the board was severely charred inside. In addition, some of the caps had clearly vented. There was glue all over the place, and a venting cap had caused a bubble to appear in the glue over the top. I assume the bubble was only made because the intense heat (no fan) caused the glue to revert to a liquid state.
                            You know there's something wrong when you open your PC and it has vented Rubycons...
                            • arneson
                              • Sep 2005
                              • 1267
                              Volcano Caps!
                              Jim
                              • hkivan
                                • Mar 2006
                                • 122
                                According to info from a PSU mfr, Fan failure is one of the major causes
                                affecting PSU life span. So, if you plan on running your system 24/7 you
                                better give it a good fan. I found the following info about fan bearings
                                which may be helpful :
                                bearing types // life span in general
                                sleeve 5000 - 8000 hrs
                                one ball ~ 40000 hrs
                                dual ball 50000 - 100000 hrs
                                hydraulic (AVC patented) ~50000 hrs
                                rifle (coolermaster) ~ 40000 hrs
                                hypro (ADDA patented) ~50000 hrs
                                MegLEV (sunon) ~50000 hrs
                                I suggest at least not to use a sleeve bearing fan although
                                they are usually the cheapest.
                                • Rainbow
                                  • Aug 2005
                                  • 1375
                                  Many PSUs use crappy fans - sleeve bearings almost everywhere. Sleeve bearing fan can also run for years - but it must not be cheap crap.F
                                  Fans can be also fake - you open a bad fan with "ball bearing" on sticker but there's sleeve bearing inside. It was very common for 5cm fans used on CPUs ~6 years ago.
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3583
                                    • USA, Unsure of Planet
                                    OEMs such as Apple or HP usually specify ball-bearing fans.
                                    PeteS in CA
                                    • Galvanized
                                      • Mar 2006
                                      • 468
                                      CoolerMaster no longer offers the rifled bearing fans=sad because they were good.
                                      I've used ADDA HyPro in 80mm, very sweet fan. Quieter than same speced Japanaflos. The HyPros are not easy to find and co$t more.
                                      Scythe has a new line of ceramic bearing 120s out now that are supposed to live 150k hours.
                                      Many of the cheaper PSUs that fit 120s have sleeve bearings and think they will live longer because they are on the cooler intake side of the unit. I'll pass on that idea.
                                      dood, the last pic looks like a splash plate out of an old stove
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        wahey it turned into fan chat again
                                        what is the opinion about the following fans ; xilence, noiseblocker, arcticcooling , akasa
                                        any good or just eXtreme bullshit?
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • kotel studios
                                          DEER B350ATX PSU - tips on making it safer and "better"
                                          by kotel studios
                                          Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                                          At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                                          Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                                          Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                                          03-04-2025, 12:09 PM
                                          no-name Radeon 9600 XT recap and cooler
                                          by momaka
                                          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                          This one was actually suggested to me by ChaosLegionnaire....
                                          11-06-2020, 07:54 PM
                                        • yheriatovych
                                          A2338 820-02020-A 5V, no screen, unable to revive/restore
                                          by yheriatovych
                                          Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
                                          Initial symptoms:
                                          One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
                                          Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
                                          However, I noticed that it was in some weird state:
                                          • The fan was still blasting at full speed. It's blasting even when the system
                                          01-31-2024, 10:22 AM
                                        • varunviolin007
                                          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                          by varunviolin007
                                          Hi guys,
                                          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                          Looking for someone experienced with older PC boards who uses...
                                          07-29-2025, 11:53 PM
