BN44-00301A No signs of life
  • snoptel
    • Dec 2021
    • 49
    Re: BN44-00301A No signs of life
    Originally posted by R_J
    Does that voltage drop when you unplug the board? It might be just left over charge from when it was working.
    Or just check if you have any voltages on CN801, you should have 5.1V and 13V
    Not sure if I'm completely out to lunch here..
    I measured the IC. Roughly 320 VDC where marked and nothing on the other pins. I referenced the negative from the 320 VDC when checking the other pins.
    Ohh, and upon closer inspection, looks like the blue ceramic cap was replaced at some point.
    • snoptel
      • Dec 2021
      • 49
      Originally posted by stj
      no, the electrolytic with the rtv silicone stuck to it
      next to jumper JP811
      Thanks for the help.
      • R_J
        • 9582
        Like I said for the PFC CIRCUIT to work the STANDBY circuit MUST ALSO be working. as it supplies the VCC voltage to the pfc circuit ic.
        There is a zener diode marked ZDM802, Check the voltage ACROSS this diode. This is one of the standby vcc voltages.
        • snoptel
          • Dec 2021
          • 49
          Sure, gotcha. not sure what the issue is then..
          • R_J
            • 9582
            • snoptel
              • Dec 2021
              • 49
              Nothing, roughly zero volts DC.
              I measured both forward and reverse bias..
              • R_J
                • 9582
                With the negative meter lead on ZDM802 (anode), check the voltage on DM803 Cathode (white line)
                • snoptel
                  • Dec 2021
                  • 49
                  Nothing. 0.001 VDC
                  • R_J
                    • 9582
                    Nothing. 0.001 VDC
                    That is the vcc voltage for the standby ic as well as the pfc circuit, so I can only suspect that the standby circuit is not working after all.
                    • snoptel
                      • Dec 2021
                      • 49
                      Earlier I asked about testing the board out of the TV because I was wondering if there I a signal from the ON button that would tell the PSU to start doing its thing. Is there a jumper that has to be installed somewhere??
                      • snoptel
                        • Dec 2021
                        • 49
                        I also wonder may CM801 isn’t working properly seeing as how there’s 320vdc and no output
                        • R_J
                          • 9582
                          You would first have to have the 5.1 volt standby voltage to be able to turn on the other voltages.
                          • snoptel
                            • Dec 2021
                            • 49
                            Ah, ok
                            • R_J
                              • 9582
                              That's not how the ic operates, That is only the high voltage to the drain of the internal mosfet. The ic also needs to produce its own startup vcc for the ic to operate at all. once the the ic is switching (at 50~100khz) the transformer feedback winding supplies a run vcc voltage to maintain the vcc voltage.
                              What is the number on the ic so I can look up the datasheet?
                              • snoptel
                                • Dec 2021
                                • 49
                                Hmm, ok.
                                Do you have the schematic for this board?
                                CM801's number is 3BR1065JF
                                • R_J
                                  • 9582
                                  Hmm, ok.
                                  No I do not, but most smps are similar. This uses the same standby ic
                                  • snoptel
                                    • Dec 2021
                                    • 49
                                    Thank you for sending this.
                                    I'm looking at the datasheet for the IC you requested. Doesn't look similar. The one on the board only has 6 pins
                                    • R_J
                                      • 9582
                                      What datasheet are you using? the one I looked up has 6 pins
                                      • snoptel
                                        • Dec 2021
                                        • 49
                                        Can you attach it please?
                                        • snoptel
                                          • Dec 2021
                                          • 49
                                          Got it.
                                          So on the VCC pin what should the voltage be?
                                          • davidk35
                                            Lenovo ThinkBook 15 G2 ITL, some little signs of life
                                            by davidk35
                                            So i got above mentioned laptop. Which shows only some little signs of life.
                                            When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                                            What ive already done:
                                            -Flashed both bios chips 16 and 8 mb.
                                            -Tried adding another stick of ram
                                            -Check if backlight is faulty.
                                            So any ideas?
                                            Thank you
                                            09-03-2025, 06:34 AM
                                          • KYBOSH
                                            Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                            by KYBOSH
                                            I picked this one up today.
                                            Previous owner says no signs of life.
                                            TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                            Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                            The TV model is QN65LS03BAFXZA - version: CB06
                                            The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                            I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                            Will keep you all...
                                            04-05-2025, 08:32 PM
                                          • someonenotyou
                                            Dell Vostro 3501 - no signs of life after BIOS read
                                            by someonenotyou
                                            Hi.
                                            I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                                            Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                                            After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                                            Then I took the motherboard out...
                                            01-27-2025, 05:15 AM
                                          • tranquility
                                            HP EliteBook 850 G5 without signs of life
                                            by tranquility
                                            hello, i have a problem with HP EliteBook 850 G5
                                            shoring no signs of life. led near charging port and on/off button are off.
                                            board it taking just a few mA..i think it was 10mA
                                            i measured some things but i don´t find anything
                                            the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
                                            but i dont know why
                                            i cant really understand what the mosfets in the pictures are doing for crazy things.
                                            i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
                                            12-02-2024, 05:57 AM
                                          • KYBOSH
                                            Trying to Save - Samsung UN40MU6300 - No Signs of Life
                                            by KYBOSH
                                            Picked this one up today.
                                            No signs of life whatsoever. No red led light from the IR module.
                                            Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
                                            Checked the power button for continuity when buttons were pressed and I got readings.
                                            Disconnected various components (speaker, wifi module) with no difference.
                                            Checked mainboard's fuses (found 3) and they were all good.
                                            I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
                                            Then it dawned...
                                            10-12-2024, 11:20 PM
