12V 10A CCTV camera system power supply pulsating
  • harp
    • Jun 2022
    • 599
    • Planet Earth
    #201
    Re: 12V 10A CCTV camera system power supply pulsating
    Originally posted by rddube
    Ok, so I tried with a 56K resistor and then a 100K resistor and same result, keeps jumping around from 3-6V on the output when there is no load and with a load, nothing.
    I didn't do the test of the power consumption, I'm a little afraid of playing with 120V detached bare wires and DMM probes. Unless you think strongly about this, I'd rather skip this test.
    What next?
    So, let stay 100k in there, all datasheet is reffer to 100k.
    It is ok that you stay in your comfort zone, especially if you have not used bulb limiter.
    FYI there s thing caled luster clamp, luesterklemme, and can screw to fix wire and probes in it, and it is handy to have one in this like situation of 120v flying arround...
    Just know we will soon runout of options...
    Your psu is fully functional and not working...
    What about post #156, you not reply, have you worry anything about that?
    • rddube
      Aspiring Expert
      • Jun 2013
      • 940
      as far as i understand changing that resistor should change the frequency somewhat ..i might be wrong though as often i am .
      With the 56K resistor (I reinstalled the 56K resistor to try it a 2nd time), the frenquency is 51.93HZ and what is weird after about 1 second, it drops to 0 on pin 8. I recheck the frequency, this time it is at 31.03HZ and after a second or 2, drops to 0. On the 3rd try, 51.93HZ and drops to 0. I tried it a 4th time, this time 75.11HZ and dropped to 0 after a few seconds. Weird no?
      • lotas
        • Jan 2016
        • 4610
        • Russia
        #203
        If you haven't changed it to a new D2 yet, try replacing it.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 940
          Hi Harp, post #156 you said : "Wait aproval if this idea will provide power to ic to test.", so I didn't try that because no one replied. But I did do the inductance testing.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 940
            D2, I'm on my 3rd one...do you think it could be the chip itself? The one in there is a 3rd one, but I got 5 of them when I ordered them. The thing is is that the pads that hold the chip are getting weaker and weaker (I have to bridge a lot with solder to make a good connection).
            • lotas
              • Jan 2016
              • 4610
              • Russia
              #206
              You need to install such a socket and experiment.
              • harp
                • Jun 2022
                • 599
                • Planet Earth
                #207
                This is "normal" behaveour when testing a pin who no do any actual switching. Thats readings are false. I think it is some part of bouncing inside measurement circutry or simptoms of insuficient signal form. Frequency must be steady, readable all the time while is probe connected, and always is the same value, repetable itself.
                • CapLeaker
                  Leaking Member
                  • 8173
                  I agree with harp. That resistor won't do Jack, because the PWM is in UVLO for some weird reason.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 940
                    Ok, I see. But why is it giving me a steady voltage on the main caps (163V), and when I remove C4, I get a steady voltage of approx 18V on pin 3. Whenever I reinstall C4, everything starts to jump around?? R10 (1.5Mohm) is what cuts the 163V down to 18V, and it is steady when C4 is out and bounces when C4 is installed....
                    • harp
                      • Jun 2022
                      • 599
                      • Planet Earth
                      #210
                      I will love to know answer also...
                      Lost in space... try measure voltage (with decimal point max resolution) between point A and B, A and C, A and D, A and E, A and F, and A and IC Pin#1 (gnd) in DC and AC (mV) settings... in DC settings it has to be about 163V, but I am interesting if after decimal point has any changed along the track... maybe some information arrive... hunting dark shaddow...
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        #211
                        i think that means c4 is trying to start it up but there is a fault stopping it . without c4 it doesn't even bother trying to start .
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 940
                          Ok, should I reinstall the 100k resistor or leave the 56K or return to the 28k resistor before taking readings?
                          • harp
                            • Jun 2022
                            • 599
                            • Planet Earth
                            #213
                            I think that with 100k is better chance to even start working because of lower frequency. Once you get it worked, a 56k is good, max 51k. For me, 27k is not option at all.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 940
                              Ok, will rinstall 100K and report back
                              • CapLeaker
                                Leaking Member
                                • 8173
                                Look at post #16.
                                Don't get fixated on the jumping voltage on the cap. The problem isn't there, it's just a result. The PWM is either in UVLO or OVP. I did notice that one can buy this PWM with or without OVP protection for some reason or another.
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 940
                                  Look at post #16.
                                  Ok, I get you. The interesting thing is that although I did buy some new chips, I did reinstall the original at some point and was getting the same result. Did check the markings on the chips and attached is a photo - they do not have the exact markings - the original has OB in front of the chip number? It is the one on the right in the photo.
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 940
                                    OK, here are the measurements with 100k resistor installed:
                                    DC V AC mv
                                    A and B 164.3 27.2 jumping around
                                    A and C 165.3 0.000
                                    A and D 166.6 0.000
                                    A and E 165.2 0.000
                                    A and F 166.1 0.000
                                    A and IC Pin#1 (gnd) 164.2 0.000
                                    Might be cleared and better aligned on the photo.
                                    • CapLeaker
                                      Leaking Member
                                      • 8173
                                      Running out of options. Only thing left to do is to take the mosfet out of the primary, plug the psu in and redo the voltage measurements at the pins of the PWM.
                                      • harp
                                        • Jun 2022
                                        • 599
                                        • Planet Earth
                                        #219
                                        before do anithing, do exactly one more time very same measurement, write data to compare.
                                        my analisy
                                        point A is far end of +, our reference of this test
                                        probing ground
                                        point D is maximum 166.6 through jumper wire
                                        point F slightly lower 166.1
                                        pin#1 dramaticaly lower 164.2, on sam plane with F, were is 2v lost?!?
                                        point C near cap 165.3... something is pulling it down (mosfet try switch)
                                        point B 164.3 (27.2mV ripple present)
                                        point E 165.2 no ripple! there is only a 000 resistor between point E and B.
                                        So, check what is going on between point F and pin#1, also point B and E, where is lost 1v and ripple? Check 000 resistor, it is not posible it is ok.
                                        Is this make sense to you?
                                        Your board may suffer of circular crack arround solder point, and when you measure this, you push it with probe and connect again with track, and all seems ok, but it is intermitten.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 940
                                          Very funny you say this Harp, as when I initially took out the board on this PSU, I noticed a cold solder joint on the R9 leg shown in the picture. At first it looked like a cold solder, but now that you mention this (circular crack), I think that's what it was! And the board is very fragile in that area as I mentionned, around the legs of the IC using my Hakko desoldering tool, it removed some of the traces, so I think I should almost do an Xray examination!
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • CMCM
                                            Russound CA4 Power Supply Repair
                                            by CMCM
                                            Hello Everybody,
                                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                            The outputs marked 12v and 20v are all measuring only 1v.
                                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                            The capacitors physically look clean (no bludgesor leaks) and...
                                            07-03-2025, 01:12 PM
