Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Power supply build quality pictorial DISCUSSION
    Enhance's UL is E166947.
    That looks like it -might- be what's on the PSU.
    Hard to read from here.
    I'm kind of surprised.
    Enhance usually uses good caps.
    Mann-Made Global Warming.
    - Dr Seuss
      master hoarder
      • May 2008
      • 12175
      #242
      I think PCBonez is right, the UL number does look like Enhace's. The model number (ATX-2035FA) is listed on their UL page as well. I noticed something weird though - Bestec also has a PSU with the same model number. Coincidence?
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        From what I can see the UL is E166547, which is nothing,
        Hard to read from here.<<
        I think your right. I believe that is a 9, not a 5.
        • lucky13
          • Aug 2007
          • 412
          #244
          Yes, it is E166947.
          Here is a close up crop.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            So it is definitely a real enhance, why does it have bad caps?
            The one enhance I have has a mix of UCC and Teapo in it.
            Maybe someone else who had it said "UCC? These are crap, I'll put some good YC caps in it."
            • Brian C
              • Dec 2006
              • 156
              #246
              Hmm.. Enhance PSU. Voltage Mode PWM controller.
              • lucky13
                • Aug 2007
                • 412
                #247
                OK, I removed the board out of the chassis.
                I don't recognize this brand logo. They are all marked 105°C TK and are black with gold lettering
                Tallest is 3300uF/16V (10mmx38mm)
                2 are 3300uF/10V (10mmx30mm)
                2 are 3300uF/6.3V (10mmx30mm)
                On the original pix, the two smaller caps (both swelled):
                1000uF/10V and
                470uF/10V (black colour)
                Recommendation on replacement caps?
                • lucky13
                  • Aug 2007
                  • 412
                  #248
                  Is that bad?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    = YC = YANG-CHUN ...
                    It's a Y and a C with a band around it like the planet Saturn.
                    Like this:
                    Really goofy logo as logos go.
                    - Dr Seuss
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      Rosewill likes to use those in their lower end ATNG's and higher end solytech built units.
                      Though i've never seen another ATNG built unit with YC caps.
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        because of those HUGE image in the pictorial thread..
                        time for topcat to add some image resizing plugin (and update the vBulletin forum software, as there are some exploits for this old version used here)
                        http://www.vbulletin.org/forum/showthread.php?t=118048
                        just an example though.. no idea if it works with this ooold 3.0.13 version
                        • lucky13
                          • Aug 2007
                          • 412
                          #252
                          I am having trouble locating any specs for these YC caps.
                          I need to find a replacement for 3300uF/16V. It is only 10mm diameter.
                          Can I use UCC EKMG160ELL332MJ40S?
                          It is available from Mouser.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I haven't found datasheets for YC yet. There probably aren't any available.
                            KMG is probably not adequate.
                            3300uF 16v 10mm is one of those hard to find sizes.
                            I would order some Samxon RS series from badcaps.net for those.
                            The RS 3300uF 16v is 10mm and RS is perfect for most PSU caps.
                            https://www.badcaps.net/pages.php?vid=22
                            - Dr Seuss
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Originally posted by minitt
                              please comment on the biuld quality.
                              no fins on heatsink? that thing must run HOT
                              only one primary cap and it's an ost. ouch-o-rama
                              almost looks like a deer
                              definitely not for a p4. not even a PII
                              looks like flash without the function
                              sigpic
                              (Insert witty quote here)
                              • KeriJane
                                Mac Enthusiast
                                • Sep 2008
                                • 681
                                Seasonic S12-330 Still OK!
                                Hello.
                                I'm not quite sure if this is the way to post it,
                                but,
                                Does anyone want to discuss the pix I posted of the Seasonic S12-330 in the pictoral thread?
                                The PSU seems utterly unremarkable on paper but it is well made, reliable, efficient and has provided clean power 24/7 for over 3 years. I opened it up to see how it's doing after almost 4 years and then tested it at full load on a scope.
                                The only weakness obvious to me is that maybe the soldering isn't quite perfect with maybe a little slop and some leftover flux-looking stuff.
                                There are no burn marks on the board or on any of the parts.
                                Also, all of the Chemi-Con KZE output caps tested OK for ESR at about .02-.03Ω and none had the slightest hint of bulging.
                                Odd, but some of the KZE caps are 2200/16v in a 10mm can. I can't seem to find any direct replacements as KZE 2200/16 are usually 12.5mm diameter. The spots on the board appear to be marked for either 10mm or 12.5mm cans.
                                The heatsinks appear to work out well and keep the PSU very cool. There's even a small one for the Bridge Rectifier that may be a little hard to see in the pic.
