BN44-00301A No signs of life
  • snoptel
    • Dec 2021
    • 49
    Hi everyone.
    I have a Samsung TV with a BN44-00301A PS board. When plugged in the TV shows no signs of life what so ever. No red standby light, no clicking, no back light..nothing!!
    First, I can´t find the right schematic online, if anyone has a copy, or know where I can get one I would really appreciate it.
    Second, I have checked the fuses, they are good. I have measured +/- 400VDC at the rectifier bridge.
    I'm a noob at this so any help would be awesome.
    Pics of the board are attached..no signs of heat of anything else.
    Cheers.
  • madan1
    • Nov 2016
    • 698
    • Bulgaria
    Re: BN44-00301A No signs of life
    Start measuring this connector. There is a pinout right next to it.
    • snoptel
      • Dec 2021
      • 49
      Thanks for the reply. I did, no voltages at all..
      • snoptel
        • Dec 2021
        • 49
        From what I've been reading, 5,1VDC should be available when the TV is off. I don't have that voltage anywhere.
        Anyone know where the jumper must be placed in order for the inverter to switch on when outside of the TV?
          • 31163
          the small cap near the center of the board starts the buck convertor chip to it's right on the heatsink, that generates your 5v standby.
          i assume you pulled the fuses out and metered them?
          you pull them out so you know that the clips are tight - just so you know.
          • harp
            • Jun 2022
            • 616
            • Planet Earth
            Have you familiar with diode mode on dmm?
            When is tv not connected to main and in big caps is no voltage:
            with multimetar in diode mode check briefly all transistor and diodes... you are looking to find possible short 0.000 on them.
            All must have some readings in one direction of probes, like 0.678...
            • R_J
              • 9582
              All you need to do is check if you have 5 volts standby, if you do not have 5v stby then check fuse FS802 if it is bad then icm801 is lkely bad.
              Check if the small blue disc cap next to the ic is cracked or has a burn mark. sometimes this cap shorts.
              • snoptel
                • Dec 2021
                • 49
                Yes, I actually had already probed all the diodes and transistors and didn't find anything that caught my attention.
                • snoptel
                  • Dec 2021
                  • 49
                  Thanks for the reply. I'm going to remove it and put in a new one.
                  I'll be back!!
                  • snoptel
                    • Dec 2021
                    • 49
                    Thanks for the reply. I'm assuming you mean the blue cap right?
                    • R_J
                      • 9582
                      You said you measured 400 volts at the bridge rectifier, to get this high a voltage the pfc circuit would be working, and for it to be working the standby circuit would also be working.
                      With the board unplugged Re check the voltage across CP802 OR CP803 (one of the main filter caps) this voltage should have drained down without the board plugged in, Then with the board plugged it check this voltage, if it is only around 160vdc, then the board in in standby, if it is around 385vdc then we know the pfc circuit etc is working.
                      • snoptel
                        • Dec 2021
                        • 49
                        The power supply will not operate at all without the 5 volt standby circuit working. The standby circuit is very simple and only has a few components.
                        stj is likely referring to the electrolytic next to the ic (CM803?) it is on the ic's vcc line and if it is bad (basically open) it will not charge to maintain the startup vcc voltage for the ic.
                        Usually the blue ceramic disc cap blows up (cracks in half) if it is bad.
                        Sometimes it is only bad solder connections on the standby ic that cause this problem.
                        Thanks again.
                        Is this the section that you are referring to?
                        • R_J
                          • 9582
                          Originally posted by snoptel
                          Thanks again.
                          I changed my post after re reading your first post. Recheck the voltage ACROSS +/- of one of the main filter caps. If your voltage reading in the first post was correct, then the standby circuit must be working.
                          • snoptel
                            • Dec 2021
                            • 49
                            I changed my post after re reading your first post. Recheck the voltage across one of the main filter caps. If your voltage reading in the first post was correct, then the standby circuit must be working.
                            Ok, I will go do that right now.
                            FYI - The measurements I take have been with the PS plugged in standalone, in other words, it isn't plugged into the video driver board or anything else. Not sure if that matters.
                            When I was installed in the TV, nothing happens, no standalone light..nothing..
                            • snoptel
                              • Dec 2021
                              • 49
                              Confirmed, 316 VDC between positive and negative leg of each cap.
                              • R_J
                                • 9582
                                Does that voltage drop when you unplug the board? It might be just left over charge from when it was working.
                                Or just check if you have any voltages on CN801, you should have 5.1V and 13V
                                • snoptel
                                  • Dec 2021
                                  • 49
                                  You can check the voltages with the board out of the tv, Just be careful that fancy black and silver cloth is not conductive.
                                  Haha, no worries. The cloth was just for the pic.
                                  • snoptel
                                    • Dec 2021
                                    • 49
                                    Yes, the voltage drops almost right away after unplugging the cord.
                                    Ok, let me go check CN801.
                                    Be right back.
                                    • R_J
                                      • 9582
                                      Be right back.
                                      This indicates the pfc circuit IS working, if it was not the voltage would only be 160vdc based on 120v A/C line voltage.
                                        • 31163
                                        no, the electrolytic with the rtv silicone stuck to it
                                        next to jumper JP811
                                        • davidk35
                                          Lenovo ThinkBook 15 G2 ITL, some little signs of life
                                          by davidk35
                                          So i got above mentioned laptop. Which shows only some little signs of life.
                                          When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                                          What ive already done:
                                          -Flashed both bios chips 16 and 8 mb.
                                          -Tried adding another stick of ram
                                          -Check if backlight is faulty.
                                          So any ideas?
                                          Thank you
                                          09-03-2025, 06:34 AM
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • someonenotyou
                                          Dell Vostro 3501 - no signs of life after BIOS read
                                          by someonenotyou
                                          Hi.
                                          I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                                          Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                                          After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                                          Then I took the motherboard out...
                                          01-27-2025, 05:15 AM
                                        • tranquility
                                          HP EliteBook 850 G5 without signs of life
                                          by tranquility
                                          hello, i have a problem with HP EliteBook 850 G5
                                          shoring no signs of life. led near charging port and on/off button are off.
                                          board it taking just a few mA..i think it was 10mA
                                          i measured some things but i don´t find anything
                                          the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
                                          but i dont know why
                                          i cant really understand what the mosfets in the pictures are doing for crazy things.
                                          i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
                                          12-02-2024, 05:57 AM
                                        • KYBOSH
                                          Trying to Save - Samsung UN40MU6300 - No Signs of Life
                                          by KYBOSH
                                          Picked this one up today.
                                          No signs of life whatsoever. No red led light from the IR module.
                                          Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
                                          Checked the power button for continuity when buttons were pressed and I got readings.
                                          Disconnected various components (speaker, wifi module) with no difference.
                                          Checked mainboard's fuses (found 3) and they were all good.
                                          I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
                                          Then it dawned...
                                          10-12-2024, 11:20 PM