                                Under the load test at around 330w, the PSU's fan barely sped up and the exhaust air was barely warm. Am I right in thinking that this indicates an over-built and very efficient PSU?
                                Rather than replace this incredible PSU with something newer, I merely extracted one of the ungainly Molex connector strings and replaced it with a single short SATA power connector to power the SATA DVD burner (one of the upgrades) The remaining single Molex string is now unused as the system uses no IDE hardware.
                                Have Fun,
                                Keri
                                PS. Even though Delta probably makes better PSUs, I still like Seasonic.
                                Mostly because they seem to last and run cool and quiet.
                                The More You Learn The Less You Know!
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3113
                                  Seasonics are always good, will provide many more years of reliable service.
                                  I wouldn't worry about it.
                                  • sLowEnd
                                    • Aug 2008
                                    • 33
                                    #257
                                    Like this:
                                    They're like the only company I've seen that makes yellow caps
                                    I call them Yellow Crap
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3113
                                      Originally posted by phaihn
                                      Is there a list of caps i need or should i just see when i open it sometime have to wait till i have the money plus i might end up have to buy a new PSU if this goes bad lol was thinking about doing that anyway but this will be intresting if it works.
                                      Whenever I recap a psu, usually I just replace all the 16v caps with 16v, 2200uf. Sometimes they will have 16v, 1000uf, or 16v 1500uf's. Just make sure they are not some weird diameter, usually 16v caps are 12.5mm, and will fit most psu's, except for those CWT antecs. Also, there is usually a 16v, 470 or 680uf, replacing that with a 2200uf is a waste, as this is just for the -12v rail.
                                      Then 10v caps usually do the 5v and 3.3v. These are usually 10v, 2200uf and sometimes you may find a 10v, 1500uf. I just replace all 10v caps with 2200uf's. Again, make sure they are not some weird diameter, usually 10mm 10v caps will fit most psu's.
                                      Then there will be smaller caps near the smaller 5vsb transformer, usually 50v, 47uf that filters the 5vsb. Replace that to avoid a high running 5vsb.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #259
                                        For the 3.3v rail, 2x 2200uF caps should be used as a minimum (or bigger if you have the space). You can use either 6.3v or 10v rated caps. I, however, prefer 6.3v to the 10v caps since they're cheaper and in some cases might last longer than 10v caps as the oxide layer is better preserved if the voltage is closer to the caps' rated voltage (at least that's what I heard from a few people here).
                                        For the 5v rail, 2x 2200uF should be used as well. Again, both 6.3v or 10v rated caps should work, but I think it's probably better to use 10v caps.
                                        For the 12v rail, 1x 1000uF 16v should be absolute minimum, and that's only if the power supply is used with an older 5v-based system (such as PII/P3) with 1 hard drive and minimum hardware. If it will be powering a P4 or some newer 12v-based system, consider 2x 1500uF to 2x 2200uF as a minimum. Most cheap power supplies only have space for 10mm dia. caps so those sizes might be hard to find. But if there's space for 12.5v caps, try 3300uF.
                                        For 5vsb, 2x 680uF should suffice, but it would be much better if there is 2x 1000uF (again, either 6.3v or 10v caps will be fine).
                                        The -12v and -5v (if present) usually don't need more than one or two small caps (in the range of 220uF to 680uF).
                                        One thing not to forget, however, is that ESR and ripple-handling capability ratings are much more important than the uF rating. Of course ESR depends on the can size of the capacitor, so the bigger the capacitor, the lower the ESR (which usually also means that the uF rating will be larger). Just avoid getting general purpose capacitors that mgiht meet the uF requirements but are not low enough on ESR.
                                        That's only if the power supply uses a 2-transistor design (the capacitor that 370forlife mentioned is actually used to control the 5vsb, hence why it's so important). This thread should help you identify if your power supply has it or not:
                                        https://www.badcaps.net/forum/showthread.php?t=6999
                                        Also everell's threads on the Bestec ATX-250 12E might be helpful as well.
                                        • Phaihn
                                          • Jan 2009
                                          • 842
                                          So id expect that my 500w Dynex PSU is no better then the 400 or 250w PSU they sell and just whaat do i need to recap it?
                                          and how do you save your shortcuts from FF the faves stuff whare is it stored?
                                          My Computer.
                                          AMD APU A4-3300 2.5ghz 1mb cache
                                          Motherboard GigaByte GA-A75M-S2V
                                          Kingston HyperX Blue DDR3 8GB (2x4GB)
                                          SB Audigy 2 ZS [B800] Sound Card
                                          500GB WD Caviar® Blue™
                                          1 Terabyte WD Caviar® Black™
                                          2 Terabyte WD Caviar® Black™
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
